Question about Garden
How do I put chain back on the Wen 14'' chain saw
  • 1 more comment
  • noma7054 May 11, 2010
    old electric
    old electric
  • dontbother10
    dontbother10 May 11, 2010
    Old electric or new gas? Reply below please.
    Brigadier General:
  • 4,088 Answers
Remove the chain drive side plate and remove the bar. Clean the drive area and inspect the drive sprocket for excessive wear. Run the motor for a short time to make sure that oil is being pumped out to the bar--is should just ooze out. Clean the bar chain groove and clean the oil holes at the drive end of the bar--especially the two small holes that go from the large oil holes out to the chain groove. Back off the chain adjustment screw several turns, then fit the chain over the sprocket (teeth cut toward you on the bottom) and then insert the bar into the chain and push the bar out till the chain is fairly tight. Apply the side cover and make sure the adjustment tang drops into the large hole at the rear of the bar. Install the mounting nut(s) to hold the plate and bar together. When run-up finger tight, turn the adjustment screw CW until the chain becomes tight enough that it doesn't droop from the bar, yet can be be turned by hand. Tighten the side cover nut(s) and recheck tension. If ok, run the saw for a few moments with the bar tip near some cardboard--it should throw off a thin line of oil. Keep the chain properly sharpened to reduce the chance of this occurring again. Hope this helps!
Posted on Apr 29, 2010
    President:
  • 2,220 Answers
Old electric or new gas? Reply below please. I have a source for the Wagner/Wen OM, the new gas saws you need to contact Wen here:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} WenProducts.com
http://wenproducts.com/
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
4 Suggested Answers
  • 583 Answers
SOURCE: Correct replacement chain
take the old chain with you when you go tobuy the new one is the best way
Posted on Aug 25, 2009
Testimonial: "Thank you for your advise, that will help."
  • 4088 Answers
SOURCE: i was using my Remington 14'' limb N' trim chain
First, inspect the chain for bent links or other damage. If ok, loosen the bar mounting nut(s) and turn the tension adjust screw CCW until the chain can be passed over the sprocket, then threaded over the far end of the bar. Make sure the chain cuts toward you on the bottom. Turn the adjusting screw CW until the chain begins to tighten. Proper adjustment is when the lower run of chain doesn't droop from the bar, yet allow easy movement of the chain by hand. Tighten the mounting nut(s) and recheck the chain adjustment. Pay attention to chain droop and readjust as needed during use of the saw. Make sure it is being properly oiled by running the saw in front of a piece of cardboard for several moments--it should throw off a thin line of oil. Hope this helps!
Posted on Mar 21, 2010
wireguy212
  • 1627 Answers
SOURCE: how to put the chain back on a 14" Poulan electric
Remove the cover that cover the rear of the chain bar.Now,loosen the nuts that attach the bar and slide the bar reward.Now set the chain in the slotted part of the bar,pull it forward until there is abut 3/8 of an inch slack in the chain an tighten the nuts.Re-install the cover.
Posted on Sep 12, 2010
Is there a master link
I personally have never seen a master link in a chain for a chain saw. What are you trying to do?
Jul 29, 2014 | Wen 4014 14-Inch 8 Amp Electric Chain Saw
Trouble starting
Remington Pole Saw Carbon Brushes
If you're Remington Pole Saw is slowing down, throwing sparks, or not starting you may need to replace the carbon brushes. Replacing brushes and cleaning commutator early can prevent damage to motor armature!
Remington carbon brushes on E-bay Search for:
Remington Pole Saw 8 AMP Carbon Brush
Apr 19, 2014 | Remington Electric Chain Saw
Chain for wen 14" chain saw cannot find. Other models fit? Thank you
My best advice is to find a lawn and garden shop that services chain saws. Take the chain you have and they can make one just like it.
Aug 30, 2013 | Remington Electric Chain Saw
Wen electric chain saw
take your bar along and compare If all the holes line up then there will be no problems with any bar that is 14''long
Aug 03, 2013 | Garden
Tighten chain on WEN 5041 electric chain shaw?
First loosten that 1/2 bolt on the bar--the lookat the bar when it goes into the housing you will see the adjustment screw.Tighten the chain by turning the screw when you get it to where you want it then tighten the 1/2 inch bolt
Nov 05, 2011 | Electric Chainsaw Sharpener
How to put the chain back on a 14" Poulan electric chain saw
Sep 12, 2010 | Poulan 14 in. 2.0 Peak Horsepower Electric...
I have a 14 inch WEN/Wagner electric chain saw in good condition with the exception of the trigger switch. I have not been able to find a replacement for that small part. Can you help?
Jim it is so long out of production about the only thing available is the OM. If you can get a pn off the original switch Allied or Newark is an option. Maybe a trigger switch from a saw in current production can be modified to fit.
Different model Poulan electric saws follow:
1. http://www.ordertree.com/modelinfo/PWE/1220-Electric-Saw/75.1220-Electric-Saw.1.59.1.html
2. http://www.ordertree.com/modelinfo/PWE/1420-Electric-Saw-Type-2/75.1420-Electric-Saw-Type-2.1.59.1.html
3. http://www.ordertree.com/modelinfo/PWE/1625-Electric-Saw-Type-2/75.1625-Electric-Saw-Type-2.1.59.1.html
“EL-14“ through “ES400” here (5±):
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
A length of spring steel and almost any micro switch might also be an option. Beyond that I am out of ideas.
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Apr 22, 2010 | Remington Electric Chain Saw
Need new chain for wen saw 5014
It is here N;
Oregon Bar & Chain Selector
http://www.oregonchain.com/pro/lookups/selguide.aspx?BusId=OCS&SellReg=USA&LangId=ENG
Select "Wen; 5014; #DriveLinks; All; All; All".
#DriveLinks, the part of the chain that fits in the bar groove. Match the number with the fourth column to get bar length.
The above results are for an original or equivalent bar. Only YOU can determine your level of expertise, how much risk (read the triangular warnings - the OE chain was probably green) you are willing to assume and choose one of part numbers listed. Once you make your choice it can be found on the Internet or through local merchants (no shipping and handling fees). If the local outlet does not handle Oregon your choice can easily be converted to a part number of the manufacturer they do handle. I suggest a few phone calls to save you time and gasoline. Given the Oregon part number and your assurance of a purchase, if my store, your chain would be waiting when you walked in the door.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Apr 02, 2010 | Electric Chainsaw Sharpener
Aug 25, 2009 | Garden
Wen electric chain saw -is it doa?
Are you pressing the trigger lock with your thumb before you pull the trigger? That's a safety feature to prevent accidental sawing.
There's not a sensor for the oil, but you don't want to run the saw dry. It takes a special bar/chain oil which is thicker than motor oil.
FYI... if you look for a manual on the web, search for "Wagner chainsaw" because Wagner bought the chainsaw business from Wen.
Mar 10, 2009 | Electric Chainsaw Sharpener
Garden Logo
195 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
