Question about Dryers
No heat Drum turns, but no heat generated
  • 2 more comments
  • abdirect Apr 29, 2010
    Kenmore 30 series
    model 110 76742501
    Kenmore 30 series model 110 76742501
  • yadayada
    yadayada May 11, 2010
    thx, perhaps some other expert will have the answer for you now. Try our live chat if u can't wait for the answers
  • yadayada
    make and model number off tag.
    Habit-Forming:
  • 98 Answers
For an electric dryer, the heater has probably failed. A failed thermostat can also cause this symptom.
Unplug the machine! Disconnect the heater and check it for continuity with a multimeter. If it does not have continuity, replace it. If the heater has continuity, check each thermostat for continuity. All thermostats should have continuity at room temperature.
Posted on Apr 29, 2010
How do I change the thermostat on an Indesit IDC85
heater units have 2 or 3 starts ,check they work ..on some hotpoint dryers there is a stat on the front top right just under the timer as wire burns out then no heat ..WARNING TAKE OUT THE PLUG
Sep 16, 2015 | Indesit IDC85S Silver Electric Dryer 8kg,...
Why heat generated in pullser back mag wheel
Hi, Anonymous because there is a lot of activity going on back there that transfers heat to the rear wheel.
1. Tire to road surface generates heat.
2. Engine heat transfer.
3. Exhaust heat transfer.
4. Brake drum/caliper heat transfer.
Good luck and have a nice day.
Apr 03, 2014 | Bajaj Motorcycles
Whirlpool AWZ 410 washer dryer is not generating any hot air when drying. The dryer drum is tumbling but with cool air only.
Unplug the unit and take the top with the screws holding the lid on. Take a look at all of the wires on the top of the machine. You might notice broken/burnt wires on the safeties that are close to or that directly activate the heating element located in the blower housing located at the top of this washer/dryer condensing unit.
Nov 26, 2013 | Whirlpool LER4634J Electric Dryer
Not generating heat and dosnt stop automatically
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101 ,..,
Apr 03, 2011 | GE Dryers
There is no heat being generated but the drum still turns
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Nov 23, 2010 | Kenmore Dryers
Drum doesnt spin
Watch the video to learn how to replace the belt that turns the drum:
Sep 22, 2009 | Asko Dryers
No heat or timer
possible wire has come loose from some where.there are a couple of problems that could cause this.one a bad timer check the harnes to the timer,or you have got a thermal fuse that has gone bad
Sep 16, 2009 | Dryers
Hotpoint Utima Logic Sensing Condenser TDC62
lewensc...this sounds like a classic timer issue. Before replacing it, first turn off your mains breakers and then back on. Check all wiring from the breaker panel to the unit. If okay, then have a quick look at the items in the dryer and test them using a multi tester. If nothing is amiss, replace the timer.
Dec 17, 2007 | Hotpoint TDC32 Electric Dryer
Miele T220 drum doesn't turn
sounds like belt may be slipping .. check idler pully for tightest against belt .. belt may be streached and need replacing
Oct 14, 2007 | Miele Novotronic T220 Electric Dryer
No Heat on Whirlpool Gas Dryer
The timer should advance in the time dry cycles if it does, it is fine Its common for them to not in automatic cycles when there is no heat I would call for service unless you have basic gas appliance knowledge , as it is dangerous If you decide attempt i can tell you what to look for Please rate my help .....Thanks
Oct 02, 2007 | Dryers
Dryers Logo
80 people viewed this question
Top Dryers Experts
