Question about Toshiba e-STUDIO 150 All-In-One Laser Printer
My e-Studio 150 is only producing all BLACK pages. At first we thought it was a toner problem (the dotted triangle icon lit up) and so we changed the toner. We got it all up and working. The only thing is that it still produces only and all black pages. Help!
Black pages are usually due to chargeing problems, when you open the right hand cover on the 150 model, the charging unit is located on the bottom of the door that swings open, on the left side of that unit, there are 2 contact springs, those 2 springs contact 2 brass looking tabs inside the machine when closed, clean those tabs, and springs, with a pencil eraser, or a cotton swap with VERY LITTLE rubbing alcohol, or both. The only other thing that would cause black pages would be the scanner light not turning on, which would be obvious, when you open the top cover to place a document on the glass, leave it open and press the copy button, if it lights up, that is not the problem, if the light never turns on, the scanner lamp is out.
Posted on Oct 04, 2010
Konica Minolta 2430 DL has Smudges or dots on page
Not an expert on this brand of printers but it looks like dirty feeder rollers to me. Try cleaning them and Print a Blank document and see if the marks show up
Jan 24, 2014 | Konica Minolta magicolor 2430 DL Laser...
WHAT THE SYMBOLS MEAN
From left to right:
(Lights)
Exclamation point: Error
Weird Monitor beat symbol: Jam
Paper: Out of paper
Toner (Triangle leading down to dot pyramid): Toner refill
Lightbulb: ready
(buttons)
Greenish Play button (square with triangle): Continue
Red button with x: Stop/Cancel
Dell 2230 User Guide Page 1
Mar 27, 2013 | Dell 2230d Laser Printer
Consistent dots down print
Try to print clean page ,
Print a cleaning page During the printing process, paper, toner, and dust particles can accumulate inside the printer and can cause print quality issues such as toner specks or spatter, smears, streaks, lines or repeating marks. Follow these steps to clean the printer's paper path.
  1. Load copier-grade paper (not bond, heavy, or rough paper).
  2. On the printer's control panel, touch the Menu button.
  3. Touch Configure Device .
  4. Touch Print Quality .
  5. Touch Process Cleaning Page .
A Cleaning message appears on the printer control panel display while the cleaning is taking place. The cleaning process takes a few minutes to complete. Do not turn the printer off until the cleaning process has finished. A page will be printed when the task is complete. Discard the page. You might need to repeat the cleaning process to thoroughly clean the printer. Print a few more pages to see if the problem is resolved.
Mar 20, 2013 | HP LaserJet 5550DN Printer
A warning light that is a triangle made up of dots with an arrow pointing down on top of them has lit up. What does this mean?
This is your add toner indicator. It means you need to change out the toner cartridge.
Thank You for using Fixya.
Apr 04, 2011 | Office Equipment & Supplies
I have a problem when u use copier. there are red icon in triangle. how to fix that.. .plz help me.
Normally the symbols indicated require attention some times a triangle with little dots in the triangle need to have the waste toner emptied from machine hope this helps you it depends what is being shown in the triangle a zig zag with may be two circles in the triangle would be like jammed paper needs to be removed
Feb 25, 2011 | Sharp AR-M205 Copier
What does the dotted triangle mean?
On most sharp copiers the dotted triangle that points up is Toner and if it has a triangle that points down that is Waste Bottle
May 13, 2010 | Sharp AL-1457 Black and White Copier
Poor print quality
The "ghost" image is "burned" onto the drum.
A laser printer is supposed to charge specific "dots" on the drum, and the toner-ink is supposed to stick only to those "dots", the paper is pressed against the drum, and then the "fuser" uses heat to "melt" the toner-ink onto the paper, to produce the printed page.
You need to replace the drum.
Apr 07, 2010 | Konica Minolta magicolor 2430 DL Laser...
On the main display the icon of a triangle of dots has lit up in red. what does this mean? thanks
Your TD cartridge is coming to end of life, time to order a new one but dont replace it until the icon changes to a blinking one
Sep 09, 2009 | Sharp AL-1553 All-In-One Laser Printer
Toshiba e studio 150 problem
1-The unit that the toner goes in is probably not filling up with the toner or the unit has a problem. open copier take out drum unit and look at the unit where the toner goes into, there is a black roller with toner on it, is there a spot that seems to be missing toner? If yes it will require a tech too complicated to do for a non- tech.
2- If not, look at the black roller on the bottom of the drum unit is there toner there? clean and try.
Nov 19, 2007 | Toshiba e-Studio150 Copier
Black spots on my documents Brother HL-1440
Stray dots (on a vertical imaginary line on the page) may not require an expensive drum replacement. In my situation, I simply followed these steps:
(1) Open up the printer, remove the toner-cartridge/drum assembly, and remove the toner cartridge from the drum.
(2) For purposes of reference, place (and center) a sample page of the "offending" output in the bottom of the drum housing, lining up the dots so that the page is turned the way it would have fed through the printer, placing the page generally in front of the shiny green roller surface. Loo, for where any matching black dot or other thing might be sitting on that surface.
(3) Gently roll the green surface's roller with its outside end pegs (without touching the green surface) if and until such a matching dot (or dots) can be found. (Multiple dots might appear along other imaginary verticals on the page, which is to say, additional vertical striping is occurring because there are more instances of "items/dots/garbage" arrayed across the roller on the horizontal, to produce repeat images down the page as the page feeds through the printer.)
(4) Take a Q-tip and very, very, very gently "polish" away the dot(s) you found on the green roller. (I ended up just dabbing the dot I found--which had consistently left a trail of three dots down my pages, in different locations because of the distance the roller traveled relative to the page size--using the absolute least amount moisture to remove it.)
(5) Clean the drum's corona wire by moving the blue plastic slider back and forth, and leave the slider at the far left point.
(6) Reassemble the toner cartridge and the drum and place the assembly back in the printer.
(7) Test.
Worked great for me. Done in around five minutes. No cost, except for the negligible cost of a Q-tip. No time waiting for a new drum to show up, etc.
Oct 17, 2007 | Brother HL 1440 Laser Printer
Toshiba e-STUDIO 150 All-In-One Laser Printer Logo
64 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
