Question about Epson Stylus CX7800 All-In-One InkJet Printer
Ink level says full on all colors but I've used printer quite a bit
    Scholar:
  • 118 Answers
Unplug, wait a minute, plug back in, should reset.
go to systems application folder and dbl click epsons printer icon for settings. this will tell you how full the ink is.
lastly, epsons web site for trouble shooting might help
good luck
Posted on Apr 29, 2010
Won't Print Color Ink
INK PROBLEM
Inkjet printers need to be used frequently to prevent inkdrying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
May 19, 2012 | HP PSC 1510 All-In-One InkJet Printer
I only want to print black color but was asked to replace color inks.
Unfortunatly, because its a color ink jet machine you will need to replace the ink to print anything. The way its designed is that it has one printer head for all four cartridges.
When you replace the color ink you will deffinetly be able to print.
Apr 02, 2010 | Brother DCP 115C All-In-One InkJet Printer
How can i check my ink level on printer
It's easy to check the ink levels. You just go to your printer icon for your printer in the Printer aplet in the Control Panel. Click on "Color Management" and you will see the ink colors for each ink container and the levels. It will say 82% full for example and show a yellow triangle like a yield sign if some are out of ink.
Sep 13, 2009 | Epson Office Equipment & Supplies
Replaced color cartiage, now only one color prints, red? Help
Try to check the level of your ink in your color catridge maybe is running low or empty then if its empty then remove the catridge then replace another color catridge full of ink then run your printer again. If you successfully installed new ink catridge then it will automatically reset the level of your ink monitor to full.
Jun 16, 2009 | HP OfficeJet t45 All-In-One InkJet Printer
HP C6280 says out of black ink
Something is wrong with your Blach carrier or connections. Use a bit of alcohol and clean the array of gold contacts where the Ink cartridge plugs in. Most of the pins are shutter and piezo control (get the ink on paper) but a few do other stuff like check ink level, # of hours runtime, etc. This is very common problem with inkjet printers. Hope this helps.
Also... rub the contacts on the printhead with a pencil eraser to make them shiny and bright.
Cheers!
Mar 26, 2009 | HP Photosmart C7280 Printer
I just installed a Lexmark 2500. It came with an ink cartridge (color) I purchased a black cartridge and installed it but it does not seem to be working. How do you darken the ink on this printer. It seems...
Maybe you can try to rest the black ink level 1st. To reset the ink level:
1) Goto the Lexmark Solution Center application.
2) Press button Maintenance>Install a new print cartridge, follow the instruction on screen. U may then have your new full ink level. Note: u only can reset to full level, cannot customize the level by your own.
Hope this help.
YBC (/\)
Jan 14, 2009 | Lexmark X2500 All-In-One Printer
Neither black or color will print..
remove and check cartidges it is quite possible that the cartridges must hve dried up.
Dec 08, 2008 | HP PhotoSmart C4180 All-in-One Color...
Won't print black ink
I am on my second Photosmart C6180, the first one I had quit printing black ink after 6 months, after hours with the HP help desk, the finally decided to replace the printer. I have now been using the replacement for several months and just this weekend it too quit printing black ink...no copying, no printing and no faxing.  I am now shopping for another, not a HP.
Sep 08, 2008 | HP Photosmart C6180 All-In-One InkJet...
Wont print
some printers share the ink from color to black but you can select if you wants to use only black just go to printer than properies than select to use only black but you probably have to remove the empty color one
Dec 18, 2007 | HP DeskJet 3940 InkJet Photo Printer
Red is printing pink.
have u used this printer quite a bit....? if so the following may be the problem and I just did run across this recently in a printer we had in the shop....I recently read in one of my technical magazines that there may be a design flaw in the placement of the laser scanners and the openings that protect them....it seems that excess toner dust can readily get in to scanner area and specifically inside the scanner assembly and accumalate on the scanner glass and lens. Just cleaning through the opening in the back of the printer will not eliminate the issue. Machine will have to be disassembled, scanner removed and opened and the glass/lens cleaned with a q-tip....the placement of the fan (behind cartridges, lower right) seems to speed this process up and it usually becomes first notable with the magenta cartridge, seeing as it is at the bottom of the printer closest to the fan. Hope this helps..
Inkworks
Oct 04, 2007 | HP Color LaserJet 2600n Printer
Epson Stylus CX7800 All-In-One InkJet Printer Logo
50 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
