Question about Ricoh Aficio SP C222SF All-In-One Laser Printer
Printer is misfeeding almost every sheet of paper it tries to print, right out of the tray. Can it be fixed easily or does it need repair/replacement?
  • 85 Answers
If it is jamming right at the tray then the pick up rollers will need to be replaced.
Posted on Apr 29, 2010
Single paper sheet not printed, multiple yes
Try few steps as given below...
1. poor quality printer may reduce printer quality & causes paper jams and other printer problems. If you encounter problem , switch to a higher grade of printer.
2. Do not load curled and paper folder.
I hope, it helps.
Feel free to get instant printer help at http://www.vtechsquad.com/printer-support/ to fix any printer issues.
Jan 21, 2013 | Epson Stylus Photo R800 InkJet Printer
I have an epson printer and when I hit print, the paper slides right thru & says paper jam
  • Carefully remove the jammed photo paper. Gently pull the paper up and out of the paper feeder tray.
  • 2
    Reload the paper into the tray. Stack the paper on a flat surface and then carefully slide the paper stack straight into the paper feeder tray---along and aligned with the right side of the tray. Secure the stack in place by sliding the left "edge guide" against the paper stack.
  • Sponsored Links
  • 3
    Press the "OK" button to resume printing. If you had a "Paper is jammed in the printer..." error message displayed on the control panel LCD, pressing "OK" should also clear the message.
  • 4
    Pull the paper from the printer, if the status message reappears and/or the printer doesn't print, and check the paper for folds, buckling and curled edges or corners. Also check the sheets for sticking. If any of your sheets stick or have damage, remove them from your photo paper stack and replace with new sheets. Reload the paper and press "OK" to try again.
  • Performance Chip
    May 22, 2012 | Epson NX415 All-In-One Printer
    "Paper Jam" message displays despite there being no paper jammed. I have cleaned all the rollers and inspected as much as I can easily get to. Is there an easy fix or should I shop for replacements?
    Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
    1. 1 Switch off the printer and disconnect the power supply. Allow any residual charge to fade away before putting your hands or metal tools inside the chassis.
    2. Step 2 Pin down the exact location of the jam. The three hot spots for a jam are the paper tray, anywhere between the feed tray and the print carriage, or between the print carriage and the output tray.
    3. Step 3 Take off the front paper tray if the sheet got stuck while it was still in the front area of the printer. If the sheet jammed here, you should be able to see most of the paper.
    4. Step 4 Pull on the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a chunk of it deeper in the machine.
    5. Step 5 Open the back panel to reach paper jammed between the feed tray area and the print carriage of the all-in-one printer. Carefully remove the jammed paper from the machine.
    6. Step 6 Use the carriage access door to reach a jam further inside the all-in-one printer. You may need to move the print carriage out of your way to clear the jam.
    7. Step 7 Return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
    Oct 21, 2010 | HP PSC 750 All-In-One InkJet Printer
    My Brother MFC-7820N has a paper jam problem that seems to be related to it's picking up an additional sheet of paper and when the first sheet completes it's print pass, the second is midway and the...
    most paper has a smooth side and a little less smooth side, try flipping the paper. in the pack use the top side as the printing side when u load. try a different brand of paper could easily correct the problem,
    some feed trays work best when nearly full also, try half full etc.
    Oct 10, 2010 | Brother MFC-7820N Laser Printer
    PAPER JAM ERROR 201.02
    if you are gettiing a 201 error without any paper in the printer you will need change the main motor drive if it fails to initialize this is the error that will show up and there is no other way to reset it
    Mar 20, 2009 | Lexmark T640 Laser Printer
    Paper Feed Problems
    Hello sir; Try to remove all the paper out of the tray look inside of the bottom on right side , if you find something ( such as; paper clip, stapplers,paper chip etc) remove it , otherwise find a piece businese card stick reverse way from paper exit to clear up.
    Jan 02, 2009 | Lexmark X6170 All-In-One InkJet Printer
    Lexmark t640: paper jam in the back door. I can see the edge of the paper. How do I release the tension on the rollers so I can slide it out? Now it is in there tight and to grab it just tears off a piece...
    Hope this helps....
    Explanation of the paper jam message
    A 241.09 Paper Jam message indicates that the printer thinks a sheet of paper has jammed at the front of the printer. The jammed sheet of paper is most likely to be found in one of the paper trays or under the toner cartridge.
    NOTE: If you select Show areas on the operator panel, you can view one or more images to help you locate and clear the jam.
    Clearing the jam
    To resolve the paper jam message, you must first clear the entire paper path. To access the jam area, you will need to open one or more of the paper trays. Follow the steps in the table below to help you locate and clear the jam.
    Step Action Image 1 Open the printer paper tray (tray 1), and remove any jammed media you find there. pattlnk_10222007_1922-enus28872_24109paperjam1_t64x_en_us.gif 2 Open the front cover and remove the toner cartridge. Examine the area inside the printer and remove any jammed media you find there. pattlnk_10242007_159-enus28872_24109paperjam5_t64x_en_us.gif 3 If you have a duplex option installed, also remove the duplex access tray and remove any jammed media you find there. pattlnk_10302007_1559-enus28860_24x17paperjamduplex_t64x_en_us.gif 4 If you were printing from an optional paper tray, such as tray 2 or tray 3, open any optional trays, starting at the top, and remove any jammed media. Pull the print media either up or down. If it does not pull easily one way, try the other way pattlnk_10222007_1957-enus28872_24109paperjam3_t64x_en_us.gif 5 If you are printing from an optional 2000-sheet feeder, open the front door. Press the elevator button (A) to lower the tray. Remove any partially fed media from the feeder.
    NOTE: Make sure the stack of print media is straight and pushed all of the way into the feeder. Incorrectly loaded paper is the most common cause of paper jams from a 2000-sheet feeder option.
    For a larger image, click here. 6 Finally, reinstall all of the paper trays and press the pattlnk_10222007_2117-select_button.jpg button to try printing again.
    NOTE: You may receive a different paper jam message informing you that another sheet of paper is jammed elsewhere in the printer. If this occurs, the error code will indicate the location. Click here for a diagram showing the error code locations. The paper path will vary, depending on the paper source and number of paper feed options installed.
    Remove any jammed sheets of paper you find and try printing again.
    Dec 12, 2008 | Lexmark T640 Laser Printer
    My kodak easyshare5300 is printing black picture
    Hi-
    If your product is still within the warranty period from KOdak then you can call them up for some step by step troubleshooting to help you with your problem and as well they can replace the printer if defective.
    Try this first
    Calibrate your printer, then print a demo sheet.
    1. If paper is in the photo paper tray, remove it.
    2. Load photo paper into the photo tray.
      1. Fan the paper to keep the sheets from sticking together. IMPORTANT: Do not overload the photo tray.
      2. Load a maximum of 20 sheets into the photo tray, with the Kodak logo facing up.
    3. Calibrate your printer.
      1. Press Menu.
      2. Select Calibrate Printer, then press Start.
      3. Wait for your printer to print the calibration sheet.
      4. Place the calibration sheet face down on the scanner glass.
        • For the 5300 AiO printer, place the sheet on the front right corner of the scanner glass.
        • For the 5500 AiO printer, place the sheet on the left rear corner of the scanner glass.
      5. Press Start.
      6. Wait until "Calibration complete. Remove calibration page from scanner glass. Press OK to continue." appears on the LCD display.
      7. Remove the calibration sheet from the scanner glass, then press OK.
    4. Print a demo sheet.
      1. Disengage the photo tray by sliding it towards you until it stops. When the photo tray is disengaged, the main tray is active.
      2. Select Print Demo Page, then press Start.
      3. Wait for the demo sheet to print.
    Then call them if issue Persist at these numbers:
    In the U.S. and Canada: 1-800-421-6699
    In Australia and New Zealand: 1800 793 895
    Thanks for using Fixya!
    Jun 21, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
    Printer
    If it is not pushing the paper out of the tray, you should first try taking a soapy cleaner like fantastic or formula 109 and clean the feed rollers and see if that helps.
    The paper tray also lifts up and down to feed the paper so the gear that drives the tray up and down may be broken.
    Slen the rolls first. If that doesn;t last long. Say in a day or two it starts misfeeding again, the rollers will need to be replaced.
    Mar 23, 2008 | Office Equipment & Supplies
    Ricoh Aficio SP C222SF All-In-One Laser Printer Logo
    324 people viewed this question
    Top Ricoh Office Equipment & Supplies Experts
    Adorjani Laszlo
    quennie732
    fares
    Level 1 Expert
    Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
