Question about Philips DVP5990 DVD Player
Disk not ejekt - Philips DVD 5990 - Philips DVP5990 DVD Player
Disc Tray Won't Open on Philips DVD Player Model DVP5990/37: The first thing to try is unplugging and turning the unit upside down and finding the slot near the tray port location. Inside the slot you'll see a white plastic piece with a small tab. Use a small knife or ice pick, etc. to slide the tab toward the far side of the unit. This unlocks the tray and should pop it open about 1/4". Place the unit back right side up and plug back in. Hit the open button and it should either close or open depending on it's current cycle, but it should work unless the drive belt is snapped, for which you'll need to remove the outer cover and fix or replace. I'm told there are no factory replacement belts available yet for these machines, however I've used large O-ring seals in place of belts to fix other models of machines. As far as Philips support for this unit, it stinks. Their live and web help features are now useless because all of these models are now "out of warranty" and they remove detailed support postings from their website and from live help stations as soon as they are out of warranty - just when you need such help. I would not recommend any Philips product, as this is my second Philips unit I've purchased new which had serious problems just after a few uses.
Posted on Jun 14, 2010
    Guru:
  • 1,705 Answers
Disconnect from power.
Take the top off., you should be able to remove the disk then.
Posted on Apr 29, 2010
Yamaha HTR-5990 Audio no longer works
Sorry Michael, you have a problem in the audio amp section of the receiver and unless you know how to troubleshoot solid state electronics, you will need to have this unit serviced by a pro. Good Luck
Jun 21, 2007 | Yamaha HTR-5990 Receiver
Command disk not foud while operating
My suspect is your DVD player has aborted a previous firmware upgrade process. Usually DVD players use firmwares burned on a DVD/CD, the complete process takes a couple of attempts to successfully flash the firmware.
The best way to get the command disk or ROM disks is to check the Philips website's support section for your particular DVD player model. Unfortunately, Philips does not offer command disk / firmware patches for all models.
Last but not least.. take your DVD player to the nearest Philips Customer care. They should be able to fix it.
Mar 04, 2011 | Philips Televison & Video
Where do i find sofeware update for my philips dvp590
USB has audio but I can't get video. I have a DVP 5990.
Feb 25, 2011 | Philips DVP5990 DVD Player
Can't Read Disc
You could try updating the firmware.
Jul 06, 2010 | Philips DVP5990 DVD Player
Unknown disk error on philips dvp 3020
I would guess that it's an incompatible disk format. If your burning software allows you to pick different types check the Philips manual for a compatible format
Mar 06, 2010 | Philips DVP3020 DVD Player
How do you make a philips dvd player model no dvp 5990 region free ???
Philips DVP 5990
How To Make Region Free:
press Setup
select the Preference Tab
Press 1 3 8 9 3 1
Press up/down key to select "0"
and press Setup to exit.
If you can't get into Preferences Tab, you may need to press the stop button twice first, then press setup.
Sep 17, 2009 | Philips DVP5990 DVD Player
"Display connected non-HDCP compliant" error
The HDMI cable was causing "Display connected non-HDCP compliant" error message to appear.
When I reconnected my DVD to TV using regular cable with 3 color connectors(i don't know what is the proper name for that cable) that error message no longer appears on my screen and I was able to watch my movie normally.
May 17, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
What is the remote code for PHILIPS DVP5990
I'm using the GE Universal Remote, and found that the four digit code 0914 worked.
Jan 07, 2009 | Toshiba CT-90157 Remote Control
Philips DVP5990 DVD Player Logo
515 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
