Question about Dishwashers
I have a Frigidaire dishwasher Model #that GLD2445RF alw ays leaves grit on the dishes. The heating element in the bottom of the unit is grey with a powdery substance flaking off of it. Does it need to be replaced? Can a novice do this, or is it time to spend the $50 for a service call? I've had it 13 months.
  • Anonymous Jun 11, 2008
    I have the EXACT same problem! The grit is whitish grey and there appears to be a coating inside the dishes (mostly on top rack). The heating element on the bottom is coated with a hard whitish grey substance that is CHIPPING off. Is it from our hard water? What can we do? Thanks
    President:
  • 2,651 Answers
Figures just outta warr. if you have a meter you can remove the lower panel of d/w and depend on the model the heater wire connections are right there either on the left or right , you can see them from within the tub which end they will be on. a simple continuity teat will determine if its good or not, if you have continuity unit is good if not replace the heater. t hold down screws and wires, thinking you can handle it
Posted on Mar 25, 2008
SOURCE:
Frigidaire diswasher not drying dishes properly
Make sure you have the heated dry setting selected, use rinse aid at all times, and make sure the unit is getting hot. If it is not, or there is no steam generated when you open the unit after cycle - have a professional diagnose the heating element.
Aug 01, 2012 | Frigidaire Dishwashers
My frigidaire dishwasher model # FDB4315LFCO, is ending the wash cycle with the dishes dripping wet, what might be the problem?
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Aug 14, 2011 | Frigidaire Dishwashers
Whirlpool dish washer leaves grit and dirt on dishes.
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
Dishwasher Residue and Film on Dishes
heatman101
Asker
May 03, 2011 | Whirlpool Dishwashers
Frigidaire Dishwasher Model GLD4355RFS0 Will not sanitize and leaves dishes wet ?
One common issue on these units is the heater wire will fall off. If this happens, the dishwasher will not heat. Also make sure the rinse agent is full. On most of the newer dishwasher rinse agent must be used to help dry the dishes.
Appliance & Refrigerator Repair
Mar 23, 2011 | Frigidaire Dishwashers
Have dishwasher does not dry dishes fully top rack wet bottom rack semi dry heat ring on bottom is rough not smooth
A bad heating element causes many problems in dishwashers…
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Aug 31, 2010 | Frigidaire Dishwashers
Grit on clean dishes.
Dishwasher2_bing.gif Problems The Heating Element not Working
http://www.fixya.com/support/r4589033-dishwasher_problems_heating_element_not
Dishwasher2_bing.gif Maintenance
http://www.fixya.com/support/r4319937-dishwasher_maintenance
heatman101
Asker's Testimonial " expanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Jul 18, 2010 | Maytag 24 in. MDBH940AWS Built-in...
Disherwasher seems to run ok but dishes do not come clean and it leaves a soapy resdiue on dishes
You may have a problem with your heating element...if the water isn't staying hot the dishwasher will not work well...
Check out this tip and the there are others at the bottom of that one...
heatman101
Apr 19, 2010 | Frigidaire 24 in. FDB1050RE Built-in...
Our glasses don't rinse clean. This is a Frigidaire FDB750RCS0
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried invain to clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if theheating element goes bad then that also can mess things up bad... So I wouldbuy new spray arms, and also check out the heating element to make sure it isworking... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehowsimple it was. thanks Ronnie " - ronnieshomes
gkj
Aug 15, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Dishes with a lot of water left on them.What's the problem? Heating element?
Yes. if this unit is not drying properly, it will be the result of a failed heating element. make sure you are selecting the correct drying method as well. if its on air, it will have a completely different drying time and attribute. if you are selecting the correct assisted heated drying method and, the dishes are not drying, replace the heating element.
***Using the proper rinse agent will increasing the drying performance as well.
Jul 17, 2009 | Frigidaire GLD2445RF Built-in Dishwasher
Dishwashers Logo
236 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
