Question about Canon PIXMA MP470 All-in-One Printer
The printer won't print it just feeds the paper through. Then paper stopped midway, I removed it and now error code 5100 is showing. Any suggestions? I have pushed reset, nothing. I have turned printer off, unplugged for several minutes, nothing.
    Scholar:
  • 118 Answers
Turn off printer. unplug, replug in, should reset.
go to canons website to troubleshoot.
Posted on Apr 29, 2010
Panasonic KX-P7110 printer won't print from the auto feed tray, shows error when printing is attempted.
Please check the entire length of the paper feed path from input to output for a small piece of paper that is stuck causing a "Paper Jam".
You are lucky that you can still print manually as this usually shuts a printer down until the jam is found and removed!
Good Luck!
Rich Lilja
Jan 06, 2014 | Panasonic KX Office Equipment & Supplies
Error message: Service error 5100 on my Canon MP160 Printer
The main reason of Canon Printer error code 5100 If you receive Canon printer error code 5100 message this means you need to reset the printer. This also signifies that your computer does not recognize the printer. Your printer will show this error code because the LED is blinking. If your PC does not recognized the printer then it will also affect your printing jobs and you will not be able to do any printing work.
When the error code 5100 appears in your Canon multi functional printer then the Printer LED light will blink. This also means that you need to reset your printer. You must fix this error as quickly as possible. For instant technical support please contact Canon Printer Technical Support.
Tips to Resolve Error Code 5100
  • The Canon printer will show error code 5100 to warn the user that there is some problem.
  • In order to fix the problem, you require to opens the top of the printer.
  • In the right side of the printer you need to search for the waste ink absorber pad.
  • The next step is to clean the waste ink absorber compartment with a paper or cloth. This also completes the resetting process of the printer.
  • Inspect the paper feed area of the printer and confirm that there are no obstructions or paper jams in the printer that may be responsible for the error.
Dial our toll-free number +1-800-213-8289 for quick online assistance for resolving technical issues relating to the Canon printers. Our Canon Printer Support Number service is available for fixing technical glitches of our customers. Please get in touch with our tech support team and will receive online remote technical help at highly reasonable charges.
Our Epson printer support technicians are always ready to sort out each and every printer related issue with latest solutions offered to its clients. We are a team of fastest printer tech support solution provider for every issues related to all printers such as Software installation issues, Driver Upgrade, Change Printer ink, Printer Spooler and Paper Jam issues etc. If users are unable to solve this problem, they are welcome to drop us an e-mail and we promise to get back to them in short time span via our professional printer contact details. So, come and join us for tom experience our exceptional level printer solutions to your unexpected and critical issues. And also our Canon printer technical support technicians are always ready to sort out each and every printer technical issues with instant solution. We also provide instant remote support for Brother Printer technical support services for your common printer errors such as Software installation issues, Driver Upgrade, Change Printer ink, Printer Spooler and Paper Jam issues etc.
How to Fix Error Code 5100 in Canon Multi functional Printers
Jul 06, 2011 | Canon PIXMA MP150 All-In-One InkJet...
My HP Laserject 5100 Printer has the Paper Jam Problem. After that, I check printer. But i haven't seen any paper jam. When i print out, nothing show on paper and show the paper jam.. How to fix?
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Jul 04, 2011 | HP LaserJet 5100 Printer
I have got error 5100 what does this mean
Hello
Error code 5100 describes a physical problem either with a paper jam or an incorrectly seated ink tank. Resolving the error is a quick process that only requires a few standard troubleshooting procedures.
Press down and hold the "On/Off" button, which is located on the printer's operator panel, for one second. Wait 15 seconds and then tap the button again. Attempt to print or scan a document.
Check the paper feed tray on the front end of the Canon printer to see if there is any paper visibly stuck inside the printer. Open the printer cover by gripping the front edge of the printer and lifting upwards.
Grab the edge of the jammed paper and gently pull towards you to remove the paper from the paper feeder. Unplug the Canon's power cable and USB cable, and then turn the printer around.
Pull off the rear plastic cover tab and check if there is any visible paper jam. Grab the edge of the paper and gently pull toward you until the paper is removed.
Push the rear plastic cover tab back into place, and reconnect the power cable and USB cable. Attempt to print or scan another document to see if the error is resolved.
Lift open the printer's cover again and wait for the ink carriage to slide into view. Press the "Push" button on the front of the first ink tank. Pull the tank out and then push it back into place to ensure it is properly seated.
Repeat the process with the other three ink tanks, and then close the printer's cover. Power the printer off and then back on again.
But in some other canon printers,Error code 5100 indicates that the waste ink absorber has reached maximum capacity. The Canon i860 printer uses the waste ink absorber to keep ink residue off the printer heads and internal printer components. To resolve this error code, the waste ink absorber must be cleaned out and the error code message needs to be reset.
Open the top of the printer.
Locate the waste ink absorber pad on the right side of the inside of the printer. Grasp the pad and pull up to remove.
Take the waste ink absorber pad to a sink. Run warm water over the pad and wring it out to clean it. Wring the excess water out when done cleaning.
Clean the waste ink absorber compartment with a tissue or cloth.
Set the waste ink absorber pad on a dry paper towel or clean cloth to dry.
When the pad is dry, place it back into it's compartment in the printer.
Close the top of the printer.
Press and hold the "Resume" button on the printer. Press and hold the "Power" button while holding down "Resume."
Release the "Resume" button. Press "Resume" twice. The indicator light will turn amber followed by green.
Release the "Power" button.
Press the "Resume" button four times
Press the "Power" button. The error code is now reset.
Nov 13, 2010 | Canon Office Equipment & Supplies
At first the paper would feed through then when the 2nd paper fed through i get the msg that there is a paper jam. Now as soon as you turn the printer on it gives me the error code 5100
Hi You can Try
for most canon this error code is
Error Code 5100
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
All The Best: Pineworks
Sep 27, 2009 | Canon PIXMA MP470 All-in-One Printer
MP830 5100 Error
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 07, 2009 | Canon PIXMA MP830 All-In-One InkJet...
MP500:not snecing or feeding paper
I just asked a question. Where do I find any answers?
Jun 20, 2008 | Canon Pixma MP500 All-In-One InkJet...
Error 5100
  1. check the user manual if you had one for that error code,
  2. and I suspect the ink level of your printer,
  3. and also check if there is any paper jam exist,
  4. disconnect the power source for 2 mins and turn on again.
  5. try to print again.
Apr 01, 2008 | Canon PIXMA MP510 All-In-One InkJet...
Error code 5100 shows onscreen and there are no comments in guidebook
move ink tank to right and turn of then turn on, found in another canon printer fix it.
Jan 28, 2008 | Canon PIXMA MX700 All-In-One InkJet...
Pixma mp460 error 5100
this error is an error within the printer. This error means that there is something obstructing the printing process. Check inside your printer through the gears that you can see under the lid. There should be something obstructing the gears such as dirt or in my case popcorn. There was even some paper caught underneath the rollers that I had to jiggle around to even see. Check VERY thoroughly.
Oct 19, 2007 | Brother HL-2040 Laser Printer
Canon PIXMA MP470 All-in-One Printer Logo
153 people viewed this question
old marine
old marine
