My friedrich unit compressor wont come on
My friedrich unit compressor wont come on fan comes on but not compressor it wont heat nor cool
  • 674 Answers
This could be a bad capacitor or your compressor may have gone bad. Another possibility is an overload that is tripped and has to be reset manually. Hope this helps.
Posted on Apr 29, 2010
I have a Friedrich Ptac unit Model PDH15K5SE-A. The unit turns on ok but does not heat. Need advice what to do. Thanks
Does the unit cool ok? If yes, you likely have a problem with reversing valve. If no, likely a refrigerant problem.
Mar 01, 2017 | Friedrich Heating & Cooling
Friedrich ductless heat pump will not start up.
Did you check to see if the compressor is running? Check out start relay/capacitor.
Sep 21, 2017 | Heating & Cooling
Hi i have a roof top LG LS- k1830 HL 18000/19000btu heat & cool mini split air conditioner. my ? is the condenser fan wont run and the after the unit is on for a while the high pressure line does...
the condenser fan will start as soon as the compressor turns on( that is the outside unit)
the inside fan will run regardless if the compressor is running or not
Jul 15, 2017 | LG LS-K1830HL Heat Cool Mini Split Air...
Ac unit wont come on the breaker was tripped, reset the breaker, checked the unit for 220 volts has the correct voltage. The unit is a split system heat on one side ac on the other. The blower motor wont...
hello
maybe you have over current .compressor act over loud.
you wait was cooled compressor .than start again and check current and over loud and condenser fan.
Sep 06, 2011 | Friedrich WallMaster WS07A10D Air...
Friedrich SS12F10 chassis fan is running compressor not cooling is it worth repairing - how much
Hello, if this is a window ac and is not cooling I would make sure the unit is receiving proper airflow across the evaporator coil, chek filter and clean if dirty, clean evaporator coil with coil cleaner which you can purchase at any heating and cooling store. If the unit still does not cool than ypu most likely have a leak in the system and is undercharged. In this case the repair would be between 80- 120 dollars. In some cases if the unit is less than the repair you are better off buying a new unit. However, if your unit is more than the repair then you are better off getting it repiared.
Apr 28, 2011 | Friedrich Heating & Cooling
Cools but no heat compressor or fan doesn't come on but on cool cycle
generally compressor will not come on in heat mode is this a heat pump or combo heat ac unit if outdoor unit look for overload button on unit itself
Oct 06, 2009 | Heating & Cooling
Indoor unit runs ok outdoor unit compressor and fan do not start
Hello rfrizzell,
My unit is giving me the same alarm. If you have found the solution, please email me at danielabrewster@yahoo.com
Thank you very much.
Mar 14, 2009 | Friedrich MR18Y3F Split System Air...
Friedrich YM18J34 will not heat
Sounds like a bad limit switch. Open and test continuity on all limits with power off and at least one wire off one side of each
Jun 17, 2017 | Friedrich TwinTemp YM18J34 Air Conditioner
Air conditioner comes on fan only. the compressor doesnt seem to be coming on. the is no cool air blowing. the unit is brand new and was jusy installed.
there will be option in remote to on the fan and compressor separately may be you would not have on-ed the compressor through remote or else there would have been any loose connection in the wire which connects the compressor
Jul 29, 2008 | Friedrich Heating & Cooling
Heating & Cooling Logo
204 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
