Question about ASUS P5PE-VM Motherboard
Monitor connection where does one connect a monitor (VGA) to an asus M4A79T deluxe motherboard?
    Guru:
  • 352 Answers
The Asus M4A79T does not have video built onto the motherboard. You will need to get a seperate video card.
Posted on Apr 29, 2010
    President:
  • 1,146 Answers
Hi:
You need to install a Graphics card , because this board does not have on board video!
I have a new case and a new ASUS E35M1-I motherboard. I believe all connections are properly connected. Yet, when I plug in my monitor (an Acer X203H) with a VGA cable and turn the computer, everything...
Hello stevenellerd,
Welcome, and thank you for using FixYa!
I will begin by saying, this will be a very in-depth fix that will be beyond FixYa! posts.
Start by pulling out your RAM and putting it back in again. Then do the same with the processor and video card(s).
If the issue continues: email me at defsheppard@hotmail.com for further diagnostics and assistance.
Have a great day!
Sep 09, 2011 | ASUS E35M1I DELUXE Motherboard...
No display
Tell me if you can see anything on the monitor while the pc is booting/starting.Is your monitor connected correctly ?Is your monitor operating well with other PC?
This motherboard you have has an onboard VGA card. Check if you have a PCIex VGA card connected on the motheroard.
In case you have one then deactivate the onboard one through the bios and connect your monitor to the PCIex one.If you dont have an external PCIex card thenGive me more details if you want me to help you.
Sep 04, 2011 | ASUS P5KPL-AM SE Motherboard
Where on my motherboard do I plug in the 2 fans that came unplugged while cleaning?
Here is a detailed layout for the fans for your motherboard:
This is a part from page 52 from the Asus manual.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Mar 07, 2011 | ASUS M4A79T Deluxe - Motherboard - ATX -...
I have a asus p5sd2-vm motherboard and i disabled the internal vga card by mistake and now i have no image displayed on my screen. when u boot it beeps like 5 times. pls help , thnks.
Disconnect the monitor from the motherboard and shut it down. Open the case, find the battery and remove it for 5 minutes. Put it back, connect the monitor and boot normally.
Aug 26, 2010 | ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA...
When I press the power button of my CPU i hear 3 Continuous beeps which repeats thrice. Again the beeps come during the windows login. This beep was not there in the begining. It started recently. But...
It is true that your computer is working properly without any trouble.Three continuous beeps means that your keyboard component is not ready to input the data.That's why it is calling you as beeps.You might have to check your keyboard that it is attached with the CPU properly or not.
Apr 06, 2010 | ASUS M4A79 Deluxe Motherboard
When i added a video card.. and restarted my pc. a blue screen appears... saying "overun"?? what is the problem??
well did you check weather the video card came with a VGA pin where you can connect the monitor signal cable if not , connect the monitor signal cable to the video card VGA out socket.
good luck
Jan 05, 2010 | ASUS P4S800-MX Motherboard
When powering on get no input to monitor board nu a7n8x-e
Make sure you have connected into the correct video port. DVI should be used for LCD monitors and VGA should be used for CRT monitors. Since both ports look the same people often get confused. Try it and let me know.
Sai.
Jan 02, 2010 | ASUS A7N8X-E Deluxe NForce 2 Ultra 400...
I want to connect my monitor to my computer but no vga port
hi !
- you can buy a dongle that will allow you to have a vga port.
-another way to connect the monitor is you have to buy a video card with the vga port.
thanks
Oct 20, 2009 | ASUS P4P800 SE (890552603657) Motherboard
NO DVI or VGA SIGNAL to MONITOR
Disconnect all devices from the power supply EXCEPT the motherboard
Remove any extra cards including video etc.(plug monitor into the onboard)
If you hear any beeps these can indictate where the fault is.
either of these sites below will help you further with that
Beep codes Pc
More beep codes
Power up the pc and see if the fans are working.
If not then double check the power connections to the board.
If you still have no fans it is time to suspect the power supply as the probable cause.
If the fans worked then you should have gotten a display which told you there was an error and offering you a chance to go into the BIOS. ignore it and shut down the PC.
Now connect one drive only and boot again.
Repeat that until you identify the component that is giving you a problem.
Once you find the problem then remove or disconnect and carry on with the rest to see if another component might also cause a problem
If there is only one problem device then you may want to investigate that device further, Unless you don't mind replacing it
Oct 02, 2009 | ASUS K8N4-E Deluxe Motherboard
VGA
hey
first check ur motherboard have builtin VGA or not. If its builtin vga first disabled the builtin and then install ur ATI vga card on ur AGP or PCI slot it will automatically detects and ask u to install the driver for it
Feb 24, 2008 | ASUS K8V SE DELUXE,...
ASUS P5PE-VM Motherboard Logo
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
