Question about Delta & Single Handle Shower Faucet
Have single handle lever delta shower faucet which is leaking--am trying to replace parts -- cannot find how to description......
  • Tammy Loftheim
    Tammy Loftheim May 11, 2010
    Which is leaking, the lever or the faucet?
  • 6,674 Answers
Try this link, it should get you to where you can find yours, if this isn't it. Then you can view parts, installation etc.
http://www.deltafaucet.com/customersupport/documentation/1343.html?document=pd
Posted on May 03, 2010
  • 3 Answers
The handle requires a very small flat head screw driver or hex tool to remove. There is a small hole on the handle which holds this set screw.
Once you remove the handle. the center tube should slide off easily. if not., just wiggle a little bit.
Once the center tube is removed you will see the valve. The valve is held in place by a brass ring. the ( round ) brass ring is about 1 1/4 inch and is screwed into a mating male brass tube. "Between the 2 brass tubes is a black rubber gasket"
Unscrew this brass ring and the valve then simply pulls out.
This delta design is simple and very durable., I hope this helps.
Posted on May 13, 2010
Why no water thru delta single lever kitchen faucet
can be a number of issues: clogged aerator, water supply is turned off, or supply lines are kinked, debris behind cartridge blocking flow, rubber seats out of place.... What has changed to cause problems?
Mar 25, 2013 | Delta & Single Handle Shower Faucet
Single handle shower/bath faucet is dripping. Want
I can fix this.
What is the last thing you did before this problem started?
Jan 13, 2011 | Delta Faucet Delta 172-SSWF Waterfall...
Leaky shower head
If you replaced the seats and springs and the problem continued you may need to get a whole rebuild kit including the ball and replace that one as well
Jun 27, 2010 | Delta & Single Handle Shower Faucet
Delta single lever faucet leakingafter bing shut off.
Will need to get delta faucet rebuild kit. Available at home depot, lowes or hardware store. It consists of valve stem seals & springs. The larger kit will contain ball assembly. Turn off water to faucet. Unscrew handle via set screw under plastic cap. Unthread cap over ball assembly. Pry out valve seals & springs. Reverse procedure to install.
Jun 26, 2010 | Delta & Single Handle Shower Faucet
How do I replace a single handle Delta mixer??
You would have to open up your drywall, cut and re-solder a new single handle faucet. An easier approach could be to shutting off your water supply, draining the lines in your bathroom from someplace below, and then trying to fix the bad soldered joint if you know how to do so.
I hope this helped.
May 25, 2010 | Delta & Single Handle Shower Faucet
Leaky single lever bath tub faucet
Faucet is leaking due to seats bad.
1- Turn water off first and remove handle and remove collar that holds stem and remove it..
2- in valve there are seats that looks like caps they may be in valve body or the end of stem itself.
3- Remove them and the springs and replace them this will take care of the leaking problem.
May 21, 2010 | Delta & Single Handle Shower Faucet
How do you switch out the single lever dial on a delta shower fau
Hidden under the lever is a little hex screw. Use an appropriate hex a.k.a. "Allen" wrench to remove the handle. You might want to shut down the water service first to save your shower until later.
Mar 16, 2010 | Delta & Single Handle Shower Faucet
Pulsating water and poor hot water pressure
Based on your description it sounds like the pressure balancing valve could be gunked up with particulate from your well or just worn out. If your water is not filtered to that shower I would lean more towards particulate. Try to remove the cartridge and take it to a plumbing parts store for a match-up since Delta makes several cartridges and you want to get it right the first time.
Feb 10, 2010 | Delta & Single Handle Shower Faucet
Slow leak old delta
The brass cap unscrews and yes there are replacements. You can find them at any home improvement store.
Sep 14, 2009 | Delta & Single Handle Shower Faucet
Delta & Single Handle Shower Faucet  Logo
545 people viewed this question
Top Delta Home Experts
Mike
john h
Tim Whalen
Are you a Delta Home Expert? Answer questions, earn points and help others
