Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
What causes the ice cubes in my ice maker fused
What causes the ice cubes in my KitchenAid Superba ice maker fused into a big block of ice?
    President:
  • 1,218 Answers
Good day,
If the temperature in the freezer is good and consistent, then it is the dual water valve on the rear of the machine, that is not shutting off properly.
The system turns the water valve on for 7 seconds just before the ice maker parks waiting for the next harvest cycle.
Many times the valve will be too slow in closing or continues to dribble even though no power is being applied to it, thus causing the well of the ice maker to overfill and overflow.
Replacement of the water valve is the only solution and is a very common problem.
Posted on Apr 29, 2010
Testimonial: "Short, direct, well explained, and an unambiguous solution! Thanks"
  • swaltner2009 Jan 03, 2011
    Now how do you replace the water valve? Is there a free manual online that can be downloaded? Where is the best place to purchase the new valve? I am having the same problem. Thx.
  • John Hall Jan 05, 2011
    The valve is located in the rear bottom of the machine. Simple nuts and bolts replacement.
    You will have to shut the water supply from the house before performing the repair.
    Any decent sized appliance parts house will carry the valve. Take the complete model number of the machine with you or remove the valve and take it in. This is easy work with normal hand tools.
Icemaker not working...
Hi, first , pour about 2/3 cup of water into the ice maker . If if freezes , and dumps , replace the water valve. If it does not dump the cubes , replace the ice maker. After pouring the water into the ice maker , remove the bottom kick panel , and clean the bottom coils , of dust , lint , pet hair , etc , as this will raise the freezer temp . An ice maker has to be 5 degrees , to operate , correctly . If ice maker starts working , after cleaning the coils , GREAT ! ( it does happen ) .
Take care
May 28, 2010 | KitchenAid Superba KSRG25FK Side by Side...
Try filling ice maker with tap water and let freeze. If it dumps and does not refill with water the dual water control valve is at fault. If the ice maker just sits there full of ice and does not move then the ice maker and possible thermal fuse in red wire of the ice maker harness has blown. Let me know what you find, Sea Breeze
Apr 18, 2010 | KitchenAid Superba KSRG25FK Side by Side...
Kscs25fkss00 superba - water not flowing to icemaker but water dispenser works - there is not ice blocking line/tray
Most times that is caused by the dual water control valve on rear of the refrigerator. You can test the ice maker by filling with water and letting it freeze. If the ice drops then the valve is the problem. If the ice does not drop then the ice maker is were the problem is, Thanks, Sea Breeze
Nov 16, 2009 | KitchenAid Superba Architect KSCS25INSS...
Ice maker is frozen in a kitchen aid side by side
Try pouring HOT water into the ice molds to release the frozen cubes. Hopefully the ice maker will restart the cycle and get back to normal!
Apr 09, 2009 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid Superba Architect KSCS25INSS - Ice Maker not working
I have the exact same problem. If you figure out what happened, and why we are not getting any ice, please let me know. I can be reached by e-mail at Hengels@ameritech.net. I would greatly appreciate any assistance you can offer to get the ice maker working again.
Thank You in Advance,
Tom
Sep 12, 2008 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid side by side model ksrs25ikss01
CHECK YOU SECOND VALVE IS WORKING IF THATS OK YOU MIGHT NEED YOUR ICE MAKER CHECKED AND SERVICED.GOODLUCK.MOHAMED
Sep 06, 2008 | KitchenAid Superba Architect KSCS25INSS...
No ice
The refrigerator has a duel water valve, one for the ice-maker and one for the water dispenser (if equipped). The valve that the ice-maker relies on may be bad, or it could be the ice-maker itself.
Another thing that could cause it would be the temperatures in the freezer. The ice-maker will not call for water until it reaches under 15 degrees. In addition, check the water tube behind the ice-maker to make sure it is not frozen, blocking more water from entering. The water does not go to the ice-maker or thru the filter unless the ice-maker turns on the water valve.
Jun 23, 2008 | KitchenAid Superba Architect KSCS25INSS...
No Ice From Kitchen Aid
Mark, your water valve has screwed the pooch. Replace it. The part number is 2199838.
What's happening is this... the valve that fills your ice maker is by-passing a small amount of water. This water has to flow through that tube, right? When very small amounts (drop by drop) go through the IM fill tube, they flash freeze. Eventually they (the frozen drops of water) form a big block of ice inside the fill tube. This ice creates a blockage which creates back-pressure whenever the IM "calls" for water. The back pressure eventually blows the tube off of the connection behind the fridge.
You say that this happened over night... no way. If you look closely at the ice cubes that you IM has been making, you'll see that they are hollow. Hollow cubes means that your IM isn't getting enough water... (because the fill tube is blocked).
Tracy
Mar 15, 2008 | KitchenAid Superba Architect KSCS25INSS...
Kitchen Aid Ice maker Stopped working
The ice maker has stopped working. The red led light blinks when the freezer door is opened. Any thoughts?
Nov 22, 2007 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid superba KSRG22FKSS01 Ice cube switch trouble
Since its an indoor ice maker its much harder to diagnose. However the motor is supposed to reverse for crushed/cubed so you can hold the freezer door switch and see if it does. If it doesnt reverse it could be the switch, or it could be a mechanical problem inside the blades (check for broken stationary blades)
Oct 18, 2007 | KitchenAid KSRS25IL Side by Side...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
434 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
