Question about Troy-Bilt 4-Cycle Curve Shaft Gas String Trimmer #41ADT41C966
Troybilt TB475SS manual - Troy-Bilt 4-Cycle Curve Shaft Gas String Trimmer #41ADT41C966
Model TB425CS WHAT IS SPARK PLUG GAP
Al, .025" is the plug gap for your trimmer,page 20 in your manual. There may be a recall on your model to do with safety.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://lawnandgarden.manualsonline.com/manuals/mfg/troybilt/tb475ss.html
Troy Bilt Model TB425CS Parts
Troy Bilt String Trimmer Sold at Lowe Recalled for Laceration Hazard
May 15, 2016 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
I am in need of an owners manual .pdf for a troybilt 6000W generator model 030475A
Wiring diagram (link below) and a link to Troy Manuals PDF Manual Web Archive - requires serial number to access
A good site for manuals or seeking of Free User Manuals and Owners Guides ManualsOnline com
Dec 11, 2014 | Garden
Troy Bilt log splitter need service manual
Go to this site and have your model # and other information handy. http://www.troybilt.com/webapp/wcs/stores/servlet/OperatorManualPartFinderView?storeId=10001&catalogId=14102&langId=-1&cm_mmc=Google-_-Parts-_-TroyBilt-_-[troybilt]&gclid=Cj0KEQjwyrqgBRDepamt-LWA2oABEiQAV7nwwKjZz1RgjRxVsOYa18PA4DFXXYgrE3YRcIRqxtG8hZsaAq6O8P8HAQ
Sep 09, 2014 | Garden
I have a Troy Bilt 4 cycle trimmer, TB475SS. The small fuel line in the gas tank has come off. I is about 6" long with a filter at the end. The trimmer can not **** any gas. How can I reattach it...
i would suggest to change all you fuel lines. troybilt uses specific fuel lines that they sell. you cant use your regular tygon fuel lines.
Sep 23, 2011 | Troy Garden
I need troy-bilt trimmer TB90BC engine schematic or manual for model# 41BDT90C711
you should be able to find the manual for the trimmer from their web site... you need both the model number and serial number to get the manual. i'll put the address you need below
Canada
http://www.troybilt.ca/troybilt/troybilt_manual_search.asp
US
Hope that helps
Aug 27, 2011 | Troy Garden
I need a owners manuel for a troybilt lawn mower
For Troy-Built USA, use this link and submit your model number and serial number to find and download your manual:
http://manuals.mtdproducts.com/mtd/Public.do?BrandCode=10001
For Troy-Built Canada, use this link and submit your model and serial number to find and download your manual:
All other countries use this page and find the applicable website or email address then go to the applicable website or email the contact point:
http://www.troybilt.ca/troybilt/contact-world.asp
Thanks for choosing FixYa,
Kelly
Oct 04, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Troybilt Shredder/Vac Manual
Try looking at www.precisionope.com. If you can not find a manual, At least you can find an Illustrated parts list and diagrams.
Sep 29, 2009 | Troy-Bilt Heavy Machinery
Troybilt 4 cycle trimmer (TB475ss) won't start. New tank, new plug, new gas??? Will occasionally start, run for about 10-15 secs, then stops. Won't restart. Help!
Take the plastic cover off that covers the muffler and cylinder head. I've had 2 cylinder heads crack. The trimmer still ran but had little to no power and would not throttle up. First head cracked at the head bolts. The second one cracked above the bolts. The side that has the carb and fuel tank is harder to see and you must remove the carb and fuel tank to check. Also I've read online that this trimmer has a problem with the fuel line cracking at the bulb and in the tank.
Sep 12, 2009 | Garden
Engine manual for troybilt tb 144 mini tiller
Below are a few links that might prove useful. The first two are operators, and shop manuals for the 144. I briefly looked through them and they have engine related info. The third is just an exploded view of the engine.
Hope this helps.
http://lawnandgarden.manualsonline.com/manuals/mfg/troybilt/tb144_1.html
http://lawnandgarden.manualsonline.com/manuals/mfg/troybilt/4cycle.html
http://www.partstree.com/parts/?lc=troy_bilt&mn=21AA144R966+TB144+Cultivator+%282006%29&dn=769021900001
Sep 11, 2009 | Troy Bilt Tiller/Edger 26cc, Model No....
Troy-Bilt 4-Cycle Curve Shaft Gas String Trimmer #41ADT41C966 Logo
407 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
