Question about Kenmore 22422 Top Load Washer
The button that is pushed down when the lid closes is broken
    Top Expert:
  • Kenmore Master
  • 76,109 Answers
Just pry the lid up and replace it, very simple job
Posted on Apr 29, 2010
When I close my lid, pc crashes
Laptop shuts down / crashes after closing lid - used to hibernate ...
en.community.dell.com/support-forums/laptop/f/3518/t/19496556
Dell
Mar 13, 2013 - 16 posts - ‎7 authors
Now shuts down after closing the lid after several hours - at least .... My computer crashes when it goes to sleep regardless of the lid's position. E7440 - sleep Issues and display issues - General ...
Apr 17, 2014
crash after sleep/close lid - General Hardware - Laptop ...
Nov 21, 2012
More results from en.community.dell.com
Laptop Sometimes Crashes When Close Lid to Sleep - Windows
Dec 01, 2015 | ASUS Computers & Internet
Spin cycle
open and close the lid a few inches,do you hear a clicking sound,if not you have a broken lid switch,stick a screw driver into the top hole on the right side and push down,does it click,if it does click with the screw driver,set the timer to spin and then push down on the switch again,if it drains and spins you have a bad lid switch part number 3949247 watch video
http://www.youtube.com/watch?v=V5aW9WkTFhE
if lid switch is good check the pump,if it doesn't drain
Jun 06, 2013 | Roper RAS6233KQ Top Load Washer
Washing machine tub won't spin. The belt is not broken. the last time I have a repair guy out he "reset" by opening and closing the lid a certain number of times and then did something else. Can you tell...
Chances are you have a sticking lid switch.Unplug machine pull one wire off the liod switch and check with an ohm meter if you got one. When the button is pushed down you should get a reading, meaning the needle should move on the dial. If you don;t get a reading replace the lid switch.
Feb 19, 2010 | Washing Machines
The switch that makes it think it's closed is broken.
You are referring to the lid switch. If it's visible, try tightening the screws that hold it to the cabinet (they may be loose and the lid strike can't engage the switch properly). If you can, feel underneath where the lid switch is located and see if it's broken from where it mounts (feels loose). Push the lid switch lever down, if it doesn't "click" or doesn't start the wash, replace the lid switch and you should be good to go.
If you want, post your model number to make sure it's the model I'm thinking of and I can also try and get you the part number for the lid switch.
Mar 05, 2009 | Whirlpool 3.2 cu. ft. Plus Washer
No spin
lid switch sounds like some ge had a plunger type switch operation ck for broken pin on lid that pushes switch lever down ..others had a magnetic type switch magnet on lid front right corner that closed switch on cabinet front corner
Jul 31, 2008 | GE WBSR3140DW Top Load Washer
"Open" written on screen
There is supposed to be a little plastic piece that pushes down a button that tels it that it that the door is closed that plastic piece is broken off. Look for it and glue a little piece of plastic on it, should fix it.
Jun 04, 2008 | Toshiba SD-P1600 Portable DVD Player
Cartridges jammed
Try pressing the "copy" button and then the black "start" button. I did this a couple of times and the printer started working again.
Other people have had success when they open the lid, pull down the gate (to expose the cartridges) and then push in the little button on the left (to fool the printer into thinking the lid is closed). With that button pushed in, try pressing the "copy" button and then the black "start" button. The printer will make some working noises. When you close everything up again, it should work.
May 17, 2008 | Canon Office Equipment & Supplies
Fisher and paykel leak
most likely the actuators are bad. with the unit off push and hold the lock and start buttons, lock first then start, after about 6 seconds the display will flash 188. press the power button, ho will be displayed. push the start button until Ld is displayed. open the drawer in question and push the lock button and watch the lid both sides should go down evenly, push the lock key to move it up and down as needed. push the power button to exit diagnostics. if you notice that the lid doesn't go down evenly or if one side stays up replace the actuators, they come as a pair. call a dealer/servicer to order actuators. make sure to specify top or bottom as there is a difference. hope this helps
Oct 03, 2007 | Fisher and Paykel 23 in. DD603H SS...
Kenmore 22422 Top Load Washer Logo
Sal DeAngelo
fordexpert
Mike Squire
