My child has pushed something on the remote and i can no longer view any channels...it is saying NO SIGNAL or NOT PROGRAMMED. the tv is linked to a virgin box
    President:
  • 1,779 Answers
Select the appropriate input you were using prior to your child's miss-hap with the remote.
Posted on Apr 29, 2010
Vizio tv says no signal
you should be able to do that with the remote by pushing "03"
or with manual buttons in menu under tuning selections , add channel 03
Apr 15, 2014 | Televison & Video
My TCL TV has a blue screen saying no signal. What button do I push on my new universal remote to get my cable tv
the button will be labeled either source, input, tv/video. if the direct TV remote was programmed for your television there is a tv/input button
Nov 03, 2013 | Televison & Video
I have a General Electric tv that someone gave me. I hooked up my dvd player and programmed it play on channel 3. I says no signal when I try to play a dvd on channel 3
There may be a chance you have hooked it up to play on AV3, as opposed to CH3. There should be an AV button on your remote or the TV. Press it a few times and see the channel flicks through the AV channels. They are usually AV1, AV2, AV25, AV3, AV35. Look for AV3, or for your signal on any of the other AV channels.
Mar 02, 2011 | Televison & Video
In just bought new Toshiba regza 40" Lcd tv and auto tuned it, but the picture is terible , snowy and colours are not good, what to do...
Hello
First of all reset the TV. for that
press and hold the POWER button
on the TV control panel for 5 or more seconds to reset the TV.
Then connect the TV tt any source like outdoor areiel or cable box etc, select the appropriate input, and retune the TV. First of all, connect it to an external antenna, and set it to autotune.
You must configure the ANT/CABLE input source before
programming channels (-left-hand column).
If the ANT/CABLE input signal type is set to Cable, the
automatic channel programming process erases channels
that were previously programmed into the TV's memory.
If the ANT/CABLE input signal type is set to Antenna, the
automatic channel programming process adds newly found
channels to the existing set of programmed channels (and
does NOT erase channels that were previously
programmed into the TV's memory.) To remove an Antenna
source channel from the memory, you must manually delete
it.
To tune the TV to a channel not programmed in the channel
memory, you must use the Channel Number buttons on the
remote control.
Programming channels when the ANT/CABLE input is
configured for Cable will take substantially longer than when
the antenna input is configured for Antenna. This is normal;
however, once channel programming is finished, you should
not have to repeat the programming process again unless
your Cable TV service lineup changes significantly.
Find out the received channels are clear or not. If they are clear, your TV is perfect, and the input device you connects ot the TV is faulty. OK.
Feb 16, 2011 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Not being able to change inputs
Change the input setting on the tv not the remote.
If you are using a universal remote it may not be programmed correctly.
When you push the input button on the remote it is changing it to the Over The Air Antenna, it is not recieving a signal and there is no channel label added for the station it is set to.
If you do have an antenna connected, from the menu do a channel search and see if it can find any signal.
Let me know how it goes, I can assist further.
lone99star
Jan 09, 2009 | Philips 32PFL3403D/27 32 in. LCD TV
Cannot return to TV from DVD play
If you have a Directv receiver, and you have to be on channel 3 on the TV to watch it, then we have to get you off the video input. On a Directv remote, there should be a button toward the top left hand side that says "TV input." Try pressing this first. If that doesn't work, then look for the button on the Insignia TV remote control that says "tv/video," "source," "input," or something along those lines. Press it (some TV's make you press it several times to change the input). Just make sure that your Directv receiver is on before you start pushing buttons.
Give that a shot.
Jan 06, 2009 | Insignia 19 in. Widescreen Flat-Panel LCD...
Channel search for my Phillips PL9125
You should contact to get original remote for that TV.
Nov 05, 2008 | Philips Televison & Video
Magnavox 15" lcd says it has attention no signal
Had the same problem. The solution: My remote has a button labeled "TV/VIDEO". I must have accidentally pushed this button so when I turned the TV on it was searching for the signal from a VIDEO source. It couldn't find the signal so it's programmed to automatically turn off if no signal is received. All I did to solve problem was I turned TV on and before it could turn off by itself I pushed the "TV/VIDEO" button on my remote to switch it back to receiving TV signal.
Jul 13, 2008 | Philips Magnavox 27MS343S 27" TV
27inch tv serial# 27r410T
Press vol-on tv& child lock on Remote together. Press mode on Remote using channel +/- to select child lock select new pin press mode E
Aug 08, 2007 | Sharp 25VS-J250 25" TV
Televison & Video Logo
73 people viewed this question
Top Televison & Video Experts
Electro Med Services...
