Back to:
Tags:
Dacor Preference RSD30 Gas Kitchen Range
Trying to determine if the ERC or main relay is... (by 2 users)
posted by Imbassai on Mar 24, 2008
I found you here on FixYa and you seem very knowledgable and I was hoping you could help me out.
Our Dacor range acted up a month or so ago where the cooling blower came on all by itself - the oven hadn't been on all day. I reset the circuit breaker and it seemed to solve the problem.
Last week I was making a very large pot of turkey soup and in the process at least a quart or two of stock ended up cascading across the front of the range and provided a very brief waterfall over to the floor. A moment later I noticed the LED display was saying OFF, then OF, then blinking, then various temperatures were displayed, etc.
I shut off the breaker; cleaned up the mess, and turned the range back on: similar results, with a few random beeps added to the mix. After a day of 'resting' the range and hoping it might be 'wet' and would dry out - the following occurs consistently: turn on breaker and the time displays and blinks; the word OFF appears in the temperature area for a second, then 045 appears in the same area; then the same sequence starts again - and each time there is a change in the display a single or double beep is heard.
Do you think I need an new ERC or could the main relay board be the culprit? Is there any relatively easy way for me to check either of these components before having to order them? I've taken out the ERC - seems okay (in the sense that there isn't any charred area where my soup would have encountered it) but I didn't test each transistor for resistence.
I've never received any formal error codes on the display. Is there a way to 'reset' or get the ERC to display its status by holding down any control key combos? I've seen reference in FixYa to sequences for changing F to C degrees...
Thanks a million in advance - we're limping along right now with the ERC out of the range (which still gives us full access to the range top gas burners, but no stove control).
Ben
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by dacorcook, posted on Sep 10, 2008
Where is the relay board located on the Dacor rsd30?
Solution #1
posted on Aug 25, 2008
Not Rated (0)
Krazytech
Rank:Guru Guru
Rating: 92%, 401 votes
after you got the OFF in the display did you do a hard reset?... if the relay if the problem you should get a F-1 error... I would replace the ERC...
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Trying to determine if the ERC or main relay is acting up:
I don't want to Accept this solution
Can you Help with these Kitchen Ranges problems?
We have had a Dacor RSD 30 for 5 years...our clock...
How do I start solving this issue? I checked the circuit...
Hello, we have a ceramic (5 burner) range that was in...
I turned my oven on as normal and cooked dinner and I...
RSD30 Dacor electric range convection fan runs and door...
Loading problems.
Repair Service
Find Kitchen Range Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
