Question about Kenmore Washing Machines
How do you replace the lid switch on a kenmore washer?
How do you replace the lid switch?
    President:
  • 1,937 Answers
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Look at the components for the cabinet and you should see how the lid switch connects.
See the following for how to release the console and cabinet.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=0aa21f615646bf86ea4aeb0c118b7e8b
Also see the Whirlpool / Kenmore Service Manual for top load direct drive washers:
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Posted on Apr 29, 2010
How can I order and replace the lid switch on a kenmore washer 110?
There are numerous videos on Youtube which will show you step by step how to replace the lid switch. Just type "Kenmore Lid Switch Replacement" in the Youtube search box
May 06, 2014 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore Washer 70 series Model #110.22722100 won't spin
Check door switch: If the lid switch is bad it will not drain or spin. Try this test: With lid open let it finish wash cycle. Press lid switch down with screwdriver. Washer should begin draining. Release switch. Motor should stop. Press switch a second time. Washer should start spinning as it continues to drain. If motor doesn't come on while lid switch is pressed, replace the switch. OR
http://www.youtube.com/watch?v=q942xn_2VXY
Click if helped.
Feb 25, 2013 | Washing Machines
Kenmore washer front load 417 wont spin
Click if helped
Feb 18, 2013 | Kenmore 24032\24036 Top Load Washer
Kenmore washer lid switch problem
Good day,
Common problem, Change the switch, and make sure if it is the model with a plunger for the switch mounted on the lid, that that be replaced as well.
Thank you for using FixYa
Dec 29, 2009 | Washing Machines
How do I acces the lid switch on my kenmore washer
The following link explains step-by-step how to access and/or replace the lid switch on a Kenmore top loader:
http://www.fixya.com/support/r385198-replacing_lid_switch
Most lid switches are located under the right hand side of the top panel. Some, are located adjacent to either lid hinge. In any case, you still need to remove the washer exterior case to access it. The switch is held in place with a couple of mounting screws with a ground wire attached. This is a very simple repair, but if you experience any difficutlies please let me know. I hop this helps you.
Nov 27, 2009 | Kenmore 24032\24036 Top Load Washer
Lid switch on a 20802 kenmore washer
Check the video at the following link and see if it is of assistance to you in changing out the lid switch. Sure hope so and best wishes.
http://www.youtube.com/watch?v=fC8SY3cU1Yc&feature=PlayList&p=A8EAB62928245279&playnext=1&playnext_from=PL&index=61
Sep 25, 2009 | Kenmore 24032\24036 Top Load Washer
I HAVE A KENMORE 90 SERIES WASHER JUST REPLACED
it mounts to the metal where the lid closes, not on the drum... there's usually two holes where the screws go through... and a third hole where the actuator(plastic post) on the lid goes through to activate the lid switch...
Kenmore washing machine 80 Series 110 20802 990 Will not agitate or spin"
You need to replace the Kenmore Washer Lid Switch. I had the same problem so being lazy I would just push down on the washer's lid and it would push the lid switch further down. making the water drain. after a while I just replaced the lid switch.
Apr 22, 2009 | Washing Machines
Help with Kenmore washer
most often the lid swtch is out of alignment, less often the switch fails
with the lid open examine the underside of the lid for the plastic 'tooth' that is supposed to engage the switch, if broken or missing replace, test
with the lid open and the washer turned on, use a ballpoint pen to engage the switch plate in the hole at the right side of the lid
If the washer starts, adjust the switch position, test
If the washer does not start
remove the edge trims from the console
remove the screws from the lower corners of the console
slide consloe forward ~1/2 inch, flip up and over
ensure cable is connected to lid switch connector
try lid switch again with ball pen
if washer does not start the switch has failed,
remove metal retainer clips from rear of washer top, remember installed position, you have to put them back
lift washer case 1 inch slide forward, lay down, remove switch
replace
reassemble in reverse order, test
3-5 times a month, takes about 25 minutes, the switch costs $7.95+tax
Aug 02, 2008 | Kenmore 15864/15862 Top Load Washer
Washing Machines Logo
50 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
