Question about Sony CDX-L480X CD Player
How to wire the power conections - Sony CDX-L480X CD Player
    Scholar:
  • 84 Answers
If your car doen't have a factory harness that you can grab power (+) and ground (-). you can run one wire from the battery (fused 10-15amp) and connect that to the yellow wire on the sony. Then find a fuse in your glove box (preferably the cigarette lighter fuse) that send power when the key turns to ignition (fuse that also) then hook that wire up to the red wire coming out of the sony. As for the black wire coming out the back, find the closest bare metal behind your dash and use a self-tapping screw to secure the wire to that. If you do have a harness behind your dash you can normally get all those wire in that harness (saves a lot of time).
Posted on Apr 29, 2010
I need wiring for pioneer gm 3000 amp?
Here is the pinout. You need to solder your own connections.
Oct 15, 2014 | Pioneer Gm-3000t Car Amplifier
No power or ground wire for after market radio?
there is a fuse for the radio in the fuse box, if your power was ripped out , find the radio fuse and make a new conection from there
ground can be made conecting to any metalic part of the car
Nov 07, 2017 | 1999 Saturn SL
No power to the fuel pump
Follow the pumps wire back and @ each conector check for power with a DMM The conections can look like new but may not make a proper conection. also tug on the wires @ the connectors they may have corroded off just inside the plug case
Sep 24, 2012 | 2000 Chevrolet Silverado 1500
1998 gmc jimmy power mirrors will not work. fuse ok and replaced switch as it has power coming to it. any ideas?
check motor in mirrors for power,rember power travels battery+ to switch then to mirrors threw wires and conections there maybe a relay in the middel,then to earth threw panels or wires,if there algood maybe its the motors,,,but its rare to have both go at the same time
Aug 14, 2011 | 1998 GMC Jimmy
The replacement switch has 4 wire ports marked L,1,2,3. The fan has a black wire (power) and 3 other wires from a plastic capacitor box, 1 green and 2 brown. How do the wired connect to the switch?
dear sir
try to find out first all wire wich type of you shold use ampere meter for testing thise wire .
ampere meter turn into continuty mode and conecect its one lead (wire cable) to your motors black wire and watch the display what is rating there .and write it next wire check and date write like this way check your all 4 wire and now who is high number data its conect to number 1 after that some low conecet number to switch number 2 after that who is lowest conect to number 3 and that black colour wire conect to the L mark then try to start your motor
hope answer the question
thank you
Jul 09, 2010 | Westinghouse Electric Westinghouse...
New starter good batt. no voltage at the starter not even a click
Have to do some trouble-shooting first. With no click at all means their is no power comming from the key switch to the starter or no earth (-) to the starter.How to check power from the key switch. Look at your starter motor wiring their should be a main batery wire conected to it and more wires to the same conection. Then their should be one small wire connected to a different connector on the starter this is the power wire from the key switch. To check if this is the problem remove it then get a long piece of wire which will reach from the starter to the battery. Conect one end to the connector on the starter then touch the other end to the positive (+) pole of the battery. When you touch it to the battery you should hear a click and the starter will turn the engine. If it does then you will have to check the ignition system starting with the fuse then relay and key switch, It could also be a coroded connection or a broken wire in the wire loom, Check the earth if you get no click when you touch the wire to the battery. Follow the large wire from the (-) pole of the battery to the engine make sure all connections are tight and corosion free. To double check get a jumper cable clamp one to the - neg. of the battery and the other end to the engine (large bolt or metal) do not conect it to any pulleys (alternator etc.), This should get you sorted but if not let me know what you have tried and I will help further.
Jun 15, 2010 | 1993 Mitsubishi 3000GT
Conecting to my pc computer with my psp
you can download with the PSP using wifi and don't need a lead to connect to the pc
Jul 31, 2009 | Sony PlayStation Portable (PSP) Console
Wire conection problem-no manual
Black is obviously ground. red is for switched power (only has power when vehicle is on) single yellow or orange is constant power Dual grey and dual white (solid grey/grey with black) and dual etc. are for speakers. the blue is for accessory power for amps and eq's. on the speaker wires the one with markings is for + and the soild is for -.
May 16, 2009 | Jensen MCD-9424RC CD Player
Thermostat wiring
your best bet and where i would start is to identify where the coulors are conected at the fernace. in the industry we use standard wireing coulors wher green is g for fan and red is rh=switched trans power for heating . rc=switched transformer power for cooling . now normaly there is only one transormer so you would put a jumper from rc to rh and conect the red wire from the furnace to eather of these.jumper installed. the y is your cooling witch is normaly the yellow wire. o on the stat is for a heat pump if you nead to energize reversing valve in cooling mode . w is first stage heating and this can be conected to eather brown or white youll have to check at the furnace to see witch it is . the final wire eather brown or white should be conected to c or 24v common witch you didnt say you see on the thermostat. once again
red to rc and rh
green to g
yellow to y
brown or white to w
brown or white to common or c
please post feadback hope i was of help
Oct 19, 2008 | Heating & Cooling
Conect power
U MUST HAVE SPECIAL WIRE HARNESS FROM SONY SYSTEM
Aug 20, 2008 | Sony XVM-H65 6.5 in. Car Monitor
Sony CDX-L480X CD Player Logo
93 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
