Question about Pride Jazzy 1103 Ultra Standard Power Chair
It just flashes all the time when it's on and won't move. pride 7. what error do you get when the joystick goes bad? can I replace the joystick myself?
  • 23 Answers
These are called VSI error lights. The VSI is the fancy name for your electronic controller. [Basically the joystick :) ] The number of times they are flashing, gives you the codes of the problem. The system locks until it is sorted to prevent injury. Follow the link below for the User Manual for your model. First check page 37 to see if it isn't just locked, then page 38 for code meanings. If its flashing lots, most of those high numbered ones are just a case of checking things are all plugged in tight.
http://www.rentascooter.com/downloads/_manuals/pridemobility/Pride%20Jazzy%201103%20Ultra%20Owner%27s%20Manual.pdf
Hope this helps.
Posted on May 06, 2010
My flash code is SEVEN PAUSE SEVEN which indicates JOYSTICK FAULT.
PDF]INFINFB2043_Jazzy_600-600XL_Troubleshooting_Rev B ...
www.pridemobility.com/download.php?...Jazzy_600-600...
Pride MobilityWhat if the systems on my Jazzy 600/Jazzy 600XL seem to be "dead" (controller does not ... Each controller will flash a code via the battery ... 7. Joystick error. Contact your authorized Pride Provider. Four yellow LEDs ... This is indicated by the VR2/VSI speed ... flash in a numbered sequence followed by a 2-second pause
Jan 18, 2016 | Pride Jazzy 600 JAZZY 600
Joystick error code 7 flashing lights, 3green 3orange 1red
Check and see if the charger is still plugged in when you have this fault. Usually a 7 light flash is a controller fault. Sometimes it will also mean you have one or both motors disengaged. If the charger is not plugged in when you have this fault then try and push the chair. If it moves freely then you need to engage the motors. If you have to engage the motors you will have to power down the chair and power it back up to clear the fault. If this does not work you will need to contact a technician to troubleshoot the root cause.
Apr 05, 2014 | Pride Mobility Products New Pride Mobility...
Lock key keeps blinkinglights blink 9 times
Depending on the controller type being used you either have a controller solenoid brake fault (sticker on bottom of joystick will say "PG Drives" and have 9-bars flashing) or a communication error between the controller and joystick (Dynamic Controller flashing wrench).
Repair for PG Drive is to replace joystick/controller.
Repair for Dynamic is to clean, remove and reseat or replace joystick cable.
Nov 12, 2013 | Pride Jazzy Select 6 Indoor Power...
I charged the batteries for 12 hours and then turned the chair on. The batteries appear to be bully charged, but the chair will not move. The joystick is flashing 8 times. Apparently a joystick fault? ...
There isn't too much you can do to fix this problem. You will have to have the joystick replaced. If Medicare paid for the chair then they will pay for most of the repair costs contact the provider that sold you your chair to have them order a joystick from Pride and repair the chair for you Hope this helps
May 04, 2011 | Pride Mobility Products Pride Jazzy 600
When I turn on controller power the speed lights flash slowly. Joystick does nothing and chair is dead. Chair is Pride Jet 3 Ultra.
Do all of the speed lights flash at the same time or do they ripple from left to right? If they ripple from left to right the chair is in lock mode and you can use the unlock procedures from my tips to unlock. If they are all flashing at the same time you have an internal joystick problem and the joystick needs to be replaced Hope this helps
Apr 27, 2011 | Pride Mobility Products New Pride Mobility...
I have a Pride Jazzy 615HD electric wheelchair. When I turn it on, ,it will not move. The bottom flashes 8 times in a row. The speed lights go from red to green, one at a time, as well. The thing is...
Eight, pause, eight Power Module Fault - Check connections to the power module and batteries. The power module is located near the front of the chair under the base cover you will have to unplug the joystick then remove the seat and the cover. The wiring for your motors, batteries and joystick all plug into the power module. Check each connection to make sure they are in good and solid if you can pull it out easily then the wire was not in there locked push in each connector to make sure they are seated in the module. now you can plug the joystick back into the cable coming from the module without replacing the cover and seat. Turn on the joystick to check if you are still getting the error if you are then the power module will have to be replaced If the error is gone then unplug the joystick replace the cover and seat plug the joystick back in and power up then go for a ride Hope this helps
Apr 16, 2011 | Pride Health & Beauty
When switched on power light flashes.
How many flashes? Count number of flashes should be a slight pause then flashes the same number of times . Your manual will give you flash codes and you can determine what the problem is. If all the lights are flashing and there is no pause the chair could be in "lockout" Your manual should tell you how to get the chair out of lockout I think that Pride uses the joystick to get it out of this mode.. Turn the chair on move the joystick forward till you hear a beep then move the joystick to the rear until you hear another beep release the joystick and the lights should quit flashing Hope this helps
Aug 12, 2010 | Pride Mobility Products New Pride Mobility...
I'm getting a 2 bar flash code and just replaced
If you can do this or have someone else do it for you. Switch the motor connections on the main computer of the chair. If the it goes to a 4 flash then you know that the left motor is bad. If it stays at two flash then either the controller or the joystick is bad.
Sep 15, 2009 | Pride Mobility Products Pride Jazzy 600
Pride mobility Jet 3 Ultra Power Chair 7 flashing lights. joystick error. how do i fix ? Three red LEDs Four yellow LEDs
a 7 Flashe code. There is a joystick fault. Make sure the joystick is in the center position and then power off and on again. Check all your couplings. make sure when turning on the unit you only mash the power button for 1 sec. 2-3 sec will put the unit in "Lock out mode".
This ierror will also be present if the joystick is off center when powered up. If you experience these symptoms, you must first make sure there is no physical damage to the joystick preventing it from returning to the center position. Then turn the power off and back on again (making sure the joystick is not depressed in any direction. If the joystick repeats this error, the controler much be replaced. smithrmrm70@hotmail.com
Sep 06, 2009 | Jet 3 Ultra Power Chair
Lights just flash on controller and wont move jet 3 wheel chair
Do they flash in series? Like ten flashes then a pause then ten flashes?
Mar 27, 2009 | Pride Mobility Products New Pride Mobility...
Pride Jazzy 1103 Ultra Standard Power Chair  Logo
258 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
