Related Tags:
This problem should be removed because:
Problem with Garmin Quest GPS Receiver
Quest Battery Problem
My Garmin Quest will not operate on the internal battery, as long as it is connected to either an AC source or a DC power source it operates perfectly but it will not even acknowledge that you have pressed the power button when not connected. I have opened it up and the battery is connected and when it is turned off but connected to the AC power source the charging symbol appears on the screen. I would say the battery is bad but in light of the fact that this is a 20 hour battery I would suggest that normally a bad battery will hold enough energy to at least start up the unit, it may not operate for long but you would think it would at least start. The battery is a Samsung brand and it has the number IA1X424H2 on the front as well as 3.7v 970mAH, is there a replacement battery available??
jdunique@embarqmail.com
Garmin Quest 2 GPS
Cannot find a replacement battery for this unit.
"Detail maps Don't Support Routing"...
May I know how to resolve the bricked Garmin Quest with Error message "Detail maps Don't Support Routing". It happened after I...
My Garmin Quest displays...detail maps don't
My Garmin Quest displays...detail maps don't support routing.The position of my vehicle is shown slightly to the left of the roads I am...
garmin quest batteries
Add Your Solution
garmin quest beeps when I turn it on.
the screen stays black and I can only turn it off buy holding on and in buttons
Unable to activate a pre loaded route on Garmin...
When trying to activate a pre loaded route, the screen turns blue and "Drawing" is dispayed. This is were it...
we ahve been given Garmin Quest and need...
I need manual and in car lead
could you convert my my gps, this is brazil...
I could not fix my gps to my computer,it's brazil standard i would like to convert to new zealand standard.could you...
Fix-O-Meter
5,943
5,943 people viewed this problem
- 16 people found this problem to be helpful.
- 0 people are following this problem. Be the first!
Top Garmin GPS Device Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
I had close to the same problem. My Garmin Quest would not work with any type of power supply, truck or home office. I opened the Quest up and removed the battery and now it will work either the home office power supply or truck power supply.
