My printer won't print on a full scale.. meaning
My hp deskjetD2300 printer won't print on a full scale.. meaning the edges of paper are still left blank..what do i do?
  • 4,924 Answers
This has to be set from the wizard for the printing job ...look for the edges size..but when you print on paper ..something like a full size A4 image ...it will always leave a 5 mm edge as default setting ..But like I said..initiate printing ..and in that wizard set the edge to 0 or ..click to remove edge if it is possible..anyway if it is possible there is the only location where you can change it ...and I'm not sure if it can be done permanently
Posted on Apr 29, 2010
Can't get small envelopes to print correctly on hp laser jet pro MFP M127fw
Go to printer setting options and choose paper size and font size, according your size choose it. I share a more help full links.
Read More Help...
Scale document to fit on different paper sizes
Resize the page or paper
And HP Printer Support
Thanks,
Aug 27, 2014 | Office Equipment & Supplies
Left edge black on hp laserjet printer
Fuser teflon sleeve got damaged, replace it.. (only professionals can do this activity) if its not available go for new fuser assembly..
Jul 31, 2012 | HP "LaserJet P2035n Printer"
HP 1300 -- toner is smudged along the left edge after crinkly sound
Hi:
This is a common problem with some HP printers. The fuser sleeve inside the fuser assembly gets torn along the edge and print can no longer be fused in that area and the paper will crinkle there. The only solution would be to replace the fuser, which for that printer it would not be worth repairing.
Andrew
Jun 08, 2012 | HP LaserJet 1300 Printer
The printer will print a document but does not put it all on one page. Sometimes it prints part of the document, then sends out a blank page, then prints the remainder of the document on a third page. We...
1. check paper length..... Select proper lengths
2. check printing leading edge, weather its matching to the selected scale?...Clean paper sensor & disc encoder
3. check printed caractors, is there any abnormal caractors?....clean Disc encoder & sensor
3. remove back door clean the paper sensor and check sensor flag
4, clean disc encoder & sensor...
goodluck..
Sep 05, 2011 | HP Deskjet Printer
How do I change the left margin on the printer? I have an internet app that sends the document and I'm unable to change the margins in the internet app.
That's why they are called margins.
You can't print to the edge of the page. The printer physically can't.
Have you tried printing landscape? The other thing to do is set "scaling". That will cause the printer to shrink the page slightly to fit your paper size.
Dec 21, 2010 | HP LaserJet 3050 All-In-One Printer
There was bits of paper, from a stuck edge from a sheet of business cards that I think are perhaps still in the printer. When I print a colour sheet the alignment is off, printing black and white seems OK.
What do you mean by alignment?
If you mean that the colours are misaligned, run a full calibration. Repeat it three times and then try your printing.
If bits of the business cards were left in the printer - it should affect the colour printing as well as B + W. You would also be getting paper jams.
Oct 25, 2010 | HP Color LaserJet 2600n Printer
When trying to print Avery Labels L7160 the top few labels print within each label 'frame' BUT towards the end of the page the labels are printed further up and therefore are out of the label 'frames' ALSO...
For Word 2007/Word 2010
1- Click on the Office button
2- Select Print then Print again.
3- In the Zoom section make sure 'Scale to paper size' is set to 'A4'
4- Click on the Properties button.
5- Click on the Paper / Quality tab, then click on Advanced.
6- In the Paper/ Output section it has Paper size. To the right you have a drop down menu . Make sure A4 is selected and not letter, then click on OK.
3- There may also be other options in your printing preferences such as 'Print Area', 'Scale to Fit Page Size' or 'Page Margins. These will all need to be set correctly for your design to print 100% e.g. Print Area set to Maximum, Scale to fit Page Size disabled and Page Margins set to Minimized.
Some printers ( for example Epson printers ) have a 'Reduce /Enlarge' facility that defaults to 94% or 97% (instead of 100%). To set this to 100% click the 'Layout' tab and in the 'Reduce/Enlarge' section select 'Custom' you should then be able to change the scaling to 100%.
Mar 12, 2010 | HP LaserJet 3050 All-In-One Printer
Printing a full page 'background' (design) with no margins
No. The official minimum print margins are as follows
print margin specifications
Top (leading edge)
Bottom (trailing edge)1
Left
Right
Sheet Paper
U.S. letter
.07 in. (1.8
.46 in. (11.7
.25 in. (6.4
.25 in. (6.4
mm)
mm)
mm)
mm)
U.S. legal
.07 in. (1.8
.46 in. (11.7
.25 in. (6.4
.25 in. (6.4
mm)
mm)
mm)
mm)
U.S. executive
.07 in. (1.8
.46 in. (11.7
.25 in. (6.4
.25 in. (6.4
mm)
mm)
mm)
mm)
ISO A4
.07 in. (1.8
.46 in. (11.7
.13 in. (3.4
.13 in. (3.4
mm)
mm)
mm)
mm)
ISO A5
.07 in. (1.8
.46 in. (11.7
.13 in. (3.4
.13 in. (3.4
mm)
mm)
mm)
mm)
Sep 30, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Printing from InDesign CS3
even if you have the same document size and paper size the printer will not print exactly to edge to edge... so please select scale to fit and check the percentage of scaling if it is more than 95 then your document should look as big as it is desired
Mar 13, 2009 | Epson Stylus Pro 4800 InkJet Printer
I want to change my printer settings to print on the full page, not have these 5mm margins all the way round. can someone help? I have a Kyocera FSC5015N
It sounds like you want to print what is called "full bleed" which means that you print from one edge of the paper to the other edge with no margin. Unfortunately your printer can't do this. It is a limitation of the design of the printer that is common to most laser printers. You have two options, either print with the 5mm margin all the way around and trim the paper or get a printer that has a "full bleed" option.
Henry
Apr 22, 2008 | Office Equipment & Supplies
160 people viewed this question
jasbo
jasbo
