Question about Canon imageCLASS D320 Digital Copier
Copies and prints are very very light. New toner cartridge installed, but it has been on shelf long time. Changed exposure and quality to darken and it didnt work. The bulb is not very bright.
  • 1,219 Answers
You need to clean the optics, including the laser unit, and transfer roller.
Do you have genuine crg or?
If not genuine try with original
Pls. rate
Posted on May 10, 2010
Mysterious fluctuation in quality of copies.
fuser drum is bad. photocopier use electricity to transfer the toner to the paper, then it is heat fused to paper. it appears that the problem is occurring around the time that the toner is attracted to the paper.
Mar 07, 2014 | Canon PC-940 Black and White Copier
I just changed the toner and the printer does not print.
If u have the CD of tht printer , u just delet tht printer from the Devices and printers settings. And re installed it
Aug 14, 2012 | Brother HL-2040 Laser Printer
Printer printing very light copies
Problem Print is too light
Source of trouble Expired toner cartridge
Resolution How old is your cartridge? Did you know that exposure to UV lights can reduce the adhesion of toner dust? You may need a new cartridge. Begin by removing the toner cartridge and vigorously shaking it from side to side, then trying it again. If that doesn't work, check your high voltage setting ,If that fails, get a new cartridge.
Resolution Look for a darkness setting - it may be in the menu system, but there might also be a lever or knob inside of the printer (check your owner's manual). HP conveniently colors these knobs and levers green. This switch regulates the amount of high voltage power that is sent to the laser and influnces the amount of toner that is attracted to the paper. Crank it up. If neither this or a new toner cartridge works, you may be having fuser problems, or need to get a new high voltage unit.
Jan 29, 2011 | Office Equipment & Supplies
Why are my copies coming out solid black, even though my exposure lamp is still working?
A couple of possibilities. Basically if your exposure lamp is coming on, the light is not getting all the way to the drum that is in the toner cartridge. It could be you have a mirror out of place. When the exposure lamp comes on, the light is reflected off the original and then off a series of mirrors until it gets to the drum. If one of the mirrirs has been knocked out of place, like due to a recent cleaning then that would cause black copies. The more common cause would be the drum protection "gate" that is on top of the toner cartridge is closed and thus blocking any light from getting to the drum. You can slide out the toner cartridge and look on top. There is a gate or panel that flips open to be able to see the drum. This gate must be opened when installing the toner. Also it is possible to have a bad cartridge but that rarely causes completely black copies.
Good Luck and Thank You for using Fixya.
Dec 06, 2010 | Canon PC-920 Black and White Copier
New cartridge and prints very light
Ithink you might need a developer change.
May 04, 2010 | Minolta bizhub 200 Copier
How do i change the print cartridge?
Replacing the print cartridge
  1. Open the print cartridge door, and remove the old print cartridge. CAUTION: To prevent damage to the print cartridge, minimize its exposure to direct light by covering it with a sheet of paper. Figure 1: Removing the print cartridge c01174123.jpg
  2. Remove the new print cartridge from the packaging. CAUTION: To prevent damage to the print cartridge, hold the print cartridge at each end.
  3. Pull the tab until all the tape is removed from the cartridge. Put the tab in the print cartridge box to return for recycling. Figure 2: Removing the sealing tape c01211568.jpg
  4. Gently rock the toner cartridge from front to back to distribute the toner evenly inside the cartridge. Figure 3: Shaking the print cartridge c01211569.jpg
  5. Insert the print cartridge in the device and close the print cartridge door. Figure 4: Inserting the print cartridge c01174125.jpg CAUTION: If toner gets on your clothing, wipe it off with a dry cloth and wash the clothing in cold water. Hot water sets toner into the fabric.
NOTE: When toner is low, faded or light areas appear on the printed page. You might be able to temporarily improve print quality by redistributing the toner. To redistribute the toner, remove the cartridge from the device and gently rock it from front to back.
Sep 13, 2009 | HP Office Equipment & Supplies
Minolta copier 1030, changed toner makes no copies
take the toner bottle out. turn off the machine then turn it on with the bottle out. once the machine, ask for toner install the bottle.
Jun 18, 2009 | Konica Minolta Office Equipment & Supplies
Poor quality copies
Hi, this is most likely caused by a worn or faulty drum.
Jan 20, 2009 | Sharp AL 1631 Copier
Light Copies
GO TO PRINTER PROPERTIES--------THEN select the option print quality-------then select the darkess as from thre given list.and after making the changes just click apply/ok.
rate the solution if this helps you.
Dec 17, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Canon imageCLASS D320 Digital Copier Logo
163 people viewed this question
old marine
old marine
