Question about HP LaserJet 3330 All-In-One Printer
HP 3330 slow PDF Printing
I have a HP 3330 all-in-one. With the (32MB I believe) base memory, it was printing .PDF's slow, so I purchased and installed the 64MB memory upgrade. It still prints .PDF's slowly. I haven't really noticed a difference from before the memory upgrade was installed. Perhaps I installed the printer RAM incorrectly (though it appears to have properly seated, and the two 'lock' bars have seated to the RAM module). Is there anyway to verify from the computer how much RAM the HP 3330 'believes' it has?
Printing from two different laptops via USB- a P4 3.02 Ghz processor with 1.5 GB RAM running Win XP SP2, and Intel 32 Bit Dual Processor 1.8 GHZ, 3 GB Ram, running Win Vista.
When printing .PDF's from both of these laptops to other printers (i.e. Canon i80 and Brother MFC 9040CN), .PDF's print almost instantaneously. I prefer to print from the HP 3330 because the printing costs are lower. Any help is appreciated.
  • 2 more comments
  • pauljen_b Apr 29, 2010
    The report shows that the memory did install properly, at 96MB total with 66MB available. So how do I increase .PDF printing speed -i.e., why does a 60 page .PDF document take 1-2 hours to print (if it prints at all without timing out) vs. 5-10 minutes on the Brother 9040? FYI- Time-out is set to 300 Sec. Resolution is set to 1200 DPI, however the Brother 9040CN's resolution is 600x2400 and has no problem printing the .PDFs quickly.
    Thanks
    The report shows that the memory did install properly, at 96MB total with 66MB available. So how do I increase .PDF printing speed (i.e., why does a 60 page .PDF document take 1-2 hours to print (if it prints at all without timing out) vs. 5-10 minutes on the Brother 9040? FYI- Time-out is set to 300 Sec. Resolution is set to 1200 DPI, however the Brother 9040CN's resolution is 600x2400 and has no problem printing the .PDFs quickly.
    Thanks
    I'll say that I have more of a mystery on my hands at this time. Yesterday, I moved the printer form 1 room to another room in my house. The printer memory upgrade was installed about 2 months ago. I had tried to print several .PDF's since the installation of the printer memory, at the printer's old location, with much frustration and printer lock-up, time-out errors, and power-down power-up sequences (the same problems I was having with printing PDFs before the memory upgrade). I've never had a problem printing any other documents, just .PDFs. Having just recently found Fixya and knowing that I've been experiencing this problem, I decided to post the problem. However, this problem doesn't seem to be occuring this morning... Same Laptop...
    So I'll ponder...
    I did move the printer to a new location yesterday, and hadn't printed any .PDFs since the move... I am using a different USB cable at the new location (long story, won't explain).
    Experiment:
    Printing a tnew location 2 portions of a document that was problematic at the old location even after the printer memory upgrade (i.e., the whole document was 326 pages, and about 2.5 MB's)- and still problematic to print after installation of printer memory 64MB module. Essentially, in old location, document would print very slowly (1-2 minutes per .PDF page), and eventually time-out when it hit the 3rd or 4th .PDF page in a row with more than just text (i.e., a .PDF image of a webpage). So I'll experiment by retrying in the new location.
    Page 1-10 mostly text with the USB cable from the old location, and a different USB cable: - 55 seconds. Sis not select "Print as image"
    Pgs 267-280 (many .PDF web page images) - 3 min 10 Seconds - did not select "print as image"
    Pgs 267-280 (many .PDF web page images) - 11 min 40 Seconds - DID select "print as image"
    These times were about the same for both the old and 'new(different) USB cable.
    I'll respectfully disagree that the problem (whatever it was) was Adobe- I was using the same version of Adobe from the laptop having problems with the HP 3330, but not the Canon i80 or Brother MFC 9040CN- so the only variables were the usb cable and the printer itself (in a different location than the HP 3330 old location). And it is of course the same version of adobe I'm using for this experiment at the new location. I've since ruled out the USB cable (see above experiment).
    The old location didn't seem to have any electromagnetic sources of interference, or any other apparent environmental factors that would seem to affect printing speeds. And the same computer was used each time (in the old location, and the new one).
    Who knows. But it seems to now be printing .PDF's much better in the new location- and FYI, there were never problems printing non-PDF's as non-PDF's always printed fine (15 or so PPM).
    I did learn valuable info, like how to print the config page (and that my printer has printed nearly 30,000 pgs of info!). Thanks again...
  • pauljen_b Apr 30, 2010
    So I'll ponder...
    Experiment:
  • 355 Answers
Printing a configuration should show the amount of memory installed in the machine. Here are the instructions on printing the configuration page.
To test the printer, use the following steps:
  1. On the printer’s control panel, press MENU/ENTER.
  2. Use the < or > button to select Reports and press MENU/ENTER.
  3. Use the < or > button to select Config Report and press MENU/ENTER.
A configuration page prints, showing the printer’s current configuration and the control panel display returns to Ready .
Posted on Apr 29, 2010
  • Shawn DuRee Apr 29, 2010
    The problem is with Adobe. Some pdf files may
    contain damaged images or fonts. I tried their fix and it works. It
    appears below:
    Print as image
    At times, you may encounter
    problems when printing a PDF file. For example, a PDF file can contain
    damaged content such as images or fonts that cannot be rendered by
    Acrobat during the printing process. Choosing Print As Image bypasses
    that rendering operation by sending the printer a rasterized image of
    the document.
    To print as image:
    Open the PDF file in Acrobat.
    Choose File > Print.
    Click Advanced.
    Select Print As Image near the top of the dialog box.
    Click OK, and then click OK again to print.
    The
    Adobe Captivate demonstration below illustrates how to use the Print as
    Image feature. For more information about viewing this demo, see
    Viewing Adobe Captivate Demos in Knowledgebase Documents (TechNote
    kb403894).
My HP LaserJet 4700dtn Printer is really slow, it taking 25 mins to do a 15mb pdf file. I am connected to the printer via a USB cable. How can i speed it up.? it has 256mb memory.
More details, what kind of document are you printing, what format, what driver, what software are you printing from. If you are printing full page color photographs those can take a long time to print. Make sure all updates for software and firmware of printer is up to date as well.
Dec 14, 2016 | HP LaserJet Office Equipment & Supplies
Memory low message on hp laserjet pro 200
see HP LaserJet Pro Printers Memory is Low message displayed on the control...
HP LaserJet Pro Printers - 'Memory is Low' message displayed on the control panel HP LaserJet Pro - Troubleshoot 20.xx (memory failure) and 21.xx (print failure) error messages (ID: emr_na-c05049204)
HP Customer Support page and ensure the printer is running the latest available firmware. Print a Configuration Report from the control panel of the printer to check the installed firmware version.
  • If the printer supports expandable memory, you can install additional memory in the form of a DIMM. Check the printer's User Guide to see if it supports additional memory.
  • Break complex print jobs into smaller jobs that contain fewer pages.
  • If the printer is an MFP, delete stored faxes to increase available memory. Go to this document for instructions: HP LaserJet Pro MFP - Delete faxes from memory (ID: emr_na-c03264743)
  • Power cycle the printer to delete stored fonts or macros. It is possible to download fonts or macros in a way that power cycling the printer will not delete them; see Appendix A - Memory Allocation.
  • Changing some software and/or print driver settings might result in a less complex print job.
  • Use a different print driver. For example, a PostScript print driver will typically result in a more complex print file. If possible, try sending the file with a PCL6 or UPD printer driver.
  • Adobe PDF files can sometimes be very complex. Go to this document if printing PDF files is slow or resulting in memory out messages: HP LaserJet - Print job is slow or hangs in the print queue when printing Adobe PDF files (ID: emr_na-c04071740)
  • If the printer is connected via a network, try sending the file connected by USB cable only. This will eliminate possible network issues that are taking printer memory.
  • Appendix A
    Memory Allocation Utilities or jobs that you download to the product sometimes include resources (for example, fonts, macros, or patterns). Resources that are internally marked as permanent remain in the product memory until you turn the product off.
    Use the following guidelines if you use the page description language (PDL) ability to mark resources as permanent. For technical details, see an appropriate PDL reference for PCL or PS.
    • Mark resources as permanent only when it is absolutely necessary that they remain in memory while the product is turned on.
    • Send permanent resources to the product only at the beginning of a print job and not while the product is printing.
    NOTE: Overusing permanent resources or downloading them while the product is printing might affect product performance or the ability to print complex pages.
    Sep 08, 2016 | HP LaserJet Office Equipment & Supplies
    Ricoh printer performance is extremely slow when printing PDF intense drawings
    Needs more RAM memory to process the print job faster. If the Printer has upgradeable memory, you can speed it up. Crucial.com sells memory for HP printers, so they may have ricoh as well.
    Apr 21, 2012 | Ricoh Office Equipment & Supplies
    Hi We have just recently bought secondhand-age
    RAM RAM RAM...Thats the key here, Your Printer needs more RAM your PC needs more Ram... As much as you can fit in both. You see a Print job must be spooled, the only place it can, fast enough, is in RAM Memory, so if you have BIG files you need heaps of RAM especially in the printer, thats why it can take 32MB RAM, see? To "Print" a MB of data... you may need up to a triple that of scratch space.
    Feb 04, 2010 | HP DESIGNJET 500 InkJet Plotter Printer
    Printer mispick and how to solve it? I tried to open the door to take paper out, but left a little piece there I believe since the paper was broken. Now, I can not print anything and can not find any piece...
    Clearing a paper jam - (or leftover bits of paper)
    The LJ 3380 may be shown in this tutorial from HP: (do not try any disassembly other than opening the product doors as suggested in this tutorial)
    HP LaserJet 3330 Clear Paper Jams
    If this info is helpful, please vote.
    Dec 29, 2009 | HP LaserJet 3330 All-In-One Printer
    HP Laserjet 3330 printed dark page especially around the middle
    Does this happen both when copying and printing?
    For printing solution, try another toner cartridge.
    If lines continue to appear when copying (primarily through the automatic feeder) then lift the auto feeder, and clean the glass -mainly the narrow piece on the left side.
    please rate solution :)
    Apr 07, 2009 | HP LaserJet 3330 All-In-One Printer
    HP Laserjet 1200 prints pdf documents slow
    I had the same problem for printing pdf documents too slow with HP Laserjet 1200 :
    Here's the fix: Open a pdf document go to File > Print> Advanced> check the box Print as image, use 300 DPI...that should do it.
    CHEERS AND VISIT //dentaltourism.rs
    Feb 18, 2009 | HP LaserJet 1220 Printer
    HP 3330 Scanner is very slow
    PDF files are notoriously slow to print. You might invest in more printer memory.
    Jan 16, 2009 | HP LaserJet 3330 All-In-One Printer
    What kind of SC memory card do I need to get for a Toshiba PDR-3330 digital still camera?
    The manual says, "SD Memory Cards having the following storage capacity can be used on your camera (Toshiba PDR-3330):
    8MB, 16MB, 32MB, 64MB, 128MB, and 256MB"
    Aug 22, 2008 | Toshiba PDR-3330 Digital Camera
    HP LaserJet 3330 All-In-One Printer Logo
    383 people viewed this question
    Ben Johnson
    mukhtar21 shaikh
    mukhtar21 shaikh
