My kenmore Oasis He top load washer is showing an F51 code. what does this mean?
  • Washing Mach... Master
  • 8,220 Answers
Problem: F then 51 flashes when there is a motor rotor position sensor.(RPS) failure. my kenmore Oasis He top load washer is showing an - 0587a5c.jpg
Cause: suds. The wrong detergent or the wrong amount of detergent, makes the motor overheat.
Why? When suds are detected the program needs to make them go away for fear the clothes won't be clean. So the program makes the motor do extra work to try and fix the problem. The poor washer motor gets worked to death because the water ain't right.
Posted on Apr 29, 2010
What does a flashing F51 code mean?
Dump the appliance. sears delivers the worst garbage available
Mar 22, 2016 | Kenmore Elite Oasis 27052 Top Load Washer
My kenmore elite oasis he top load washer keeps stopping in the wash cycle, beeps and flashes a code F51...what does this mean?
from what i can find out it apears to be the rotor position sensor which seem to be a common fault it apears you need a new board to fix the problem
Aug 14, 2011 | Kenmore Washing Machines
F51 problem
f51 code is the tachometer rps sensor saying that the drum is not spinning at proper speed usually means something is stuck between the inner and outer tub
Jan 23, 2011 | Kenmore Oasis HE 27082 Top Load Washer
What does the error code F51 mean on the kenmore elite oasis he?
The F51 error code indicates that the control is not sensing proper motor movement through the signals from the RPS (rotor position sensor) circuit. This can be caused by several different problems. Make sure that you are not overloading the washer. Overloading can cause this problem. A toy or foreign object could be under the washer that is interfering with motor rotation. With the washer empty, spin the basket inside the washer tub to see if it spins relatively easily. If not, you could an item caught between the spin basket and the tub. You could have a wire harness problem causing signals to not be transmitted properly between the RPS and the machine control board. A failed RPS sensor or a failed control board could also cause this problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Aug 04, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
F1 & F51 error on my Kenmore Elite Oasis HE washer
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Good news for Oasis F-51 sufferers! Sears will replace the electronic control board (the F51 prob) for free, in warranty or not. Serial #s for the bad board are: CS48 - CS52 or CT01-CT49. Call Sears at 800-847-9083.
You hv to rate me ‘very helpful’, or the call won’t get thru!!
Feb 08, 2010 | Kenmore Oasis HE 27082 Top Load Washer
In mid wash the Kenmore Elite Oasis HE flashes F51 and
check if basket turns freely. if it does replace the main board
Jan 28, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
What does f51 code on a kenmore oasis mean
Dec 02, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Error F51 for Kenmore Elite Oasis Toploading washer??
bad main board or motor possitioner sensor.. most likely motor sensor.
China made junk parts with a million problems
Nov 21, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Washing Machines Logo
116 people viewed this question
Top Washing Machines Experts
