Question about KitchenAid K45SS Classic Stand Mixer
I have a K45SS Kitchen Aid mixer, and it doesn't start. It turns very slowly and I changed the burshes, but still the same. Could it be the plate control?
  • 185 Answers
It could be. also a tight bearing/shaft could be culprit. sometimes, the two nuts that hold the motor field loosen; and even fall off.
Posted on Aug 31, 2010
Can the motor be gone if my kitchen aid mixer will not come on
This can be caused by a number of things. Offhand, some are:
Bad line cord.
Worn brushes.
Faulty phase board.
Faulty control plate.
In any case, the Service Manual can be found at:
http://www.kitchenaidparts.eu/documents/pdf/service-manual/classic-svc-manual-new-email-version.pdf
Sep 25, 2013 | KitchenAid K45SS Classic Stand Mixer
Who repairs kitchen aid mixers
Call the Kitchen Aid small appliance warranty office and they will tell you where the authorized repair person is that is close to you.
Dec 16, 2012 | KitchenAid K45SS Classic Stand Mixer
What kind of grease can be used on a stand mixer after replacing a stripped worm gear? model:K45SS
Food grade grease is what Kitchen Aid put into the gearbox originally. They do supply it as a spare part if you cannot find it as a non Kitchen Aid part.
Nov 02, 2010 | KitchenAid K45SS Classic Stand Mixer
Kitchen aid k45ss classic unscrewed black plastic screws and springs on housing and replaced and now it won't run
Hi, JDMCIN. I hate it when that happens. It seems that power is not getting to the armature from the brushes so I would suspect that one or both of the brushes is (are) not seated properly. I'd suggest removing them again and making sure the contacts are facing in the right direction to contact the armature’s commutator. The concave contact face should be resting completely on the commutator. If you've turned it 90 degrees too much, it won’t' seat properly and the motor doesn’t get any juice.
Good luck, I hope this helps. Howard, Burke, VA\
If this solution has been helpful, please rate it, thanks! - hslincoln
Nov 26, 2009 | KitchenAid K45SS Classic Stand Mixer
My kitchen aid mixer makes a clicking sound when it is on and will not mix properly. It spins, but sounds bad.
Check the motor brushes. You'll see two black plugs with flathead screwdrivera small one, Unscrew to check, if only springs or very worn,youll,know.Its a maintenance problem.
Mar 11, 2009 | KitchenAid K45SS Classic Stand Mixer
My Kitchen Aid mixer attachement rod won't spin when turned on.
It sounds likme you may have stripped/broken one of the gears up in the mixer head. Any competent appliance repair shop should be able to fix it.
Jan 02, 2009 | KitchenAid K45SS Classic Stand Mixer
Kitchenaid mixer
Try replacing the moter brushes,if not its probably ether wiring or in the switch board.
Jun 01, 2008 | KitchenAid K45SS Classic Stand Mixer
Kitcchen Aid mixer making a grinding noise
common problem. Worm gear & bracket #PS734273 about $36.
Oct 21, 2007 | KitchenAid K45SS Classic Stand Mixer
KitchenAid K45SS Classic Stand Mixer Logo
64 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
