Question about Refrigerators
Installed new Ice maker and it works fine except the on/off wire arm does not go back to on (the lower setting) after making the ice to go into the bottom holder. I have to move it down to the on position. Kenmore
  • duke5551 May 02, 2010
    great support!!
  • 668 Answers
I recommend removing the icemaker, to reinstall the feeler arm. First, disconnect power to the unit. To remove the icemaker, remove the 2 screws above the mold and the one under the mold. The icemaker will be loose now and you can disconnect the harness. Now looking at the back side of the icemaker housing, on the top left side, you will see a small white bushing. The arm fits in this bushing. It just pushes in. I'm attaching a picture showing the arm and where it goes. You can now reinstall the icemaker.
Hope this helps .
Posted on Apr 29, 2010
  • 713 Answers
Hi,the problem is probably from the relay that controls the wire arm,i think it needs to be replaced or serviced,However,Be sure to review the Kenmore user manual that came with your refrigerator when you purchased it. If you no longer have a copy you can get it online at Kenmore's website. The user manual that came with your appliance has information that is specific to your particular model. It may have additional suggestions to help fix your ice maker problem that is unique to your Kenmore refrigerator model.Since,your device is still under warranty,you might have to take it to the point of purchase for necessary help.
Thanks and take care
  • 4,070 Answers
When the arm goes high enough it catches and wont go down. This is how you cut it off.If it's catching on the harvest cycle then the wire is going too high. You can adjust this by slightly bending the wire till it doesn't catch when it goes up.
Ice maker not working. Refrigerator had been off for 1 week. Now not making ice. There is water coming into the water dispenser but does not seem to be getting to the ice maker,
Hello there
f your ice maker has stopped producing ice completely, check these, in this order: It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these: bullet.jpg If your ice maker has a small red plastic lever, lower it to lower the wire. bullet.jpg If there's no plastic lever, simply lower the wire. bullet.jpg In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly. The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary. The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Jul 26, 2010 | Kenmore 21.7 cu. ft. Top Mount...
Ice maker not making ice now
thanks for requesting help from fixya...
I suggest u to do a hard reset by turning off the fridge completely for 5 hrs and then put it back on... Can u do this...
hoping to hear from u..
Thankyou
Aug 13, 2008 | KitchenAid KSCS25FKSS Side by Side...
Maytag sidebyside MSD2758DRW ice maker won't make ice
If the ice maker no longer make ice, check the following.
Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on.
On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice.
Check your door seals and thermostat, repair/replace as necessary.
Thanks
Jul 10, 2010 | Maytag Refrigerators
Jenn-Air bottom freezer ice maker not working
I took the arm of the ice-making machine out of the slot and put it back in, pushing it snugly inside the slot, then raised and lowered it several times. Then, with the arm in the up (stop making ice) position, I felt inside the ice-making tray, where I noted there were ice cubes as well as a sheet of ice at the base of the ice-making tray. I poured approximately 24 oz. of hot tap water into the tray to melt the sheet of ice. I turned the freezer temp control to "warmer". I think the freezer temp setting was too cold, causing the ice maker to freeze the water before it could make cubes. I have a working ice maker again!
Cynthia
Sep 07, 2009 | Jenn-Air JFC2089H Bottom Freezer French...
Icemaker not working, but did
Hi..
If your ice maker has stopped producing ice completely, check these, in this order:
  • It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these:
    • If your ice maker has a small red plastic lever, lower it to lower the wire.
    • If there's no plastic lever, simply lower the wire.
  • The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary.
  • The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
  • Thanks for using fixya
    Regards
    ICmanServer
    Aug 09, 2009 | Frigidaire FRT17G4B Top Freezer...
    May 30, 2009 | GE Profile PSW26P Stainless Steel Side by...
    Ice maker stopped
    Hi!
    Please check these:
    Please do rate this solution as FixYa and revert for further assistance.
    Thanks
    Rylee
    May 23, 2009 | Whirlpool Gold Series GI15NDXT 15"...
    Replaced icemaker with new one but still not working
    The ice maker has a problem The ice maker is a separate appliance within the freezer section. Please see the How things Work section of our website to learn about the normal functioning of ice makers. Some common problems with ice makers are:
    The ice maker has completely stopped producing ice
    The ice maker is producing ice poorly
    The ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
    The ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
    First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
    There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs
    Apr 01, 2009 | Kenmore 57029 Side by Side Refrigerator
    I have a Whirlpool Model EC3JHAXRL00. The ice
    Is the ice maker wire shutoff arm or switch (depending on
    models) in the OFF position?
     Is the water line shutoff valve to the refrigerator turned on?
     Has the ice maker just been installed? Is the freezer
    temperature cold enough to produce ice? Wait 24 hours
    after ice maker hookup for ice production to begin. Allow
    3 days after ice production begins to completely fill ice
    container.
     Does the ice maker mold have water in it or has no ice
    been produced? Make sure your refrigerator has been
    connected to a water supply and the supply shutoff valve is
    turned on.
     Has a large amount of ice just been removed? Allow
    24 hours for ice maker to produce more ice.
     Is there a water filter installed on the refrigerator? The filter
    may be clogged or installed incorrectly.
     Is an ice cube jammed in the ice maker ejector arm?
    For models with an interior ice bin, remove the ice from the
    ejector arm with a plastic utensil.
     Is a reverse osmosis water filtration system connected to
    your cold water supply? Make sue your connections are secure.
    Feb 19, 2009 | Refrigerators
    Whirlpool Gold Ice Maker problem Model # GS6NBEXRS00
    I hate to ask the obvious but is your water supply turned back on since the filter change?
    Feb 10, 2009 | Whirlpool GS6NBEXR Side by Side...
    Refrigerators Logo
    49 people viewed this question
    Top Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
