Question about D-Link GamerLounge DGL-4300 Router (DGL4300)
My d link dlg400 router won't issue it's own
My d link DGL-4300 router won't issue it's own gateway address which should be 192.168.2.0. Also that IP url site is none existent to try to set it up.
    Problem Solver:
  • 12 Answers
The default IP address for this router is 192.168.0.1. Try that. If it is assigning ip addresses to your computer, you can check under status of network connections by right clicking the lan connection, left-clicking status, then click the support tab. The IP address listed next to gateway should be your routers IP address.
Posted on Apr 29, 2010
  • DocRabbit Apr 29, 2010
    The IP address you Posted would be considered the Network ID address for the network 192.168.2.x
    For the same network, the broadcast address would be 192.168.2.255, and the numbers 192.168.2.1 thru 192.168.2.254 would be the available IP addresses.
I'm just looking to update the DGL-3420 and update my DGL-4300 router (they were not in use for the past year) having some connection issues
DGL-3420 Firmware & DGL-4300 Firmware
Please visit the above links from DLink Official Support for your products. Firmware updates, Manuals, trouble-shootong guides etc are available. If you are experiencing connection issues, i would suggest that review the router settings before going for firmware updates. Most of the times the connection issues are due to settings only.
Hope it helps! Good Luck!
CreativeTECH
Feb 23, 2011 | D-Link Computers & Internet
How do i find the password for my dlink dgl 4300 so I can hook my wii
In order to find the wireless security page of your Dlink wireless router DGL 4300 , please follow these setps
1. Open up the internet explorer in the comp in which you are online and clear the address bar and type in the number 192.168.0.1 and hit enter.
2. You will be logged into the D-Link router setup page .
3. Under the SETUP tab, in the left hand side, click on WIRELESS SETTINGS? you will find Wireless security Mode under which you can find the password for the wireless settings.
Good Luck!
Thanks in Advance!
With Regards,
Prema
Dec 31, 2010 | D-Link GamerLounge DGL-4300 Router...
I forgot the password a i want to know how to reset the router so i can put a new password in
For reset router press RESET button for 10 seconds it is in back side of router.Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then click on wireless then wireless security then WEP security change the password and save settings.Then restart router then you can connect wifi with new password. Let me know if you need further assistance. Thanks for using FixYa.
Sep 21, 2010 | D-Link GamerLounge DGL-4300 Router...
Network connects without router. Install router
is your router powered? make sure your router is powered properly.
are you connecting your computer to the LAN ports? (the ones with a number not the one that say WAN? connect your computer to one of the LAN numbered ports and check to see if you get a green light on the front pannel. if you don't have green light, try a different port until, if you run out of ports and still no green light try a different cable.
have you by any chance disable your lan ports? I don't know if it is possible on your router to disable some ports, if that's the case is better to start fresh and simply reset your router by pressing a reset button for a minute while your router is getting powered and retest to see if you a green light on the lan port where you are connecting your computer.
if all this fails, it's very likely that your router has died. replaced accordingly.
Apr 04, 2010 | D-Link DGL-4100 Router (DGL4100)
Open port 80
To open a port on a router involves several steps.
1) Log into your router from your browser, this is generally at address 192.168.1.1
2) Type in your username and password (this varies from vendor to vendor)
3) Once logged in, go to the Advanced Tab, and then click on Gaming on the side menu.
4) Under the Add Game Rule, put the name, IP address can be left blank, and then set ports to open to 80.
5) Save changes.
Dec 03, 2009 | D-Link GamerLounge DGL-4300 Router...
Will not let me into router. only have an option for password and nothing works. tried resetting to default and it still doesnt work
are you trying to access the router set up ?
First make sure that your computer will be connected to the router with the ethernet cable.
Now check the IP address and Default gateway on the computer. Default gateway will be the IP address of the router.
When you try to access the router it will always ask you for the password.
Try the default user name = admin and password = admin
or try user name = blank ( do not type anything), password = admin.
if that is not working then the password of the router must be changed.
try some different password that you use most often.
If that doesn't work then you will need to reset the router and reconfigure the router.
once you reset the router , you will loose all the settings on the router.
Reset the router for 30 seconds. unplug the power. plug it back in. wait for 1 minute and try to open the page again.
Click Here to know more about how to reconfigure the router
Nov 17, 2009 | D-Link GamerLounge DGL-4300 Router...
Dual Router Configuration
Plug the second router into the lan not the wan and it will act as a switch instead of a router
Oct 02, 2008 | D-Link DGL-4100 Router (DGL4100)
DGL 4300
Glad to hear the new one is working (it's likely or at least possible, that the old one is simply mis-configured - resetting back to it's factory defaults and starting from scratch should help with the bridging issue)
Apr 10, 2008 | D-Link GamerLounge DGL-4300 Router...
Router won't allow internet access from DSL modem
in internet explorer, go to tools and internet options and delete all temp files and all cookies, as you may have corrupt cookies in your explorer temp files for your home page. look in the properties of your network card and on the tcp/ip line click properties and make sure 'obtain ip address automatically is ticked, as your ip address my be wrong. also run this programe if you still have problems, start>run, then type ipconfig /flushdns
Apr 13, 2007 | D-Link GamerLounge DGL-4300 Router...
D-Link GamerLounge DGL-4300 Router (DGL4300) Logo
88 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
