Question about Samsung Televison & Video
Samsung 50 inch DLP has power will not turn on
Model HLS5086W. Front lights come on and off...timer, bulb, etc. Removed the bulb and appears to be ok, no sign of burnt mark.any idea what may be the cause of not turning on even though the power light is on.
  • 336 Answers
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.Here's the instructions to replace it :http://www.fixyourdlp.com/guides/samsung/bp47-00033a.php It's major symptoms are clicking,electrical sounds,shuts off and on and get the lamp indicator. But if you don't hear any strange noises,tv is around 6000 hrs,2-4 yrs,It's major symptoms are clicking,electrical sounds,shuts off and on and get the lamp indicator, it could be time to replace the lamp.Note lamp sometimes doesnt look bad when it's bad.The lamp you need is BP9601472A you can find it here http://www.discount-merchant.com/Samsung-HLM437W1X-OEM-Replacement-LAMP-BULB-p/samsung-hls5087w-lamp-sm.htm?Click=48173.Have a blessed one!
Posted on Apr 29, 2010
Testimonial: "thanks and will keep you advised on when checked out"
I have no flame or heat. How do I disammble unit ti check for burnt out bulbs ect.?
Check that the lamps have any obvious indication that they are burnt out, such as a scorch mark or otherwise. Careful not to break them if attempting to remove them. With the lamp removed you can test them for continuity (like with any other type of light that has a filament).
Feb 09, 2015 | Heating & Cooling
I've shorted out my oven after attemtping to change the light bulb.
most ovens will not operate until you set the clock - doesnt matter what you set it to as long as it isnt 00:00
Nov 30, 2013 | Dacor Preference RSD30 Gas Kitchen Range
DMX31 microwave does not work,grill, light, timer ok
its likley to be the magnatron burnt out, (the bit that makes it cook!)
its a very pricy part to buy and you cannot fit it yourself without putting yourself in danger doing it,, (like killing yourself!) so if you wont to get it fixed drop it into the shop or if its a fuw years old or more its a better bet to just buy a new one
0
Mar 05, 2010 | DeLonghi Microwave Ovens
One of my five EJ500C timers controls 6 outdoor landscaping lights behind my house. I installed the energy saving (coil type) bulbs and, at roughly 15 minute intervals after the lights come on at dusk, the...
The EJ500C is designed only for standard incandescent lights, not chandelier bulbs, CFLs, etc. Replace it with the ST01C, and you'll be fine. Intermatic may even exchange it for you if you if you complain to them.
Feb 27, 2010 | Intermatic Inc. EJ500C Digital Wall Switch...
Left turn signal flashes rapidly
If the left turn is flashing fast then this is a sign that either the front or rear indicator bulb has blown and will need replacing once you have done this then you should find it will work properly if not post me a message back then i can assist you further ok
Feb 13, 2010 | 2002 Buick LeSabre
SAMSUNG HLS5086W
with the back cover off there is a small switch with a blue actuautor near the lamp. press it up and hold it while you turn on tv. if tv works ok replace the switch
May 26, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Microwave external underside light no longer works
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights fan can be inoperable or stuck on or no bright, too. Sometimes this will similarly affect the exhaust fan operation, too.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
May 20, 2009 | Whirlpool MH1150XMQ Microwave Oven
Left rear brake light stopped working but bulb and fuses are OK.
These are Dual Function Bulbs. They control the Parking Lights and the Brake Lights. This Bulb is Burnt out on the Brake Coil inside the Bulb. I have actually seen Bulbs that were Bad But you could not Tell by jast looking at them. It should be fine with a New Bulb. Please Rate My Response! Thanks!
Feb 05, 2009 | 1999 Ford Expedition
Televison & Video Logo
369 people viewed this question
Henry  Thomas
Henry Thomas
