Question about Acer Aspire 5610 Notebook
Acer Aspire 5610Z dead battery & malfunctioning power adapter
Acer Aspire 5610Z dead battery/power adapter malfunctioning
Battery has been dead. Pin where charger inserts came completely loose last year and I had it repaired. While it appears to be intact (no movement), now when I plug in power supply, it will stop working and I will have to move the plug around until I get it "just so"; this continues throughout the day with much repetition. I am considering buying a new battery (where do I get one, btw?) but am concerned that my ability to charge the thing will croak right after I shell out the cash.
Any thoughts?
    Problem Solver:
  • 21 Answers
Hi
i think the battery for acer 5610, you may see here
Posted on May 01, 2010
  • Acer Master
  • 4,737 Answers
But before you buy a new battery, You need to again repair the power plug where your adaptor's plug is inserted so that it will not create any problem later. There might be loose connection or sort wiring.. Good luck..
Posted on Apr 29, 2010
My Acer Aspire one notebook ZG5 won't turn/boot on, help?
1. Dead AC adapter
2. Dead battery
3. Broken AC-socket on laptop, so no power is received, and battery is not charging.
4. Dead ON/OFF switch
5. Dead motherboard
Take your computer to a qualified technician, for professional trouble-shooting & remediation.
Jul 19, 2011 | Computers & Internet
My acer aspire 5610z series does not trun on even with the power cored followed rebooting trouble shooting nothing wrked i think it made it worse what do i do
1. Check your power cord & adapter. 2. If its working then check the battery, reseat the battery & check. 3. If available then check with another battery 4. If no, then remove the battery & switch on the PC in AC mode. 5. Check if battery charging indication or AC power on indication is glowing. if not then need to change ur motherboard. 6. If indication is OK, but could not power ON then check ur RAM for any loose connection or dust. clean & reinstall. 7. If still no display, connect an external monitor, check if display is comming. 8. If Display is coming then your LCD need to replace.
Aug 23, 2010 | Acer Aspire 5600 Series 5610-2013 Notebook
I have ACER ASPIRE 2920, the power suplly can't turn ON
There could be a problem with the battery. A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective & needs to be replaced.
If this did not work, try also disassembling the laptop & make sure that all main components are seated properly. Also make sure that all ribbon cables interconnecting the various components of the laptop are tightly connected.
Dec 27, 2009 | Acer Aspire 5500 5570-2609 Laptop
No output voltage to input of inverter therefore no backlite wich chip damage...?notebook is acer aspire 5610z.
Dec 22, 2009 | Acer Aspire 5610 Notebook
Acer aspire 5135 will not charge is it the battery or the charger
Nov 17, 2009 | Acer Aspire 5315 Notebook
I have an Acer Aspire 3610 notebook. It wont charge
How old is your battery? When you use your laptop, do you run it on just the battery or do you use your a/c adapter and battery? If you're going to use your laptop for an extended period of time, it's recommended to remove the battery and run off of a/c power alone. This helps to extend the life of your battery. Over time, using both a/c and battery will cause your battery to charge/discharge, which dramatically shortens the life of the battery.
You may simply have a dead battery.
Another alternative is that you have a bad power unit, which is what the a/c adapter plugs into on your laptop. My guess is that you most likely have a dead battery.
Oct 07, 2009 | Acer Aspire 3610 Notebook
Acer Aspire 5610z Battery Replacement
I would wait for your acer battery, try a computer store such as office depot who sells alot of acer or best buy as a last resort. Even ebay is a better chance. I would return the rayovan battery...they are good batteries, just not for laptops
Dec 10, 2008 | Computers & Internet
Charger in not charging the battery
You can get an A/C adapter online on various websites or Ebay for around 20-30 dollars plus shipping. That should rule out whether the problem is your adapter or the laptop.
Nov 16, 2008 | Acer Aspire 5610-4648 Notebook
Acer aspire 5610z laptop wont start.
well, first of all check the LED if it lights up when you plug the AC cord, if it goes on it means you got power. Otherwise, either the power supply or battery is dead. You should check if an OS was pre-installed.
Oct 15, 2008 | Computers & Internet
Acer Aspire 5610 Notebook Logo
503 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
