Question about Briggs Electrical Supplies
Generator starts runs with a miss for a minute or 2 then dies just changed oil and plug checked gas supply was good any idea whats wrong
  • 905 Answers
If you have good spark, clean air filter (replace anyways), try choking it half way or so. If it runs better, then it is running too lean, probably a clogged orifice or jet in the carb. If choking it makes it run worse, then it is likely running too rich. Could be a float problem, or metering tube that is clogged and isn't spraying.
Posted on Jun 12, 2010
I just got a 1994 yz 125 and when i was riding it ,.. it would run good as long as i was going slow and not raping out the gears .. but when i would give it a lot of gas to take off it would bog out and...
if the plug is sooty your float is set wrong the air filter should have oil on it to catch dirt.sounds like a carb problem although it could be the power valve
Aug 24, 2011 | 2003 Yamaha YZ 125
Generator has been running steady for 2 weeks. It will not start now. It has spark, gas is good, oil is good. It is a 5000 coleman powermate electric generator. Did it die due to a 2 week running? It...
if it doesnt turn over how did you test the spark?
if i have read it wrong then always try a new spark plug, these can fail under compression but will spark happily outside the cylinder.
if it wont turn over then it could be siezed or dropped a valve.
Apr 23, 2011 | Coleman Powermate Powermate 5000W...
Honda eb3800x will not start. I started and ran it in June 2010 with no problem. Will not start today 9/2/2010. Checked oil, checked spark plug, drained all gas and put new gas. Carb getting fuel....
the worst thing for generator and compressors are to sit up. when you do sit them up put stabil in the gas. run it and then run the gas out of the carburator. now, make sure the gas in the tank is good and has no water or trash. check the fuel line that it is in good conditon and not plugged. pull the carberator and clean varnish out and clean jets. soak it over nite in varsol or parts cleaner. check to see if you have a low oil shut off. oil level must be correct. check your exhaust to make sure it isn't plugged. some have a little screen that get coated with carbon and won't let it exhaust.( fuel in, spark, exhaust out)
Sep 02, 2010 | Electrical Supplies
11 hp 5700 watt generator wont fire
If you could not start in spite of oil and gas change, checked gas supply, spark plug, ignition cables and coils (magnetos) and so on whitout success, then try this:
Your generator has a low oil level protection, which stops the ignition of the motor.
After "a couple of years" sitting without or with old oil, the level switch may have got lazy or stuck down.
If your oil level seems to be good, while measured, find the oil switch and try to shorten or disconnect it.
If you succeed in running the generator change or repair the oil switch.
I hope that this will be helpful, because I don't have your device in front of me, but some people rank such an answer with 2 thumbs, which means useless. Better dont rank.
Jul 22, 2010 | McCulloch FG6000MK 5700Watt 13 HP 338CC...
Changed the oil, new plug,cleaned the air filter and arrester. tapped the muffler while off and shook out some junk. confident in my gas. my supply runs my two other gennies. so, here the question. unit...
2 things to check , carb bowl for rust/water/debris, if the engine has a oil alert fitted try disabling this ( after double checking oil level ) as these can sometimes become itermittant
Oct 20, 2009 | Honda Electrical Supplies
Honda GX160 runs fine for 5 minutes then dies like out of fuel.
I would look for the fuel filter. Blow it our. I know you have a new tank of gas, but you might want to empty it out and make sure the clean and put in new. Even with Stabil in the gas you might just have to much condensation in the tank
Sep 07, 2009 | Master Heaters MASTER HONDA POWERED...
ONAN 4000 RUNS FOR ONE HOUR AND DIES--ANY IDEAS WHY?
does it have original oil in it? if so they use a lighter weight oil than recommended for engine break in. change your oil and filter and see if that doesnt solve it.could be thinning out loosing pressure when hot. i have seen this beofore.. :)
Mar 24, 2009 | Watts Onan Portable Generator - 4000 ,...
Electrical Supplies Logo
203 people viewed this question
Top Briggs Electrical Supplies Experts
John Trevino
jdthefixer
Mike Carew
Are you a Briggs Electrical Supply Expert? Answer questions, earn points and help others
