Question about Clavia Nord Stage 88 - Digital Stage Piano NS88
Clavia Nord Stage EX88 dir. in active monitor damage the speakers (tweeter) ? Happened twice with active monitors: Peavey Impulse P1020 and Behringer B-300 Peter ;-)
  • Clavia Master
  • 5,603 Answers
It is VERY easy to send to high a level to speakers.
A few important things:
ALL interconnected equipment MUST be powered from a single point. This avoids ground loops that can set up feedback. Powering monitorss at one end of a room from a receptacle and the synth at the other end of the room is inviting trouble.
REMEMBER that audio sent to the speakers that is causing the damage MAY be well above one's hearing range!
Use BALANCED audio lines where possible. CHECK that in's and out's are compatible, for instance both BALANCED TRS.
Use PROPER cables for interconnecting. Using plain stereo TRS cables for interconnecting TRS balanced lines is a NO-NO... they are cheaper but invite trouble.
If in close proximity to radio transmitters, interference can be a problem due to rectification of the radio signals that can create frequencies beyond the hearing range that can damage speakers.
The starting point is a post mortem on a failed speaker to look for damage.
The Behringer definitely requires a TRS or XLR input. I searched for a user manual online for the Nord but was unable to find one to verify they have a balanced output to run to the monitors.
There is a possibility that a filter in the NORD is NOT working, allowing digitizing noise to be presented on the output audio causing overloading of the tweeter speakers. The best way to check that is with an oscilloscope if you have access to one.
I would turn down the high eq on any active speaker to reduce the signal to the tweeter as an interim step.
Posted on Apr 30, 2010
Hi, I have own a pair of peavey impulse 1012 speakers. One of them has developed a fault in that the output is terribly owful at low volume compared to the other one but an increase in the output from the...
"terribly owful " is not a descripption we can really understand. You need to describe whether the probllem is with the bass or treble speaker... lows/highs... The only suggestion we can give is to open the unit. You will need a LONG phillips screwdriver and remove all the screws in wells around the edges from the back and then gently separate the shell. Inspect for loose wiring. You don
t mention if you are using this as bi-amped or not which we need to know. This unit has the soundguard protection of the tweeter which consists of an automotive type lamp and a polyfuse. I would open the unit and see if there is a problem with the connections or possiblly a socket problem with the lamp as that would disturb the tweeter level. If you are bi-ampong this, then verify that swapping the speakers the problem is the speaker and NOT the cable or amp... Also verify the switch on the back of the speaker is properly set.
Jul 25, 2011 | Peavey Impulse 1012 2Way Molded PA...
On stage live...I want to use the B205D as a personal monitor...the band uses a Yamaha EMX512SC 8 powered mixer on stage...What would be the correct connections to hear only my vocals in the B205D monitor...
Oh my... the EMX512SC does NOT have any "sub busses" there fore there is no way to just hear YOUR vocals where there are other vocal present. The way to connect this is to run YOUR mic into the B205D and then run the line output that is intended to run to other B205D's from the B205D into a channel of the EMX512SC.
Jun 24, 2011 | Behringer Active 150Watt PAMonitor Speaker...
I purchased a PV12M monitor and was wanting help connecting it to my Behringer xenyx 2442fx mixer
You will have to have an amplifeir between them since the PV12M is an unpowered speaker. The Xenyx 2442FX is likewise an unpowered mixer meaning it cannot directely drive a speaker. You will wire with a balanced line (TRS cable) between the 2442 and the amp and then from the amp to the speaker using a speaker type cable.
Jun 06, 2011 | Peavey Pv12m 12' Floor Monitor
Will a Behringer UB2442fx-PRO run 2 main PA speakers plus two passive stage monitors without blowing up?
ALL the speakers will either have to be POWERED or have external amplifiers. The mixer has NO power amps capable of driving speakers. When connecting, make sure that the mixer is powered by the same receptacle as the speakers or amps. Used balanced line for interconnection.
Jan 24, 2011 | Behringer Music
Hi there, I have a Nord Stage EX 76 and played a gig on friday night outdoors. I have set the keyboard up and now one or two of the notes occasionally sound much louder than they should. The problem...
What has happened is that one of the contacts on those notes is not working properly. Each key has two contacts. One makes before the other as the key is pressed. The processor MEASURES the time between those as you hit the key to read the VELOCITY you have hit the key with. This velocity is often used for loudness on many voices such as the piano. These contacts are USUALLY conductive rubber pills suspended in silicone rubber "domes". One can disassemble the key area and clean BOTH the black rubber pills and the circuit traces they are pressed against using Q Tips and ONLY 99% isoprophyl alcohol to restore proper operation
One needs to be very careful when disassembling unit as there are many tender ribbon cables and connectors. Best to have clear work area and two people to "control" the halves of the shell while opening..
Nov 07, 2010 | Clavia Nord Stage 88 - Digital Stage Piano...
The after touch sensitivity on the Nord Stage EX 88 seems to be very low and I need to press down very hard to make the sound that I want with it. Please help.
Here is a link to their support where you can download the latest operating system, manual etc.:http://www.clavia.se/main.asp?tm=Support Consider joining the forum. There are always helpful members who quite likely have experienced some of the same problems. You didn't mention if that happens when you play piano, organ or synth as the setting changes you make can affect each differently. Here is a link to the download page for Windows:http://www.nordkeyboards.com/main.asp?tm=Downloads&cldwn=Nord_Stage_EX&osdwn=osw Here is the one for Mac:http://www.nordkeyboards.com/main.asp?tm=Downloads&cldwn=Nord_Stage_EX&osdwn=osx Pages 61 and 62 of the manual are good starting places. Aftertouch can be assigned to different functions. You will need to read Morph Assign also on page 60. Page 33 explains Velocity Sensitivity which is different from Aftertouch. If the Aftertouch is not giving you enough control over a parameter, try using the Wheel or a pedal for that parameter instead. Here is a link to the manual:http://www.nordkeyboards.com/downloads/manuals/nord%20stage/Nord%20Stage%20EX%20Manual%20v6.x%20%28eng%29.pdf The Factory Reset function is on page 68.
Aug 24, 2010 | Clavia Nord Stage 88 - Digital Stage Piano...
Hi, I would to say thanks a lots to let put some words on yours email box. It's just regarding about how to set up a live band gigs @ outdoor stage in to mixer system. In a mixer setting, i wana know how...
You will need at least a 24 channel mixer to give you spare channels. You also need an active crossover and a snake. The advice you need is too much to include here so I am including some links:http://mixonline.com/live/FixIts/, http://en.wikipedia.org/wiki/Live_sound_mixing, http://mixinglivesound.com/blog/tag/outdoor-concerts/,http://mixinglivesound.com/blog/, and http://www.scribd.com/doc/11435651/Beginners-Guide-to-Mixing-Sound. You may need more monitors than you are planning on and you might consider in ear monitoring.
Aug 22, 2010 | Music
Nord keys not making sound
This will have the weighted keys.
The contacts for the dead keys are dirty and have to be cleaned. This type keyboard is NOT DIY unless you are adept at electronics. The actual contacts are accessable after a lot of dis-assembly.
They are conductive rubber that is pressed against circuit traces on circuit board.
Use ONLY 99% isoprophyl alcohol and QTips to clean both the contact and the circuit traces they press against. Clean ALL the contacts when you have the unit open as others are sure to become inoperative as well.
Jul 20, 2010 | Clavia Nord Stage 88 - Digital Stage Piano...
One of the buttons is sticking on my Nord Stage (the amp button). How can I fix it?
FROM DOCTOR FIX . SPRAY WITH WD 40. THEN CLEAN UP WITH A PAPER TOWEL, ALL SPRAY.
WD 40 IS NOT A OIL, IT IS A STRIPPER.
Jul 07, 2009 | Clavia Nord Stage 88 - Digital Stage Piano...
Using Behringer PMP3000 to power monitors??
Using the mon out and the proper balanced cable follow the instrcutions found in the manual section 61.
Here is a link to the manual.
http://www.behringer.com/EN/downloads/pdf/PMP1000_P0566_M_EN.pdf
Oct 04, 2008 | Behringer Pmp3000 16 Channel Audio Mixer
Clavia Nord Stage 88 - Digital Stage Piano NS88 Logo
199 people viewed this question
Top Clavia Music Experts
Vito Vacirca Jr.
Are you a Clavia Music Expert? Answer questions, earn points and help others
