Question about Kodak Easyshare C813 Digital Camera
My Kodak easy share 12 MP digital camera isn't focusing
I bought a mini tripod to get good steady, crisp photos, but the focus flutters; keeping an in and out movement and won't settle.
    Guru:
  • 1,705 Answers
It's just a thought but quite a few cameras now have more than one focus options. Single point, multipoint and sometimes several types of multipoint focus.
Check your camera menu or instructions to see if yours has these functions. If so, try switching say to single point of focus. See if that's any better.
Posted on Apr 29, 2010
I have a nikon 55-200mm lens for the D40X digital camera. The pictures I take are blurred. I use the auto settings. the 18-55mm lens works fine and there are no problems with the picture clarity. Is the...
One of a few things might be happening
1. Photos being taken at high zoom (i.e. 200mm) are susceptible to camera shake, even though the lens is focusing properly. The solution here is use a tripod, zoom out, or steady yourself.
2. Photos being taken without flash when flash should really be used will result in motion blur (which is slightly different than camera shake). This is due to the camera using a longer shutter speed to let more light in, with the side effect being that objects will move while the shutter is open, blurring the picture. The solution here is to use a flash, or take pictures in better light.
3. The camera may be focusing on something other than what you intended.
3. If you are taking photos in good light with a steady hand, and the camera is choosing the correct subject to focus on, then yes, the lens could need readjusted, though this is not a very likely scenario.
If the lens is "hunting" for focus, that could be a sign that something is amiss.
A local camera shop can verify the accuracy of focus for your lens.
Mar 04, 2011 | Nikon D40x Digital Camera
My M1063 camera does not focus, even in timer mode and using a tripod the photos are out of focus. I get good pictures only in close-up mode. Is there anything wrong with my camera?
It sounds as if your camera is in close-up mode, where it only focuses on close-up objects. Try putting it into one of the other modes. What happens then?
Dec 26, 2010 | Kodak EASYSHARE M1063 Digital Camera
Close-up photos always end up out of focus.
Use the close-up mode by pressing the button with the flower (tulip) icon until that icon shows on the screen. Place the camera on a tripod or solid surface to make sure it is steady.
Oct 09, 2009 | Olympus ? Stylus 500 Digital Camera
Nikon D40 vertical focus problem
Make sure the camera is using the appropriate focus sensor.
Does the problem occur when you focus manually?
Are you handholding the camera? Many people don't hold the camera as steady when holding it vertically. Try putting the camera on a tripod or other steady surface and see what happens.
Jun 11, 2009 | Nikon D40x Digital Camera
FUZZY & BLURRY PICTURES.
It could be the focusing, did you check the focus every time? A slow shutter speed also causes blurry pictures. I know you do use your tripod, but if you don't use the self-timer function or a shutter cable then you are not using the tripod properly. Also, check the front piece of glass in the lens, clean it if it has stains or whatever on it.
Mar 28, 2009 | Kodak EasyShare Z1015 IS Digital Camera
"hand" icon flashing
It's likely your photos are blurry from camera motion, caused by taking a hand-held photo with a slow shutter speed, rather than out of focus.
The hand icon flashes when you don't have enough light to take a crisp (not blurry) photo without either using a tripod (or a flash). The reason for a flashing hand is you can't "hand-hold" the camera at the current settings - you need to use a tripod. If you are "zoomed in" (on a telephoto setting for your lens) you can sometimes get a crisp hand-held photo if you "zoom out" to a wider angle setting on the lens. (You need a steadier hand to hand-hold a telephoto lens setting than a wide-angle lens setting.)
You may have changed a setting that sets the ISO (the normal setting would be "auto") and if so, if you change the ISO to a high number, or to auto, this will help you take better photos in low light. Check your camera's user's manual to see how to check/change the ISO.
When you have more light the icon will stop flashing. If you need to take hand-held photos in low light then you need to use flash, or get a better camera that has better low light capabilities.
Dec 14, 2008 | Nikon Coolpix 5200 Digital Camera
Poor focus
Are you using a DX lens. Do you know if you have the camera's auto focus set to AF (auto focus) or M (manual)? There are many things that effect the focus and as an added note, any shots over 1/60 shutter speed in normal light should be in focus without the need of a tripod.
I shoot a D80 and a D70 and I have excellent results and very clear pictures, I'd be will to bet that either your lens is incompatible with the camera or it's just a setting. I'd be happy to help if you could give more info to your settings.
Jul 18, 2008 | Nikon D80 Digital Camera with 18-135mm...
DSC-S650
paintshop pro 8 is what I use and it has a one button fix to enhance photos or you can keep hitting "clarify" or the "sharpen more" tool. it should help alot unless really blurry out of focus.
Feb 29, 2008 | Cameras
Blurd LCD and picture print outs
it is the camera shake. Try using a tripod or higher ISO.
Feb 13, 2008 | Kodak EasyShare C300 Digital Camera
Cannot get clear close-ups
Recommend not using flash. The first thing is that your subject should be well lit. Try placing it on a lighter background with good lighting around it. Also recommend using a tripod to keep the camera steady, and setting and using the camera's timer to take the photo (this also helps keep the camera steady). The closest auto-focused macro shot that the S200 takes is around 1 foot from the subject. Depress the shutter button halfway to verify that the subject is in focus (one of the three squares on the LCD should turn green on the subject). Next depress the shutter button all the way to take the photo.
Jan 24, 2007 | Canon PowerShot S200 / IXUS 178 Digital...
Kodak Easyshare C813 Digital Camera Logo
115 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
