Question about Microsoft Xbox 360 Console
Xbox 360 after having 3 red light now it turn to 2 light.. i remove everything snd put s thin layer of rubber beetween heatshild/heater coil and memory underneat of it*i guess* after doing all this 2 red light comes on and my fan will run for five second and stop and leave me with 2 red lights... i even try pushing eject first*instead of power* it open afer five second of red blingking and its seems like i dont have power to closed the cd back or hitting eject to closed it..running out of sulution.. thank you
  • 25 Answers
Just contact the fixing microsoft company because there is no other way but it may cost you some mulla
Posted on Mar 29, 2008
I have taken my xbox 360 apart,cleaned it, put new thermal coating on it, checked all the componets on the motherborde to make sure that they won't lose, and put it in a place with good air flow but the 2...
2 red lights meaning the chips are overheating. This could be the heatsink does not have a good contact with the chip. Don't put too much thermal paste. just a very thin layer.
Jun 02, 2010 | Microsoft Xbox 360 Console
I have one red light flashing on my xbox 360. how can i fix it?
If you have a hard drive, clearing the cache might resolve the one red light error. Also, you can try to remove the hard drive and power on the Xbox 360 Console without the hard drive to see if the red light will still occur. If it doesn't appear it is the hard drive causing the error and needs replacement, if it does flash the red light still, it is a hardware failure in your Xbox already.
May 06, 2010 | Microsoft Xbox 360 Console
3 red lights on xbox 360
What is the Red Ring of Death?
When Microsoft designed the Xbox 360, they attempted a innovative method of mounting the heat sinks to the motherboard. During normal operation, the temperature within the case is very hot. Which in turn causes the motherboard to flex against the x clamps. It is this flexing, which results in the soldered joints around the processors coming away from the motherboard. The fault is indicated by the now infamous 3 red lights!
Recent Xbox 360 Elite's have been upgraded with a stronger epoxy resin to glue the processors down. Whether this will work, only time will tell!
The X Clamp fix
The modification detailed in this guide, alleviates the flexing of the motherboard and maintains uniform pressure on the processors, this in turn ensures the heat sinks are far more effective in dissipating the heat build up.
Kit list
Torx Screwdrivers T8 & T10
Pliers
Artic Silver Thermal Paste
Thermal Paste cleaner (nail varnish remover!)
Thin flat bladed screwdriver
8 m5 10mm bolts
8 m5 steel spring washers
24 m5 1mm width washers
Step 1 - disassemble the console
Stop and take a look at your warranty, is it still in date? If so contact Microsoft for a replacement! If not, then proceed.
Remove the front face plate by placing your thumb into the USB door, applying pressure on the side panel, you will be able to lever the cover off. Do not force it!
Once removed this will expose the Microsoft warranty sticker. Next, we need to remove the side panels.
They are kept in place by 3 lugs on each side, which can be seen by looking through the ventilation holes. Using the thin screwdriver (or wooden skewer), push the lugs through the holes, whilst gently levering the grey side panel up. Once you have released a couple the panel will lift up quite easily. You will have to remove one of the rubber feet, to access one of the lugs and the hard drive if you have one.
Once both panels have been removed, we can move onto the case itself. On the rear of the case are 6 retention slots and 4 clips on the front of the case.
Unclip the front clips using the thin screwdriver, and gently lift the front up about an inch.
Now locate the rear 6 retention slots, and again using the thin screwdriver, push gently into each slot, you should hear a click each time.
Once all 6 have been released, you will be able to lift the top halve of the case off.
Flip the console over, and you will notice 14 silver screws and 8 black screws, remove these using the Torx screwdrivers.
Once all removed, turn the console over and remove the case.
This will expose the motherboard and DVD drive. To remove the DVD drive, simply lift upwards and unclip the cables from the rear of the drive.
Now you will have access to the white plastic fan shroud, which lifts out by unclipping the retention hook at the top of the shroud. Unclip the cable to the fan.
At the front of the console, you will notice a daughter PCB, by the power button. Unclip the white power button cover and remove the 3 screws with the T8 screwdriver.
Unplug the daughter board, this will enable you to lift the motherboard out carefully.
Once you have the motherboard out, you will notice on the underside 2 x clamps.
To remove the x clamps, you will need to pry the clamps off the metal studs. Insert the thin screwdriver into each corner of the clamp, gently levering each one until they are released. If you do 2 corners at a time, it is easier. Take your time, it is essential we do not damage the motherboard.
Once the clamps are removed, flip the motherboard over and gently remove the 2 heatsinks by lifting them up. The low profile one is the GPU heatsink, the main cause of the problem!
Using the Pliers, or small spanner, remove the four bolts on the underside of each heat sink. The bolts are no longer required.
Now we need to remove all traces of the old compound from the heat sinks and processors. Start by using a plastic scraper, usually supplied with the thermal paste or an old credit card! Take extra care when cleaning the processors.
To remove the remaining compound, use the nail varnish remover or if you have it compound cleaner, only a little is required.
With the processors, we are trying to obtain a mirror finish on them!
Now apply a little dab of compound to each processor and spread with the plastic card, we want a thin film across the top of the processor, no more no less.
Now we start the process of re-fixing the heat sinks.
Place a spring washer on each bolt (m5 10mm) followed by a steel washer, insert the bolt through the underside of the motherboard and then place 2 steel washers on the bolt. It is essential we have the correct width between motherboard and heatsink.
In order for the bolts to stay in place whilst attaching the heat sink, I stand the motherboard on its side and screw the bolts in a couple of turns until they have purchased.
Once all 4 have been attached, we need to systematically tighten each bolt, so start top right, then bottom left, bottom right and top left. This ensures the heat sink is uniformily tightened and not one side at a time. Repeat on next heat sink.
We can now plug everything back in, apart from the fans.
Turn the console on, we want it to overheat in order for the changes we have made to reset. Looking at the power bottom, wait for the 3 red lights to go to 2 red lights, this could take a couple of minutes. Once we have 2 red lights, leave the console on for about 5 mins.
Now turn the console off and let it cool down for about 1 hour.
Now we come to the test, plug everything back in including the fans and turn the console on. You should now be looking at green lights.
If you have green lights, re-assemble the console.
If you have red lights, we have a couple of procedures to follow, do not worry, some consoles take a number of attempts before the fix is successful.
First, loosen the screws holding the heat sink in place and with the fan disconnected run the console with 2 red lights for another 5 minutes, then allow to cool.
Once cooled try the test again with everything plugged in. still getting red lights?
Check the thermal compound is not too thin on the processors and before tightening the screws up, run the console again for 5 minutes with 2 red lights. Tighten screws up and allow to cool. Run the test again after an hour. If you still have red lights, run the console again with the fan disconnected for a longer period of time on 2 red lights, before allowing to cool.
It is normal for the console to take about 3 attempts to get all green. If none of the attempts work, gone back to the beginning and start again. Do not give up, this fix has been 100% successful for me.
Once you have green lights and you have put everything back together, run another test to ensure you still have the green lights, remember you will not need the 8 black screws for the case.
It is advisable, to run the console on low settings for about 20 days and keep it well ventilated. Fan upgrades are available, which run more efficiently.
For more detailed instructions and video's visit: http://bestxbox360repairguides.com/
Enjoy your Xbox!
Steve Thornton offers insight into the information product market, researching a number of niche topics and resourcing products in those areas.
Please take time to visit the estore at: http://www.lobbythornton.com/estore
Article Source: http://EzineArticles.com/?expert=Steve_Thornton
Sep 26, 2009 | Microsoft Xbox 360 Console
3 red lights flashingand xbox doesn't turn on
The Xbox console is overheated.
  1. Let your Xbox 360 console cool. You may have to wait several hours for your console to cool enough. Don't turn on your Xbox 360 console when the console is hot.
  2. Verify that your Xbox 360 console has enough ventilation and that the fans are operating.
  3. If the lights continue to flash red after you try steps 1 and 2, contact Xbox Customer Support.
To try to prevent this problem, follow these precautions:
  • Don't block any ventilation openings on your Xbox 360 console.
  • Don't put your Xbox 360 console on a bed, on a sofa, on a carpet floor, or on any other soft surface that may block ventilation openings.
  • Don't put your Xbox 360 console in a confined space, such as a bookcase, a rack, or a stereo cabinet, unless the space is well ventilated.
  • Don't put your Xbox 360 console near any heat source, such as a radiator, a heat register, a stove, or an amplifier.
Taken from Microsoft support.
thank u
rate me!!1
Jul 12, 2009 | Microsoft Xbox 360 Console
Xbox 360
It's overheating. Consider buying an external cooler at a local Target or Best Buy.
Jun 08, 2009 | Microsoft Xbox 360 Console
My Xbox 360 has the 2 red rings and is out of warrenty
Turn it on and put it next to a heater in the sun.
Feb 03, 2009 | Microsoft Xbox 360 Console
3 red lights and one green one in the middle HELP
how can i fix this ring of death it will not let me play the game
Jul 31, 2008 | Microsoft Xbox 360 Console
2 red lights on the ring of light
2 red lights mean its getting overheated i noticed this was happening 2 mine whilst i was playing halo 3 so every 30 - 40 mins i saved and quited and placed a fan infront of the back pannel for about 5 - 10 mins this cooled it down and could be played for longer without thret of over heating
p.s saveing and quiting can be frustrating every 30 mins so do it after that level 30 mins through. :)
Jun 09, 2007 | Microsoft Xbox 360 Console
My xbox flashed a red light, and the screen goes black
I went with the eraser fix and it worked like a charm. Can anybody explain why using erasers changes things and makes the 360 work without the 3 red lights flashing? Just Curious!
May 05, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
