Question about Canon PIXMA MP510 All-In-One InkJet Printer
Error code 5010
When I turn on my Mp 510 printer it just shows error code 5010 and will do nothing else. The lights flash orange and green alternately. Any suggestions?
  • 5 more comments
  • tris85 Apr 01, 2008
    my canon mp510 is showing the same error ( 5010) i haven't done anything to it, the only thing that may be coursing it is the colour cartridges may need changing...does anyone know! thank u!
  • Anonymous Jun 02, 2008
  • chiste Jun 04, 2008
    falla!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  • badger111 Aug 15, 2008
    not working error code 5010
  • bigworld31 Aug 21, 2008
    Yes, same thing happens to me...Error code 5010...and flashing green and orange...alternating lights.
    I was trying to photocopy (in basic black, not colour). I had a few pages to copy. I got this 5010 Error code after EACH copy!
    I had to turn off the printer after each copy and then turn it back on for the next copy. That's not the worse of it.....once I turned the printer back on and hit copy again...the printer took a VERY long time to scan the item for the next copy. It took me a good 40 minutes to copy 15 pages.
    Sooooo irritating!!!!!
    Anyone know what to do?
    I've also had the paper jam on me tons of times. I am really disappointed with this product. I would not recommend this printer to anyone!
  • slappfamily Dec 08, 2008
    Error Code 5010 Cannon MP510. After every copy I do the error code comes up and my printer wont print anymore. I need to restart it and
    can only copy one at a time after turning the printer off and on each
    copy. That's ANNOYING! Can you help me. Chyrel
  • Brenda Kidd
    Brenda Kidd Nov 18, 2013
    my canon mp600 has error 5010 and with flashing orange and green lights. I've unplugged it from everything and turned the printer on, but doesn't matter.
Posted on Aug 21, 2008
    Opps! My post was a question, not a solution. Sorry.
Will not print
the sequence that the lights flash is how the error codes are given. Please count the sequence of flashes and re-post
Mar 27, 2014 | Canon PIXMA iP90v Printer
Error code 5010 green & orange lights flashing printer will not operate
Error 5010 is a scanner error, either not warming up properly, or lamp or sensor error. Either way, the scanner will need to be replaced. I can check for you and get a part number and price if you like.
Jun 23, 2009 | Canon PIXMA MP600 all-In-One InkJet...
My canon MP 610 shows code 5010, also the green & orange lamps are flashing aleranately .
same problem here but i think; its a hardware problem or maybe scanner but if u face error 2:4 thats i confirm problem with connecter cable from scanner into motheboard...just check cable connecter scanner connect properly if doesnt work.......send to canon service center
Aug 21, 2011 | Canon MP610 Photo All-In-One Printer
I have a cannon MP 510. When I turn it on, the carriage slams right and left. Then the lights on the front flash Green (left) Orange (right), Green (left) and Orange (right), then stops flashing for a...
I suspect you had a paper jam and removed it from under the main cover. It sounds like you have got grease on the encoder strip (the long blackish plastic strip that runs the full width of the machine. The carriage looks at the encoder so it knows where it is. Clean the encoder with soapy water on a cotton bud. You may have even snapped the encoder which will mean you will need a new one.
Good luck
May 26, 2011 | Canon Office Equipment & Supplies
Green light flashes, will not print. Checked all
Hi can gave you the truble codes
  • Light Orange - 2 beeps: Remove any paper jammed
  • Light Orange - 3 beeps: Remove any paper jammed
  • Light Orange - 4 beeps: Add Ink
  • Light Orange - 5 beeps: Re-install cartridge or replace it
  • Light Orange - 6 beeps: Re-install cartridge or replace it
  • Light Orange - 7 beeps: Re-install cartridge or replace it
  • Light Orange - 8 beeps: Waste is almost full
  • Flash 1 x Orange - 10 beeps (error code 6100): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 2 x Orange - 10 beeps (error code 6300): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 3 x Orange - 10 beeps (error code 6800): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 4 x Orange - 10 beeps (error code 5100): Make sure nothing is blocking the cartridge movement, if not requires service.
  • Flash 5 x Orange - 10 beeps (error code 5400): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 6 x Orange - 10 beeps (error code 5B00): Waste full (make a reset)
  • Flash 7 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 8 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 9 x Orange - 10 beeps (error code 5600): Replace the BJ Cartridge(Printhead) or reinstall it
  • Feb 01, 2010 | Canon BJC 4400 InkJet Printer
    Canon printer mp 510 error 5010
    That is a purge system error, either you need a new purge assembly or there is a paper scrap caught in there stopping it. The purge unit is on the right where the printhead parks at shutdown and where the printhead is cleaned.
    Aug 25, 2009 | Canon PIXMA MP510 All-In-One InkJet...
    Cannot get Canon PIXMA MP 150 to work at all
    salve la mia mi canon mp 150 lo scanner non funziona e mi da errore code 2,250,0
    Apr 18, 2008 | Canon PIXMA MP150 All-In-One InkJet...
    Canon Pixma MP600R shows Error Code6000. Green & Orange Lights flash alternately and cannot use any of the printer /scanner functions. Help!!
    Each colour flashes alternately on a continuous basis for as long as I leave the prnter on - i.e. green , orange, green , orange, green , orange,............
    Thanks,
    Mar 28, 2008 | Computers & Internet
    Canon PIXMA  MP510 All-In-One InkJet Printer Logo
    2,305 people viewed this question
    old marine
    old marine
