Question about Nokia N70 Smartphone
My mobile is not working properly so i want to formate phone memory,,,,,,,
  • 713 Answers
Hi,you can formatt the phone memory of the nokia n70 by dialling this code on your phone *#7370#
it also need a code which usually
is 12345.
The other way to format your phone memory for Nokia N70 is *#7780#, after that use this code:12345 to process it .
Posted on Apr 29, 2010
I lost my memory card passwod.......Nokia 2730 Classic...
first remove ur memory card,
then switch off ur mobile phone and remove ur sim card also,
then insert the memory card in switch off position,
and the switch on ur mobile phone and format the memory card as fast u as but within 8 sec.,
it will works properly try it now:...,
Sep 11, 2011 | Nokia 2730 Cell Phone
My mobile displays no memory card inserted when there is one
May be memory card is not inserted properly, plug it out and insert it again. and switch off and then do on your phone.
if not working by doing above...
Then there may be memory card problem, or format of memory card not supported by phone...
Do a memory card format using your PC, format it with NTFS file system. and then insert it into your phone it may start working...
Thank You
Apr 16, 2011 | Nokia 5800 XpressMusic Smartphone
Respected Sir, I have Nokia N73 hackked Mobile whenever i install the softwares it was not installed showing the msg corrrupt file, unable to install pls sir is there any solution for this problem
this specific error occurs in the hacked mobile phones when the hack is not installed properly.
you have to format both the phone and memory card in order to install the applications.
to format phone dial *#7780# to format the memory card remove it from phone nad connect it directly to a pc and format it there.
after formatting, properly reinstall the hack.
hope it helps
Mar 11, 2011 | Nokia N73 Cellular Phone
Memory card not showing in set
Hello
1. You would need to check the memory card on another phone and see if if shows.
2. If it does not work then you might need to format the memory card.
3. Insert the memory card into your mobile phone, Format the memory card in your mobile phone so the proper directory structure is created in your card. Refer to your mobile phone's manual for formatting instructions.
THANK YOU
Jan 27, 2011 | Cell Phones
Bluetooth of my phone is not working properly. When i try to switch on bluetooth then a massage is shown on screen " unable to perform bluetooth operation."
Try formatting the phone.This will help to solve this problem.If still the problem persists then update the software from any NOKIA CARE
To format nokia 3230 mobile please follow the below steps.
Please download the software called as 'Psiloc System Tools'.
You can download the system tool software from below website
http://gallery.mobile9.com/f/1047847/
Install it in your phone memory.DONOT install in your memory card because we will be removing the memory card.
Remove the memory card
Open the installed software.
Go to 'TOOLS'
You will find the option called as 'format phone',select it.
It will ask for confirmation, confirm it and it will format your phone.
It will restart while formatting and this process takes several minutes.
Once the mobile is started your mobile is formatted.
NOTE: Formatting will delete all your content from your phone memory.
Thank you
Oct 05, 2010 | Nokia 3230
When i put the micro sd card into my phone and tried to format it it said format failed what should i do?
remote memory card frm phone check if any small buton is there on your memory card if yes slide it to other side and than format it. it should work fine then.
If its tll not working properly you can try formating it once in your computer then again connect it in mobile and it should format. If its still not formating check it with other phone if possible if it do not work then also then you can thorw and get a new one
Oct 02, 2009 | PNY Electronics - Others
While i insert the memory card its showing format the memorycard
whenever u want to format any thing ,use quick formating otherwise it will creat a problem ok ,try to format the memo card by connecting it with ur computer
Aug 27, 2009 | Nokia 3110 Cellular Phone
How i can Format My Mobile Nokia 5130
heyyyyyyyyy
does any one know how to format my phone memory ?????? [:X] [:X]
iam facing a big problem .... my phone memory is 824KB onlyyyyyyyyyy what can i do now ???? [:X] [:(]
& that*#7370# dosent work on my handset nokia 5130 xpress music.
Jul 09, 2009 | Nokia 5130 Cellular Phone
Memory car id not formatted as like mssage given by the cell phone nokia 3500c when i m opening memory card
hi thanks for using fixya!
Unfortunately, there is no master password for the memory card. I suggest, if your memory card is working properly to other phones, you should check your phone perhaps it is not reading the memory card. It is better to bring your phone to the Nokia Care Center to further check the error.
Regards!
May 30, 2009 | Nokia 6233 Cellular Phone
Nokia 6288 / format memory card
MMC puchased should be formatted once, because new MMC comes with file system FAT-32. and mobile phones supports FAT file system. You can copy your data from MMC to PC using MMC reader/writer first. Then format it in your mobile and then reload your data in formatted MMC at folder created during formatting. Then you may see your MMC working properly. Fix your problem and vote here to fixya for solution....
Jan 09, 2008 | Nokia 6288 Cellular Phone
Nokia N70 Smartphone Logo
63 people viewed this question
Top Nokia Computers & Internet Experts
Computer Links
Gopi Venkatesan
Gopi Venkatesan
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
