Question about OKI C5300n Led Printer
Won't print Mac recognizes printer's existence. Printer set to "ONLINE" Document sent to printer. Nothing happens.
    Scholar:
  • 118 Answers
Contact Mac's web support for printer's they're quick to respond, sorry I couldn't help more
good luck
Posted on Apr 29, 2010
My HP Deskjet F380 all in one printer will copy but won't print
Switch off the printer,un install existing drivers(not to delete), restart the computer, switch on the printer, check whether system is recognized the printer?.. if not,try with another usb cable, no luck? problem with Logic card if available replace it or else go for new printer..
If system is recognized the printer, switch off the printer, run the driver CD.. connect USB cable when dialog box appears, do rest of the installation process. Shoot test page....Best off luck..
Aug 01, 2012 | HP DeskJet F380 All-In-One Printer
Hi, I have a mac and a Lexmark X 2600. Until today I just needed to connect my mac and the printer and it worked without problems. today, even though everything is connected, the printer is switched on and...
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Frequently, issues are caused simply by a break in the signal sent from PC to printer or vice versa. Unplugging and re-plugging the printer allows the small amount of on-board memory on the printer to be cleared, with the result that the PC recognizes the machine properly. Programs continuing to run in the background of the operating system (OS) can cause the signal to be lost. Rebooting the PC ends all programs that may be running and makes a 'clean' start, allowing the signal to be detected.
If that doesn't help, try to update your printer software by visiting the Lexmark website at http://bit.ly/aNGYmW. Select your operating system and download the driver and execute the file.
May 12, 2011 | Lexmark X2600 InkJet Printer
Hello. I have a Deskjet 810C, and a friend tried to adjust the settings. Now, when I try to print one full page of a document, it only prints a jumbled portion of one line. After that, it feeds through...
The symptoms indicate that the printer is receiving a data stream that it does not support or the data stream it is expecting (is set for) is not the one it is receiving. This also happens when the printer is somehow disrupted (like momentary power off) during printing. When it resumes, the setup information sent previously for the document has been lost, but the computer doesn't know about it so it sends data to the printer which prints merrily on in gibberish.
If you haven't already done so, try turning the printer off, disconnect the power cord for about 5-10 seconds, replug and turn the printer back on. Check to see whether that resolves the print issues.
If not, run the diagnostics: with the printer already on, press and hold the power switch while pressing the Resume switch four times, then release the power switch. If the problem is internal to the printer, nothing will happen (internal diagnostics should run and the printer will print something).
Assuming the diagnostics ran ok, the fastest way to fix this type of problem is to reinstall the printer drivers and software. Something has probably happened to the driver or the installation which is easiest to counter by reinstalling.
Mar 07, 2011 | HP DeskJet 810c InkJet Printer
HP Officejet 5610v: Sent document to print. Somehow the settings were set to print offline, so nothing came out. I "unchecked" the "print offline" option. I tried to...
This Utility program resolve all the printing issue for HP Printers ( Network and USB connection )
This Utility will Resolve :
1. Check Connectivity between the Pc/laptop and HP Printer
2. Check if there any Documents stuck in Queue
3. Check if all the software/Drivers are correctly Installed
4. Check if the HP Printer icon is the default icon to print
5. Will Resolve Printer Spooler Issue and few more issue
This Utility program will fix all these issues.
Download the file on Desktop and Run the program ( Ex. File name = HPPDU.EXE )
Click Here to download the Utility and save on Desktop location
Run the HPPDU file and follow the instruction on screen to fix.
Regards,
Ron
* Please rate this solution with Thumbs up and comment to help us improve providing support
Feb 21, 2011 | HP Officejet 5610v All-In-One InkJet...
Cant print using Dell A920 printer on my imac. printer set up shows driver is correct I think and the printer name is correct.
So clearly the Macintosh sees and recognizes the printer. WIll it let you queue a document to the printer? After you do, you will see an extra icon on the Dock that represents the printer queue. Open it up and see what is happening to the printer job. If it disappears, it was sent to the printer and the Mac thinks it was printer successfully; if it isn't printed then you have either a bad printer or a bad printer driver. If it stays in the queue and goes to "hold" state, look in the log to see what the error was -- the Mac is unable to negotiate with the printer to get your file printed.
Jun 09, 2010 | Apple iMac G5 Desktop
I send a document from WORD (ms vista) and nothing happens. Printer window shows a document to print.. but nothing ever prints. No lights blink as usual, nothing. restarted computer, still nothing.
Vista has most drivers, and certainly supports your printer.
Try this routine.
First turn on your computer.
Now, turn on printer, and connect the USB.
Vista will recognize it.
i) Go to printers and faxes and set your printer as default, because there are other software like One note which could be default.
OR ii) Go to your word document, ctrl+P for print settings, choose your printer from the drop down menu
Jun 03, 2009 | HP Deskjet 6940 InkJet Printer
Re-installation of printer software won't complete
i'd say you may have a corrupted system file..had your computer tuned up lately?
Mar 28, 2008 | HP LaserJet 1020 Printer
Printing from Mac os X 10.4.10
Here was the way I got it to work on my Mac: Set up the printer with a static IP address. Then add it as a LPD (Line Printer Daemon) printer. Specify L2 as the queue for a USB printer. (L1 is the parallel port).
(This took me a while to figure out - I couldn't get IPP or AppleTalk to work properly).
Sep 18, 2007 | Arris WPS870G (51272300100) Print Server
OKI C5300n Led Printer Logo
82 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
