Gas flow through the carburetor is clogged. Easy fix is the following----- remove all gas from tank (siphon or drain). Put that gas aside or dispose of it. Use a little bit of fresh gas and a little bit of carburetor cleaner in the tank. Run that through (by running the motor with the choke.). Do it several time if needed. When it seems to be running better, then try just a little gas only to be sure you have cleared it. When you fill-er-up, be sure to add a gas additive like Sea Foam or similar.
