Question about Jenn-Air JMC7000 Microwave Oven
Sharp R-930CS Microwave
Turntable wont spin
    Sergeant:
  • 247 Answers
Check to see the turntable it is seated properly. Try to spin it by hand. If it moves easily, it is not in the right place.
If seating it properly does not solve the problem, you'll need to take it apart to see what the mechanical problem is caused by.
It could be as simple as a clogged gear. Or it could even be a broken gear or bad motor. A visual inspection should provide clues.
Be careful. Disconnect it from the AC before taking it apart and do not operate the microwave disassembled as microwaves are harmful to humans. It can cook them!
Posted on Mar 25, 2008
SOURCE:
Sharp R-930CS microwave turntable stopped turning and neither convection or microwave are working (ie. not heating). Lights and fan turn on and counter counts down normally.
Look inside for one of many thermal cutouts (button type) test each for continuity (with the unit unplugged of course). Also look for burned wires and repair or replace them. If you get it running and it works fine... we're done. If it still acts up then replace the magnetron and or the capacitor.
Oct 19, 2013 | Sharp Microwave Ovens
Sharp microwave oven model r-403kk carousel wont spin .if you turn power on.
Most likely the turntable motor is faulty and needs to be replaced.
Mar 08, 2012 | Sharp Microwave Ovens
Sharp model r-403kk [ turntable wont spin] lights and keypad are all o.k.
The turntable motor will need to be replaced, gears tend to give out over a period of time.
Mar 08, 2012 | Frigidaire FMV156EM Microwave Oven
Hi - I have a Sharp Carousel w/ Convection R-930CS-F that sounds like it running but is not cooking and the turntable is not rotating. Any ideas? Thanks!
That would be a failed secondary interlock (bottom door switch) or possibly the switches mount.
We have the service manual and have uploaded it to our site here to help you.
Also see this text file on door switches.
Dec 04, 2010 | Microwave Ovens
My microwave door sags to the right from the top hinge. The microwave is a Sharp R-930CS. How do I adjust this?
The only adjustment is by removing the outer cabinet and examining the hinge side will be self explanitary.
Beware that the door must close squarely and if it is very mal adjusted will take out the mains fuse!
Oct 19, 2010 | Sharp R930CS Microwave Oven
Sharp Carousel R-930CS-F Wont heat
CHECK YOUR FUSES. IF GOOD IT MAY BE THE MAGNETRON IS BAD
Apr 17, 2009 | Jenn-Air JMV8000 Microwave Oven
Turn table has stopped working in sharp r-930cs
We have the service manual for that model and have uploaded it to our site for you here.
Chances are the coupler or motor is bad.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
The best place to order Sharp parts is Tritronics.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 16, 2008 | Sharp Microwave Ovens
Jenn-Air JMC7000 Microwave Oven Logo
182 people viewed this question
Top Jenn-Air Microwave Ovens Experts
William Miller
William Miller
Ekse
Are you a Jenn-Air Microwave Oven Expert? Answer questions, earn points and help others
