Question about Whirlpool ED2FHGX Side by Side Refrigerator
How easy is it to remove the doors?
Bought refrigerator and will be delivered next week. However, I will have to remove doors in order to fit thru interior doorway. Since this is the first refrig with water and ice on door, will it be a problem to remove doors?
  • Whirlpool Master
  • 8,220 Answers
You will have a problem. However the delivery men know a trick. I used to deliver em before I learned how to fix em. You mess around and have to fish any hoses out the door that might end up costing a service call because it is not covered in the warranty. It is best to let the guys go ahead and set it up for you. If you had a coupla strong guys who knew how to work a dolly then you could get the ice box in the door without taking the doors off. What you do is open the doors and begin by easing a door in firs being careful not to knock the door off the hinges then ease the ice box into the door and swing it to the side to get the other door in. It can be done but if you are not careful you could mess up the door. Best to let the guys who deliver it install the ice box. They should connect the water and level the icebox before leaving. Yeah it costs a few dollars more but these new machines are expensive and have delicate electronics. Banging them around, taking wires loose, loosing hoses inside the door, losing harness inside the door ain't good. Been there Done that.
Posted on Apr 29, 2010
Need to replace water line inside freezer door.
Water lines inside doors are typically not serviceable as the insulation is "foam in place". Pulling apart the door and reassembling will be next to impossible. Generally the door would need to be replaced.
Apr 14, 2014 | Samsung 24.8 Cu. Ft. Side-by-Side...
An automobile maker has an order for 7500 new cars to be delivered in one week. Each car must be fitted with a new hood ornament that requires 1 hour and 15 minutes to install. Assuming the factory...
An automobile maker has an order for 7,500 new cars to be delivered in one week. Each car must be fitted with a new hood ornament that requires 1 hour and 15 minutes to install. Assuming the factory operates on a standard workweek shift (8 hours per day for 5 days), how many workers must be assigned this job to meet the deadline?
Jun 14, 2012 | Refrigerators
Hi I have an LG- LFX23961SW The water hose that goes from water valve to ice maker keeps freezing up so no water goes to ice maker. We first thought the problem was the water valve, but discovered the...
Water is delivered to the ice maker mold bymeans of a "tube-within-a-tube" design. A conduit system consisting of three separate pieces(liner fitting, conduit, back panel fitting) isfoamed into place in the cabinet.This conduit provides a pathway from thefreezer liner to the back panel. The majority ofthis system is routed above the refrigerator linerto prevent the water tubing from freezing. Thetubing that delivers the water is routed throughthe conduit, and is secured by snapping into place at the freezer liner fitting.
And also check freezer temp and defrost system is working.I hope repairman would replace the insulation of tube by taking door as you said. Thanks.
Jan 29, 2011 | LG Refrigerators
My side by side refri w/ice and water in door makes ice but cant ice from tray to door
Mine just started doing the same. I purchased this one on Nov 08, 2008. If I take all the ice out of the tray I can see the auger turn and if I put back just a few cubes the system delivers ice thru the door. But, put too many cubes in and the auger won't turn. Piece of junk - out of warranty and and now I pay more to get the buggar fixed. I need to try another company next time.
Aug 30, 2010 | Whirlpool ED2FHEXN Side by Side...
Whirlpool model #GD25DIXH02. The front water dispenser tube cracked at the retaining screw. How do I change the filler tube kit?
Remove the top free door hinge cover and disconnect the plug there . This removes all power to the door . Remove the grill inside the dispensor , and remove the 2 screws at the bottom , holding the dispensor cover on . Lift the cover to remove , and disconnect the receptical , freeing the front . Next , remove the 4 screws holding the white dispensor switch mount , and slide out . Remove the screw holding the water fitting assembly .
Remove the bottom refrig kick plate . Follow the tube about 6 " to a connector , and disconnect the connector . The plastic compression nut , slips off the tubing after disconnecting .
Pull the dispensor tube , up thru the door from the top . Using the new tube with spout , pt number 4388152 . Insert the new tube into the hole from the top , and feed down , thru the door . Re-assemble in reverse .
Oct 26, 2009 | Refrigerators
Refrigerator won't fit thru door.
I ran into the same problem when I moved into my old house. the door way was to small, so I had to take both doors off the refrigerator to get it through the doorway. But I found out when I moved out of the house, that I was able to open both doors and wiggle it through the doorway. It was a hassle but it was alot easier that removing the doors. Good luck.
Apr 04, 2009 | Whirlpool ED2FHGX Side by Side...
Whirlpool Side-by-Side Fridge
unscrew the cover plates on the top door hinge there are quick connects for the elects and 3 bolts on the freezer side and just 3 bolts on the refg side before you removed the freezer door pull the kick plate and there is a water line quick connect you will need to disconnect it as the tube runs thru the hinge after the top bolts are out pull up on the door and it is off >>>Note: there are some small plastic washers on the hinge post make sure you dont lose them
Jan 27, 2008 | Whirlpool GS6NBEXR Side by Side...
Whirlpool ED2FHGX Side by Side Refrigerator Logo
56 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
