Question about Kenmore Microwave Ovens
Kenmore microwave runs but doesn't heat. clicks 7 or 8 times evey 30 seconds
  • melowder Apr 29, 2010
    Found the problem myself. The lower door interlock was misadjusted.
    President:
  • 1,070 Answers
First it is important that you learn the proper safety precautions because repairing a microwave can be very dangerous. You should always be sure:
· The appliance is not plugged in
· You don’t touch any wiring or components until you discharge the high voltage capacitor
· Don’t work alone
· Remove watches and other jewelry
DANGER: Microwaves produce lethal voltages. They can kill.
This Will let you to Help more..Click here
If your microwave looks and sounds normal but isn’t producing any heat, you should check the internal door switches, the high voltage circuitry and the circuit board for problems. You may need a certified technician to help you make these repairs.
If you are unable to adjust the power level, there may be a defective triac or a problem with the circuit board. If the carousel inside your microwave won’t turn when you run it, the small motor that operates it may be broken.
HIGH-VOLTAGE TRANSFORMER: When the voltage transformer fails, it will often emit heat and smoke, but with the fan running, you might not smell it. With the cover off, it may be easier to smell. Also, you can look at the windings and see if they look discolored due to heat. If a high-voltage transformer is shorting, it can blow the fuse a few seconds after pressing the start button to start a cooking cycle.For More Click here
In case Of loose Connection.. >If the connectors feel loose, and any burning or melting seems minor, you should be able to carefully tighten the connectors with a pair of pliers, then sand or file the rusty-looking terminals of the magnetron until they are clean and shiny.
>If the burning is more serious, the connectors may need to be replaced. They can be obtained from home improvement centers and auto parts stores. They are 1/4" connectors and can be squeezed in place onto stripped wire with proper crimpers or a pair of pliers. Another option is to cut the connectors off the wires and solder the wires directly to the magnetron terminals. If this is done, do not apply heat to the terminals any longer than necessary...
>If the burning is really bad, the plastic surrounding the magnetron terminals is charred or melted, the magnetron may need to be replaced. Thanks For Contacting FixYa...
Posted on Apr 29, 2010
Kenmore elite microwave model 721.79203010 problems
I'd check to make sure you don't have a door switch that isn't functioning properly. Also, might be a control panel or control panel interface issue.
Mar 18, 2013 | Microwave Ovens
Bosch hmb5050 shut down after 30 seconds
It may be turning off because it is not heating, does it have the lights inside and the turntable both working?
Dec 10, 2012 | Bosch Microwave Ovens
I have a neff combi microwave oven and it stops working after 20 seconds and doesn't heat the food
It is one of three things, the microwave oven, "heart of the system" inverter board, "if less than 7 years old" and the keypad control board. all parts mentioned are not cheap.
Apr 16, 2012 | Microwave Ovens
My Kenmore Built-in microwave doesn't heat and the turn table doesn't turn. Model 911-47812200
It is good that the microwave does not work all together. It might be an interlock button or even a relay connection burn on the main mother circuit board.
Need a qualified technician. The service manual will be like $20-50.
e
Nov 22, 2011 | Microwave Ovens
Kenmore microwave model #565.60502990..........the microwave comes on when the door is opened!
First you need to determine when that happens if it's actually heating, or if it's just the fan and turntable coming on. (I suspect the latter).
You can test it by putting in a cup of cold water and letting it run (with yourself standing to the side of the microwave) for about 30 seconds.
Then unplug the microwave and check the water for warmth.
If it IS heating, then you probably have a control board issue and we can help you here.
If it is NOT heating, as I suspect, then I think it is a door switch or switch mount issue.
See these files:
http://031d26d.namesecurehost.com/mwd/safety.txt
http://031d26d.namesecurehost.com/mwd/disassembly.txt
http://031d26d.namesecurehost.com/mwd/doorsw.txt
May 25, 2011 | Kenmore 60502 Microwave Oven
Kitchenaid microwave runs for a few seconds and then shows error code F7. Kitchenaid Phone Center never heard of this error.
Hi alykat737,
This error code F7 on KitchenAid microwave is about a function key that is stuck on ERC. You will have to Replace control board (also called ERC or clock) to fix the problem. In case you will have to buy a replacement part you may contact Sears for the replacement part at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central.
Hope this helps.
Thank you for using FixYa.
Feb 06, 2011 | KitchenAid KHMS2050S 1200 Watts Microwave...
Kenmore microwave (2 y/o) will stop soon after you hit start.
A quick test. Switch off power then remove outer cover. Look for the transformer. remove the two wires connected to the primary side. Note, do not toutch anything else. power still sitting on the cap. With those two thin wires disconnected, make sure they are not toutching each other or leaning on the metal frame. Set a program that has been a problem and let it run. If it still stops and does what its not supposed to do, your board needs replacement.
Sep 16, 2009 | Kenmore 80412 Microwave Oven
Time count down on microwave oven
Unplug the Micro for about 5 minutes and plug it back in this will reset the board,it may have picked up interference from other electronics.If the issue continues have a technician look at it.
Aug 25, 2009 | Maytag MMV4205 Microwave Oven
Microwave Ovens Logo
132 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
