Question about Delta Faucet Delta 172-SSWF Waterfall Single Handle Kitchen Faucet with Matching Side Sp...
Cannot remove spout on model 172 Delta faucet
  • 659 Answers
SOURCE: leakes around spout
You remove the handle after turning the water off the to faucet. Remove the retaining nut which is apart of the trim. The ball assymbly will pull right out and you will find the two little washers and springs below the ball. You can buy a rebuild kit with the new ball if you like but it is not necessary. When you do replace the washers, it might be necessary to tighen the tension ring that is on the retaining nut. Tighten it unit it doesn't leak around the ball stem.
Posted on Apr 03, 2009
  • 659 Answers
SOURCE: Adjusting single leaver faucet handle
The little wrench tightens the tension ring that fits on the inside of the retaining nut right under the handle. You fit the little "arms" in the notches.
Posted on Apr 06, 2009
  • 10865 Answers
SOURCE: Need Delta kitchen faucet repair kit # for model #
you can generally purchase this kit at any plumbing supply store, or a home depot, or on line http://www.repairclinic.com/
Posted on Aug 19, 2009
  • 21 Answers
SOURCE: I do not know how to remove the spout from a Delta
You shouldn't have to remove the ball to take the spout off. It simply slides onto the post. Simply rotate it back and forth while raising it up, it should slide off directly towards the ceiling.
Posted on Nov 16, 2009
motor1258
  • 6674 Answers
SOURCE: I have a Delta Waterfall 172 SSWF faucet in my
Normally you just turn that ring, counter clockwise. If too hard to turn, I usually put a rag over it, to avoid scratching, and use a pair of channel lock pliers, and squeeze just hard enough not to slip.
Posted on Jan 15, 2010
How do you remove the spout cap (RP34090) from a 2 handle delta 2402 kitchen faucet? The spout cap is stuck.
If you are talking about the aerator at the end of the spout,take a pair of pliers and a rag put the rag on the aerator and turn counter clockwise(take care to make sure rag is covering all the area and that should help you get it off.If you plan on replaceing aerator which is about $6 just take the pliers and take it off.
Jun 10, 2011 | Delta Faucet Delta 172-SSWF Waterfall...
Hard to turn spout side to side
Remove the spout and apply a thin coating of plumber's waterproof silicone lubricant to the O-rings on the spouts mounting post. If the spout is still difficult to turn, replace the O-rings. Here is the link to the delta waterfall parts breakdown.
Sep 04, 2010 | Delta Faucet Delta 172-SSWF Waterfall...
Any tricks to lifting the spout off the base? I slid the collar up and removed the plastic retainer, but don't seem to be able to life the spout.
Run the hot water for a few minutes this will expand the spout and help loosen the seals. You may have to pull hard but it will come off. Use alittle silicone grease on the o-ring when reinstalling.
Jan 16, 2010 | Delta Faucet Delta 172-SSWF Waterfall...
I have a Delta Waterfall 172 SSWF faucet in my kitchen. I need to replace the water spout - I have the replacement spout. It appears there is a plastic retainer ring that holds the spout in place but I'm...
Jan 15, 2010 | Delta Faucet Delta 172-SSWF Waterfall...
Replace entire valve assembly
You can drill a small hole into the set-screw and use an easyout to extract the set screw
May 04, 2009 | Delta Faucet Delta 172-SSWF Waterfall...
Leakes around spout
Apr 02, 2009 | Delta Faucet Delta 172-SSWF Waterfall...
Delta Faucet Delta 172-SSWF Waterfall Single Handle Kitchen Faucet with Matching Side Sp... Logo
290 people viewed this question
Top Delta Faucet Plumbing Experts
Donni Steen
Ed Mac
Are you a Delta Faucet Plumbing Expert? Answer questions, earn points and help others
