Question about Air Tools & Compressors
When the comp. shuts off the air bleeds back out the intake. what needs done to stop this It is a quincy model 350 2 stage compressor
    Scholar:
  • 169 Answers
You have one or more valves broken in the head and need to be replaced, and Quincy compressors require a special tool to remove and install valves.
Posted on May 08, 2010
I have a husky model 947265. And it won't shut off when I turn it off manually I have to wait till all the air is out before it turns back on
Free Husky Air Compressor User Manuals ' ManualsOnline ...
powertool.manualsonline.com > ... > Husky > Power Tools Husky
Husky Air Compressor Operator's Manual ... Plumbing Quincy Single-Stage Air Compressor - 3.5 HP, 220 Volt, 60-Gallon Vertical Tank, Model Q13160VQ.
Sep 04, 2015 | Air Tools & Compressors
I have a craftsman air compressor model # 921.16472S. When it got to cut off pressure the bleed valve started blowing. I changed the pressure switch and bleed valve then lowered the cut off pressure. When...
Either the pressure switch is not shutting off when reaching the desired pressure or the pop off is either the wrong one or it is bad. Some blow off at lower pressures for single stage air compressors while others blow off higher for 2 stage air compressors.
Feb 11, 2014 | Craftsman Air Tools & Compressors
How much oil for a quincy compressor model #216
What type of gauge belongs on the side of a 216 quincy compressor?
Also were can i locate one?
Thank you!
Tom
Mar 24, 2013 | Honda Quincy 17 - Gallon Air Compressor...
Quincy model model QMB/T is leaking oil out of filter
tighten filter
check that the filter is not too tight and distorting the seal
replace the filter
Oct 24, 2012 | Quincy Compressor Quincy 30 Rotary Screw...
The compressor air supply line from comp. to storage tank has a tee at the tank with a brass pluss in it with a tiny pin hole and that is allow air to be expelled. Is this a safety plug or can it be...
no, do not block with a solid plug. This allows air to bleed off the compressor so it will restart when pressure switch makes. If air continually bleeds out of this hole i would check the tank check valve . It is bad or has trash or something keeping it from closing. If check valve is bad it will allow air from the tank to bleed down until compressor starts or no air left in tank if shut down
Aug 16, 2011 | Campbell Hausfeld 5HP 20 Gallon Single...
Model hl410100 the compresser works well until the pressure reaches about 75lb then the motor stops but keeps trying to turn as soon as you bleed off some air the motor starts again until it hits 75lb.It...
might be a bad check valve and do nut use an extension cord ever on a air compressor it will over time damage the motor plug it in directly and use longer hose
Jul 06, 2011 | Campbell Hausfeld 5HP 20 Gallon Single...
I have a quincy 350 and the relief valve on the second stage keeps lifting. I have changed valves, unloader, gaskets, filters and cleaned the cooler. Could it be the rings?
It won't be rings. You may have solved the main issue with the valve replacement, but still have a weak safety valve, especially if it was popping a lot before your repair.. I'd try replacing the safety valve before going much further.
Nov 05, 2009 | Air Tools & Compressors
Need to know torque specs for rod and head bolts on a quincy model 350-11 air compresser
25-35 ft. lbs. Never saw any air compressor head bolts any other torque range If that number is a little squishy for you, call Quincy up tomorrow at
212-222-7700
Aug 21, 2009 | Air Tools & Compressors
Kicking overloads but not consistantly
First: Most all compessors use check valves at the tank and an unloader to allow the compressor to start without a load. Make sure that system is unloading and that check valve is not leaking causing head pressure at start. Second: Too frequent starts and stops will cause motor to overheat. Check Quincy manual for max starts per hour. enjoy
Nov 14, 2008 | Honda Quincy 17 - Gallon Air Compressor...
Air Tools & Compressors Logo
266 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
