Question about Sharp R-22GT Microwave Oven
MODEL E23GT-F 240 VOLT SHARP M/W
OVEN SHOWS EE2 ERROR CODE AFTER ABOUT 15 SECONDS OF COOKING,IT CONTINUES TO END OF TIME SET AND SEEMS TO BE HEATING.I HAVE A 10 DEGREE CELCIUS RISE IN TEMP FOR 1 MINUTE, WITH 1 LITER OF WATER.I AM NOT FAMILAR WITH SHARP OVENS.I SERVICE MOSTLY HOBART AND AMANA.
  • 3,051 Answers
Hello there
this is tbirdfan1 here is a pict of the megatron for you
MODEL E23GT-F  240 VOLT SHARP M/W - f01aa88.gif
Posted on Apr 29, 2010
  • Michael Thomas
    Michael Thomas Apr 29, 2010
    1. UNPLUG the oven.
    2. DISCHARGE ALL HIGH-VOLTAGE CAPACITORS. (Procedure)
    3. Disconnect the high-voltage lead from the transformer's
      high-voltage terminal (or tap).
    4. With an ohmmeter set to the lowest resistance scale, R X 1,
      measure the resistance from the high-voltage terminal to the transformer
      chassis (ground).
      1. Some early models are equipped with two or
        three high-voltage taps. If this is the case, perform the measurement
        from each tap to chassis ground.
    5. The meter should read about 55 to 70 ohms, depending on
      which high-voltage tap is being measured and the model being tested.
      1. A substantially higher or lower reading
        would indicate that the transformer is defective.
    6. Carefully disconnect the leads from the primary (input)
      terminals
    7. Measure from one transformer primary terminal to the other
      for a normal reading of less than 1 ohm (i.e., .22 ohms)
      1. A substantially higher reading would
        indicate that the primary winding is open.
    8. Set the meter to its highest resistance scale and check
      from each transformer primary terminal to the transformer chassis
      (ground) for a normal reading of infinity (open circuit).
      1. Any measurement of resistance would
        indicate some degree of a short to ground
    9. Set the meter back to its lowest resistance scale. Then
      carefully disconnect the filament leads and measure from one filament
      terminal to the other for a normal resistance of less than 1 ohm.
    10. Set the meter to its highest scale and measure from each
      filament terminal to chassis ground for a normal reading of infinity
      (open circuit).
      1. Any measurement that is substantially
        different from the normal readings would indicate a defective
        transformer.
  • Michael Thomas
    How To Test the
    High Voltage Rectifier (Diode) Used In Commercial & Residential
    Microwave Ovens
    Excerpt from the
    renowned
    e-Book, The Complete
    Microwave Oven Service Handbook: Operation, Maintenance,
    Troubleshooting and Repair
    on CD-ROM
    © 1996-2009 J. Carlton Gallawa
    . All Rights Reserved Worldwide
    IMPORTANT
    SAFETY INFORMATION: Microwave ovens
    are among the most dangerous appliances to work on. Before attempting
    any troubleshooting, testing or repairs, for your personal safety,
    we strongly urge you to carefully read the very important safety precautions
    found by clicking
    here
    and Please read our disclaimer
    at the bottom of this page.
    The high-voltage
    rectifier
    (diode) works along with the high-voltage
    capacitor
    to effectively double the
    already-high voltage that is provided by the power transformer. This
    powerful voltage, about 3000 - 5000 volts DC (depending on the model),
    is applied to the magnetron tube, causing it to produce the microwave
    energy that cooks the food.
    Testing the HV diode requires an ohm meter with at least a 6
    volt battery in order to accurately measure the front to back resistance
    of the diode. Meters with insufficient battery power may read infinite
    resistance (open) in each direction, mistakenly showing a good diode as
    being open.
    However, the following resistance tests will
    conclusively reveal a diode that is shorted. In most cases, defective
    diodes, whether shorted or open, will show some physical signs of the
    defect, such as a burned crack, a blistered spot, or it may even be
    split in two. Also, a shorted diode will usually give off a pungent
    electrical burning odor.
    Before making this or any other test:
How to fix EE2 on Sharp r-23GT-f commercial microwave
EE2 error means there is a defect in the circuit that runs magnetron #2.
A similar service manual which may help you is here.
You can order Sharp microwave parts from Encompass here or you can call them toll-free at 866-779-5835.
Dec 25, 2012 | Microwave Ovens
Sharp convection microwave oven model R1875F. It's cooking on the left side faster then the rest of the oven. It seems to burn on the left side and not cook in the middle.
see the next causes. God bless you
Diode The high voltage diode converts the A/C power output of the transformer to D/C, doubling the voltage to nearly 5,000 volts. This high voltage powers the magnetron which emits the energy that cooks the food. If the diode burns out, a lower A/C voltage reaches the magnetron, which is not sufficient to power the magnetron. When the diode fails it is often visibly burned out. If it appears to be good, it can be tested with a volt-Ohm meter capable of testing diodes. High voltage diodes frequently fail and are one of the most common points of failure in a microwave oven.
Door Switch If the microwave does not heat, one of the door switches might be defective. Microwave ovens normally have three door switches, if any of them fail the microwave does not turn on and does not heat. Check the switches for continuity with an Ohm meter.
Magnetron If the microwave oven doesn't heat the magnetron tube might have burned out. The magnetron uses high voltage, high current DC power to generate the microwave frequency that cooks the food. If the microwave oven is turned on when it is empty this can cause the magnetron to burn out. Once it is burned out it has to be replaced, it's not repairable.
High Voltage Capacitor If the microwave doesn't heat the high voltage capacitor might be defective. The high voltage capacitor works with the high voltage diode to convert the output of the transformer to DC voltage and to double the output voltage. If the capacitor is burned out the entire high voltage circuit stops working properly. The high voltage capacitor can be checked with a special VOM meter which has a capacitance testing capability. Be aware that the high voltage capacitor can retain a charge of more than 3,000 volts and can injure or kill a person if not handled properly. Only trained technicians should perform this type of testing.
High Voltage Transformer If the microwave does not heat, the high voltage transformer might be burned out. Microwave ovens produce a very high voltage in order to power the magnetron antenna, which emits the energy that cooks the food.
Thermal Fuse If the microwave doesn't heat the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Thermoprotector If the microwave doesn't heat the thermoprotector may have tripped. This is a safety device to prevent the microwave from overheating. It can be tested for continuity to see if it's blown.
Main Control Board If the microwave doesn't heat the main control board may be defective. This is not common. When a microwave doesn't heat the problem is usually within the high voltage circuit; either the high voltage capacitor, diode, transformer or magnetron.
Oct 03, 2012 | Sharp R-1870 Convection/Microwave Oven
Sharp RCD2200M error code ee2
this mean shortes thermistor you must replace, but before you must test with VOM.
see the video .God bless you
Jul 10, 2012 | Sharp RCD2200M Microwave Oven
I have a sharp microwave sometimes it works for 10 or 20 seconds and then stops with error ee2, other times it works fine. Today it did the same but stopped with error ee1!
This sounds like a keypad problem, sometimes a short developes in the keypad controller causing all kinds of intermittent problems, on the back is the microprocessor circuit board which controls vital areas of the microwave oven. The cost to repair will be high and consideration should given to looking at a replacement.
Feb 17, 2011 | Microwave Ovens
Error code -FS- on display with 3 long beeps
Hello :
Shorted humidity sensor, will occur if humidity sensor is detected as being shorted continuously over 5 seconds you need to replace humidity sensor .
good luck .
please rate !
Mar 28, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I have a 15 year old Toshiba microwave which I may need to replace. It can be set to cook in single seconds (eg for 23 or 38 seconds) a facility I find essential. Many new microwaves it seems can only be...
I believe the dial on Hobart microwaves allows you to manually enter any amount of time by spinning the dial for the desired time, and programmable buttons to save the time settings. HL1600 is 1.5 cubic foot, 44 liters
Feb 11, 2010 | LG LMVM1935 Convection/Microwave Oven
The microwave screen says EE2
The fault code "EE2" on a Sharp commercial microwave oven means that the magnetron 2 circuit has a problem and is pulling too little or too much current.
It may be the magnetron, high voltage transformer, high voltage diode, wiring, etc.
Since you didn't mention your model number I can't say for sure, but magnetron 2 is usually the lower magnetron in a Sharp.
You can order Sharp commercial microwave parts here.
If you need more help, we may have the service manual for you to download free.
But we would need the model number.
Please note that FixYa is not currently notifying us Experts when Clarification Requests are answered.
So to allow us to help you effectively (at no charge), please post a
NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit and your symptom, "EE2" code.
Dec 25, 2009 | Sharp R-1500 Microwave Oven
New GE Microwave JVM1750DM1BB with F4 error in Sensor cooking
GE
Microwave Fault Codes Failure
Code
Condition Check/Repair F1 Open sensor, will occur below 190F of cavity temperature within 15 minutes after starting convection, combination or roast cook Check oven temperature sensor for continuity. Replace if zero or infinite ohms F2 Shorted thermal sensor, will occur if a shorted thermal sensor is detected continuously over 5 seconds on convection, combination or roast cooking Check oven temperature sensor for continuity. Replace if zero or infinite ohms
Note: It will take a minimum of 5 minutes of convection run time before F1 or F2 code will be displayed if the thermal sensor is shorted or open. F3 Shorted key panel (touch pad), will occur if a shorted key panel is detected continuously over 60 seconds Replace key panel (touch pad) F4 Open humidity sensor, will occur if humidity sensor is detected as being open continuously over 5 seconds Replace humidity sensor F5 Shorted humidity sensor, will occur if humidity sensor is detected as being shorted continuously over 5 seconds Replace humidity sensor F6 Shorted temperature probe, will occur if temperature probe is detected as shorted continuously over 5 seconds Replace temperature probe ProbEe Open temperature probe, will occur if temperature probe is detected open, or not plugged into the receptacle If probe is plugged in and "ProbE" is on display check continuity of the probe with an ohm meter. If zero or infinite ohms, replace it
Feb 08, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Trouble shoot microwave
The first thing to try is a "hard reset". Unplug it from the power line for a minute, plug it back in, set the clock, then try again.
Also, are any other of your electrical items (light bulbs, DVDs, etc.) failing lately? This could indicate improper power line voltage.
Let us know if the hard reset doesn't fix it.
Jul 18, 2008 | Emerson MW8102SS 1100 Watts Microwave Oven
Sharp R-22GT Microwave Oven Logo
299 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
