Question about Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer
My weedeater won't prime. When i press down i see bubbles in the tank but nothing comes up. It's been a few months since i last used it and only used it 3 or 4 times since i bought it.
    Genius:
  • 1,400 Answers
Hello
Sounds like the small prime tubing line may have a pinhole in it.
Try a new piece of tubing,check for a clogged line also.
Posted on Apr 29, 2010
  • Michael Watchorn Aug 10, 2013
    when i push my prime button it won't come back up
2012 Keystone Cougar XLite 32 SAB model... Where is the city water to fresh water tank switch?
feeling air from the pump means that the pump needs priming
Turn on a tap for the pump , prime the pump
if you have damaged the pump seal it will leak at the motor end of the pump
Oct 21, 2017 | Washing Machines
Weedeater starts but won't run for more than 30 seconds
A lot of times the line that in the tank deteriorate so you mean may need to replace the line in the fuel tank
Aug 12, 2014 | Makita Em4251 24.5cc Gas Powered String...
Won stay running
Check carburetor & air filter. Clean off all dirt and clean air filter. check age of gas. Cannot be more than 30 days old. Make sure to use fresh gas w/synthetic 2-cycle oil @ 40:1 ratio (1 gal.) Gas to 3.2 oz. Oil). Do not use old or stale oil/gas mixture. Before putting in fresh fuel, press the primer several times. A small amount of gas might show up in the fuel tank. Remove fuel. With carburetor cleaner, spray carburetor. Put in small amount of fresh fuel. Just enough to cover the fuel filter. Then press primer with fuel cap off, and watch to see if fuel is flowing smoothly. If not or if plastic primer bubble does not come back to original shape after pressing, then you have to take carburetor apart and clean or get new carburetor.
Sep 05, 2013 | Weedeater Gas Blower
Engine on 30"Craftsman 2009 snow thrower won't prime. Primer button and connecting tube look good. Primer button won't send gas to the carb.
the priming bubble can look totally perfect, but all it takes is a pin hole and right around the retaining ring is hard to spot a crack and you should also check fuel lines in tank
Jan 07, 2013 | managemylife.com
Model ut21004 homelite gas weedeater want stay
fuel issue, look for cracks or holes in the two lines from tank to prime bulb, check prime bulb, adjust/clean carburetor, may also need to check filter inside tank it is connected to the bigger of the two hoses. Tim
May 30, 2011 | Homelite Mighty Lite Lawn Trimmer
I have a weedeater model Featherlite 711334 and the gas lines crumbled to nothing. Not sure how the set up was inside the gas tank as to which line goes where and hooked up to what inside the tank.
There are two lines from the tank to the carburator. One picks up gas and fills the prime bulb, the other is a return line. The pickup line should have a filter on the end of it that is in the tank. The other line just dumps back in the tank. Usually the reason these lines deteriorate is because of ethanol in the gas. Make sure you're using ethanol free gas.
Sep 30, 2010 | Weedeater Gas Powered Hedgetrimmer...
Weedeater blower will not prime
The primer bulb sucks fuel from the tank to the carb. When the carb has enough fuel the remainder is sent back to the tank. When you replaced the fuel line did you use the exact length of line and did you re-install the filter. On some of the trimmers the filter is weighted and holds the line in the fuel. Good luck...Lee
Sep 24, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Saeco Magic Deluxe flashing water light, & not draining
The pump could be out or it could just need primed. Saeco sells a cheap hand pump that you insert into the receiver and force water into the system while the pump is pumping. This will often prime the pump and get things going. Call 1 800 933 7876 and tell one of the customer service reps you need a priming pump.
Aug 06, 2007 | Saeco Magic De Luxe Espresso Machine
Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer Logo
743 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Nick Olsen
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
