Central air conditioning blowing out hot, not
Central air conditioning blowing out warm, not cold, air
  • 674 Answers
Can you tell if your outside unit is running (the fan and compressor)? Sometimes it is hard to hear the compressor for the fan. If they are running then you possibly have a low refrigerant charge and need to have some added. Refrigerant pressures and temps can be checked to verify this. If they are not running then you need to find out why. If both the fan and compressor are not running then first make sure all the breakers and disconnects are closed. Then a bad contactor or capacitor could be the problem. If its just the compressor that's not running then it could still be the capacitor or maybe the compressor.
Posted on Apr 29, 2010
Testimonial: "Thanks, this is very helpful."
Passenger side blows cold air--what part could it be
2001 Chevy Tahoe Heat Problem - Tahoe Forum
www.tahoeforum.com > ... > Technical Discussions
Dec 5, 2008 - 10 posts - ‎7 authors 2001 Tahoe, the front heater blows a little hot air when the car warms up and then blows cold air. The rear heat seems to work fine. I changed ...
Rear AC blows hot air - Tahoe Forum - Chevy Tahoe Forum
Jul 14, 2008 - 10 posts - ‎5 authors
On my wifes 03' Yukon the rear air conditioning blows hot air no .... Pull the panel off and look at the hot/cold actuator shown in the picture.
Oct 30, 2015 | 2001 Chevrolet Tahoe
Everstar portable air conditioning model number
check for dirty condenser coil the condenser hot air will be very very hot more than 30 degrees higher than what is going in
Sep 12, 2014 | Heating & Cooling
Ac is not blowing cold air but holding refridgerant The condenser line is cold at first and blows cold but then get warm
the blend door could be open a bit or half way, meaning it is not closing the hot air. you have hot air and cold air at the same time.
Aug 06, 2013 | Air Conditioning and Heat for...
The heater in my 1999 Land Rover Discovery Series 1 won't blow cold.
As per your problem mentioned.There are few solved help links to troubleshoot these problems.Go through the list and Click the link below:----
Air conditioner blows air but not cold air http://repairhelpcenter.blogspot.in/2012/07/air-conditioner-blows-air-but-not-cold.html
Car overheats and Air blows hot at idle? http://howtobyme.blogspot.com/2011/11/car-overheats-and-air-blows-hot-at-idle.html
Heater blows cold? http://schematicsdiagram.blogspot.in/2012/02/heater-blows-cold.html
Heat blows cold on drivers side and hot on passenger side? http://schematicsdiagram.blogspot.com/2011/12/heat-blows-cold-on-drivers-side-and-hot.html---------- Hot air on the driver's side vents only? http://repairhelpcenter.blogspot.com/2012/01/hot-air-on-drivers-side-vents-only.html
2005 Chrysler PT Cruiser: A/C Blows Warm? http://whoisbyme.blogspot.in/2012/06/2005-chrysler-pt-cruiser-ac-blows-warm.html
1992 Toyota Camry: A/C Control light Flashing and A/C not Blowing Cold? http://technoanswers.blogspot.in/2012/04/1992-toyota-camry-ac-control-light.html
No heat, blower blows only cold? http://technoanswers.blogspot.in/2012/02/no-heatblower-blows-only-cold.html
These will help.
Thanks.
Nov 22, 2012 | Cars & Trucks
1998 taurus windows keep fogging up. a/c blows cold then warm
make sure your heater core is in good condition this could be done with a compression test, if that is fine i would make sure the climate control switch is working proper and not shorting between cold and hot
Oct 15, 2012 | 1998 Ford Taurus
2001 Beetle (Non - Air Conditioned) 1.6L petrol. European Model.
add some r12 if still not working check antifreeze level if still full then check the relay fuse for the fan temp blower
Jul 10, 2010 | Volkswagen New Beetle Cars & Trucks
Central air conditioning system is blowing warm air.
many, many. Is the outside unit running? If it is, is the compressor running? Feel the refrigerant lines leaving the unit. Little one should be warm. Big one should be cold, probably sweating.
Jul 08, 2010 | Ruud UAPA042 Air Conditioner
2003 Ford Explorer XLT Air Conditioning vents blow hot and cold
It sounds like the control motor switching from hot to cold is stuck halfway in between the two temp settings. You will have to take it down and replace it, it is mounted under dash passenger side near the blower motor.
Sep 09, 2009 | 1996 Ford Explorer
CHRYSLER TOWN & COUNTRY 2003 HEATER PROBLEM
Have you checked the coolant level? If it's low, it will result in diminished heat, and could be the problem.
Mar 20, 2009 | 2003 Chrysler Town & Country
Central air conditioning unit
the large tube. it should be very cold
and the high side should be very warm but not hot.
if very hot you are leaking and low on freon.
Jun 04, 2008 | Whirlwind FH-778 Air Conditioner
Heating & Cooling Logo
165 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
