Question about Makita Saws
How do i remove the front gear on a makita 4.5 inch grinder i cant get the bering of the front not sure if it takes a special tool
  • 34 Answers
Bearings are usually tightly placed on shafts of in the holes. You might need a tool like this (sorry I don't know English name for it). You can also ask some who makes car repairs for help. These guys usually have right tools and experience. Juraj PS: Sometimes also hammer helps, but you must be gentle
Posted on Jun 14, 2010
Bad bearing on makita ga4530. How do I get to the upper bearing?
You have to take the gear housing apart, remove the hex-nut and spiral bevel gear on the end of the armature so you can pull the armature out of the bearing. Then remove the retaining ring, o-ring and bad bearing for replacement.
Oct 10, 2013 | Makita GA4530 4 1/2" Grinder
My makita 4 1/2 grinder has a problem where the motor still turns but the mounting shaft and subsequently the disc does not move. Its not had more than a few weeks work so is almost new.
Inside the head of your grinder there are a couple beveled gears, one on the armature and the other on the spindle that the discs attach to. If either or both gears are broke or worn down to where they don't contact each other properly, the motor will spin but not turn the spindle. It's easy to disassemble the head to check but if the tool is that new you may want to look into getting it repaired under the warranty.
Jun 15, 2012 | Makita Angle Grinder 4.5" 9524NBX
How do I replace the big gear on a makita 9557nb grinder
After taking the bearig box off the head, remove the retaining ring and wave washer on top of the gear. Some spindles can be tapped out of the gear with a hammer but be extremely careful not to mushroom the spindle head. It's best to take it off with a hydraulic press. There is a woodruff key in there so be careful not to loose that when you press the spindle out of the gear. The new gear should be pressed back on also.
Dec 31, 2011 | Makita Saws
I need help to replace my brushes on a makita 9553NB 4 inch angle grinder the old model i used to have had easy access.. coin sized slots on the handle that you simply uncsrew to reveal the brushes. my...
first unplug the tool, next on the backside you will notice a screw, remove it and slide the cover back to expose the backside of the motor. gently move the springs that hold the brushes tight to the side and remove the brushes and replace. Make sure to replace the springs and then slide the cover back into place and replace the screw and that should take care of your problem.
Feb 18, 2011 | Makita 9553NB 4" Angle Grinder
Slow,smell burned
Sounds like your brushes are used up. Take the brush caps off on each side of the grinder handle, if the carbon is 1/8" long or shorter they have to be replaced. (Makita Part #191938-1) If you overworked the tool (put too much pressure on while grinding) it's possible the armature and/or field overheated and burned out. They are Makita Part #517301-4 and #521621-0 respectively. You need a growler to check these items to see if they're shorted out.
Aug 21, 2010 | Makita Angle Grinder 4.5" 9524NBX
I got a Makita4
Your missing the flat wrench that goes under the blade and holds the shaft from turning. I can't find anywhere to buy just the wrench. If you can find an old 14mm wrench and grind it down on both sides so that it's only about 1/8 of an inch thick it should work.
Jan 08, 2010 | Makita 9553NB 4" Angle Grinder
Angle grinder
on a grinder the nut that holds the wheel on has left handed threads.....that means it has to be turned in the opposite direction than conventional nuts do..there should be a button on the casing to hold in..this keeps the grinding wheel from turning wheel being removed....remember to unplug first..thanks and have a great day
Jan 03, 2010 | Saws
Armature problems
Unplug tool and then remove the brush caps and brushes, at the front of the tool are 4 screws that need to be removed after removing them you might have to pry the gearcase from the motor housing and then it should just pull out if there is no problems with the field having been hot and melted. Let me know if you need further assistance
Mar 06, 2009 | Makita 9005B 5" Electric Angle Grinder
Something wrong with the armature
If the armature is shot, it will spark a lot where the brushes are touching the armature comutator. To remove the armature:1 Remove brushes. 2 Remove 4 screws holding the gear box. 3 Pull away gear box from the body. The armature may come with the gear box or not, it's only pushed in, so you should have no problem to disassemble it. If the armature stay in the grinder, use two skrew drivers to pray it out. You may not see anythink wrong with it, but it may be no good . That's Makita special, they don't make it good as they used to. The price for new grinder is about $130, for armature $65. field $40
Saws Logo
154 people viewed this question
Top Makita Saws Experts
ray gallant
Are you a Makita Saw Expert? Answer questions, earn points and help others
