Teac cr-h255 volume control vr81, what value pot is it, where can i get one from?
Volume control on teac crh250
Make sure the volume knob is tightened to the volume potentiometer shaft via the set screw on the knob itself.
Jun 12, 2016 | Teac Audio Players & Recorders
Looking for spare remote control,or universal remote that would be suitable.
go to e-bay and search for remote for teac cr-h255
you will probably get new ones or 2nd hand units
Jul 22, 2015 | Teac Audio Players & Recorders
Teac cr h255
I think it is a problem related to overheating of the cpu. Question is whether your cpu fan is running. or is it running fast enough, say within 1000rpm. It will go faster if the workload is more. And while installing the cpu did you put some cooling jell/pest right on the back side of the processor. If none of these are applicable I will suggest that that you should contact someone professional asap.
Apr 03, 2014 | Acer Computers & Internet
I hav a Silvertone sslb11 bass that needs a new volume pot and don't know wich one to buy. I don't see any part numbers or values printed on the pot. Does anyone know part numbers, brand, or...
I recommend checking music stores in your area for that, it doesn't have to be any specific rating of impedence. Depending on brand, I see guitars with anything from 50 ohms to 250 ohms. This only allows a faster cutoff on volume than others. The most critical action is to have a smooth taper, meaning a straight volume rise or decline versus one that goes down slowly or quickly and suddenly cuts off. Most any guitar volume control from a music store will work just fine. In case I confused you, ohms is the rating of the control, the taper or smoothness is classed as A, B, or C. A is normally for volume controls and B is used mostly for tone controls. Knowing that should give you insight insight to the difference of the controls.
Mar 31, 2013 | Music
I have a Teac Receiver AG-D9100, sound cuts off, but if I touch the master volume knob it comes on for a short time. What to do? jmf
This can be related to a fault in the potentiometer as it cut off the tracking of the voltage and gets back to feed the digital circuit. You need to check, sometimes a switch cleaning oil can help.
Try to wriggle the pot control many times as it can help, if not replace.
Oct 07, 2011 | Teac AG-D9100 Receiver
The volume control on my bx5a deluxe has a short. It has a "sweet spot" where it will play at one volume level. Do you have a part number or a solution?
part are difficult to find for this unit. I would suggest you take it apart and try to read the value on the volume "pot" and then get a replacement from radio shack parts, just remember to order "audio taper".
Mar 18, 2011 | M-Audio BX5a Speaker
I own a TEAC AG V1020 receiver. One channel keeps cutting out then and back in after a few minutes. When I give the volume control a quick twist louder then back down, the channel returns for a few minutes...
Turn it off and vigorously operate all mechanical controls throughout their ranges many times with special attention paid to any Tape Monitor or other rarely-used controls.
Jan 10, 2011 | Teac AG-V8060 Receiver
Audio volume control problem
Have exactly the same issue, no cure however
Mar 16, 2009 | Audio Players & Recorders
Volume does not work Korg Microkorg Synthesizer with vocoder
You might try to clean it. You can buy some tv tuner cleaner at radio shack. If that fails, then the pot. will have to be replaced. If you can solder and de-solder components its not hard to change out. When you open the unit up, the volume control or POT has a ohm value. Like 200, 250 ect…. It may have a K after it, that’s x 1000. Get the right size ohm value and replace it. Hope this is helpful.
Jan 20, 2009 | Music
My Teac Z-7000 will not record tapes
some weeks ago I got this really impressive deck (Teac Z 7000) from a colleague, and found the same problem. I fixed it, and the fix is not too complicated. It´s the potentiometers that do fail. All pots are from the same manufacturer (Alps) and construction. The problem is that the wisher is broken away from the holding plastic and will loose contact completely. You can check that with a normal ohmmeter: You´ll find the total resistance over the outer terminals but endless resistance from one of the outer terminals to the middle wisher contact. The values are: 100 kOhm linear for each of the upper left pots (fader,space), 2x22kOhm pos.log. for the lower left pot (phone volume). So, what does a broken wisher at the "fade in" pot do? The Recorder "thinks" that You selected an "endless" fade in time, and the result is : no record level. You can do an easy "quick and dirty" fix just to see if that´s the problem: Hold- or better solder- a say 47kOhm resistor in parallel to the conducted potentiometer terminals and try to record.
4 of 5 pots have been defective in my deck, and I´ve replaced them with standard types from my local electronic supplier (Conrad electronic, has a shop in Frankfurt/Main). Well, the new parts didn´t fit perfectly, I used a file to get them in (not visible from outside). Also I lost the possibility of pushing the knobs in and out, but that is not a really problem.
I assume this fix might also help owners of the Teac Z-6000 and Z-5000, which- most probably- use the same type of potentiometers.
This text was written by Boris Witke, Kelsterbach (near Frankfurt/Main), Germany. E-Mail:
witke1@web.de Please tell me if You were successful, possibly we get lucky users of these really fascinating machines.
Mar 08, 2008 | Teac Audio Players & Recorders
63 people viewed this question
 Grubhead
Grubhead
