Question about Sony Playstation 3 (PS3) Console
Internet doesn't work + cuts out after 5 secs fro being turned on
Internet doesn't work and switches on for a few seconds then yellow light comes up the console turns off then red light starts flashing????
    Scholar:
  • 57 Answers
This is called the yellow light of death. You will need to get your system repaired. We can help you with this. We charge $80.00 and that includes a 90 day full coverage warranty with free round trip shipping. You can also extend the warranty up to four years on the console for full coverage. Contact us today and we'll be glad to help.
www.wiredextreme.com
Toll Free: 888-389-3038
Email: support@wiredextreme.com
Posted on Apr 29, 2010
Schematics for cjb100pd
Red is your positive, black is negative, both brown wires are to the speaker, and the yellow and green wire are for any emergency strobe lights you may want to hook up to it. P.S. if you wire up the brown wires and siren doesn't work make sure volume is turned up and try it again if it doesn't work then switch the brown wires around. Both toggle switches on the far right is to only turn the lights on. not the siren. Make sure the siren nob is turned all the way left thats off. The rest of the are just siren modes. The toggle switch all the way to the left. Push down horn comes on release it then horn goes off. Push up siren comes on for like 7-10 seconds and the goes off. Horn and your microphone always override any siren that may be on.
Mar 12, 2012 | Cars & Trucks
The SRS light will go off. Tell how to turn it off.
Hi, you cannot turn it off rather you have to reset it by following the instruction below...
  1. Turn ignition switch off, remove service connector cover.
  2. Connect (jump) the MES (Memory Erase Signal) connector (this is 2 pin connector wrapped on yellow plugged in the front of the under dash fuse box).
  3. Turn ignition switch on.
  4. SRS light will come on for 6 secs then go out, remove the jumper within 4 secs after the light goes out..
  5. The SRS light will come on again, reconnect the jumper within 4 secs after the light has come on.
  6. The SRS light will go off, remove the jumper with in 4 secs after the light has gone off.
  7. The SRS light will blink 2 times indicating the memory is reset.
  8. Turn the ignition switch to off and wait for 10 seconds.
May 25, 2011 | 1994 Honda Civic
Philips flat screen 42" flashing red light 7 times it stops for 5 seconds and 7 more flashes if i unplug and plug it a few time it will come on
my 42 inch phillips, i turn it on green light comes on for 10 sec then red light comes on and flashes 4 times then stops for 5 sec then repeats.
Apr 20, 2010 | Philips 42PF9631D 42 in. Plasma Television
Battery was low and put in new battery,problem SRC Light stays on how can I reset the SRC light?
I'm guessing you mean the SRS light, yes. When you have a bad battery the battery voltage can drop below 10 volts. The SRS unit detects this voltage loss and set a DTC (diagnostic trouble code) for an internal SRS unit failure. You have to erase the DTC memory. You'll need an SCS service connector tool (P/N 07PAZ-0010100) You can order one from your local honda dealer. Don't worry its not more than $10. Then you'll have to find the MES 2pin connector located in the upper right hand corner of the drivers underdash fuse box. It can be gray, green or yellow in color. 1.)Turn the ignition switch off. 2.)Unplug the MES connector from the fuse box and plug your SCS special tool into the MES connector. 3.) Turn the ignition switch on. 4.) The (red) SRS light in the dash will come on for 6 seconds and then go off. Remove the SCS tool from the MES (2P) connector within 4 sec. after the SRS light went off. 5.) The SRS light comes on again. Reconnect the SCS tool to the MES (2P) connector within 4 seconds after the SRS light came on. 6.) The SRS light goes off. Remove the SCS tool from the MES (2P) connector within 4 sec. 7.) The SRS light indicates that the memory is erased by blinking twice. 8.) Turn the ignition switch off and wait ten seconds. You may have to do this procedure a few time to get the steps correct. If this sounds to complicated I'm sure your local Honda dealer would be happy to reset the light for you for no charge. Just let them know that the battery was recently replaced and you think that the SRS light came on due to low battery voltage. -Hope this helps:)
Jan 13, 2010 | 1997 Honda Civic
406 wont lock/unlock please help!!!
Switch ignition ON.Press and hold lock button for 10 sec.Switch ign.Off.Remove key from ign. switch.Wait 5 sec.Sinchronization procedure complete.Confirm sinchronization has been successful by locking,double locking and unlocking vehicle. Repeat abuve procedure to sinchronize any remaining key.Good luck
Nov 30, 2009 | 2005 Peugeot 405
Samsung aircon cuts off. lights green/yellow flashing
lg air cond.multi split led lamp blink power 1 times,good sleep 2 times
Feb 11, 2009 | Heating & Cooling
Samsung aircon turns in 5 sec. lights green/yellow flashing
check capacitor on outside unit,or gas is leaking.
try to reset(small black button in inside unit under the cover)
Feb 11, 2009 | Samsung Heating & Cooling
If TV switch ON B+ is 139v but it will off after few sec. then font LED Blinks 3X
I found problem why this tv was cutting off after few seconds the switch is on. I replaced the vertical IC LA-7845N now the tv is working well
Oct 01, 2008 | Google Analytics
Tv cuts off and green light flashes
If your set was manufactured around July 2005, you may need a firmware upgrade to solve this issue. On the Sony website you can enter your model # and serial # to see if you TV is affected. If so, it is easy to have done and may be free from Sony. It sounds like the issue they described in the writeup on the required formware update. I had mine done within few months of when i bought it (purchased in Dec 2005) and it has been working flawlessly since.
Donnieboy999
Jul 19, 2008 | Sony KDF-E42A10 42 in. LCD Television
Sony handycam dcr-pc300/330
Make sure the batteries are fully charged. It may be your batteries may show they are charged but are too leak to operate the camera. Try a new one
Apr 07, 2008 | Sony Handycam CCD-TRV37 Camcorder
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
