Question about One For All URC-4021 Remote Control
I have a tv all in one remote control i dont know the code number
To turn a symphonic tv on
    Sniper:
  • 52 Answers
The user manual for the all in one URC-4021 lists two possible codes for a Symphonic tv , they are: 0171 or 0180 if you try these codes then it should work. If it would help the user manual for your URC-3021 is available to view or download from the all for one website, if you use the link below it will take you to the site where if you follow the simple step process on screen it will take you to your user manual.
Hope this helped,
James
http://www.oneforall.com/us_US/support
Posted on May 01, 2010
Need the codes for an rca coverter box for a symphonic tv
Here is the code for your symphonic tv that works for me. It is "0053."
Here are the steps:
1.
Press the "On" button on the symphonic TV to turn that set on.
2.
Hold down the TV button on the symphonic remote until all of the buttons on that remote flash.
3.
Type in 0053 code for the symphonic TV remote as you point the remote toward the TV.
4.
Press either the "Power" or "Pound" ("#") button on the symphonic remote to save the code
Jun 11, 2011 | Televison & Video
Need to know how to reset my PX-RC1 remote control, and the code for symphonic TV Thank you
I hope this one will work for you. Please try these steps:
> Press and hold the MUTE and SELECT keys at the same time
> Using the number keys, enter 9-8-1
Here are the codes for your symphonic tv:
> 10180, 10171, 11904, 11944
Apr 06, 2011 | Radio Shack 15-2142 Remote Control
Sirs and mesdames: I have a Symphonic TV/VCR COMBO model # TVCRI3E1. The remote control part # (UREMT32SR007) is missing. Where can I find a replacement? Thanks, Ilia Rivera
Hello
Just buy one Philips Universal Remote control Model number [CL 034]. You can synchronise it with your Symphonic Combo by entering one amoung the following codes. Proceedings are also given.
Note: Switch OFF and Switch On your combo, before entering each code.
Three digit codes for Symphonic are:-
033/ 053/ 189
Four digit code for Symphonic TV/VCR combo is:-
0227
Four digit remote codes for Symphonic tv are:-
0053 0189 0227 0456 0024
Four digit codes for Funai are:-
0051 0189 0053 0227 0456 0042
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
You can also check according to the catelogue of that remote control also. The above given numbers are most common for all universal remote controls. OK.
Dec 24, 2010 | Funai Televison & Video
Program my symphonic tv
Here are the steps on how you will program your remote control to your Symphonic TV
1. Manually turn on the component you want the remote to control.
2. Press and hold the TV key. The illuminated ON•OFF key turns on and remains on. If you release the component key at any time during the Direct Code Entry procedure, the illuminated ON•OFF key blinks four times, and the process is exited.
4. While holding down the TV key, consult the list for the four-digit code that corresponds to your TV and use the number keys
(0-9) on the keypad to enter it. While you are pressing the
numbers, the illuminated ON•OFF key turns off.
5. After the fourth number is entered, the illuminated ON•OFF key turns on. At this time, release the TV key. If the illuminated ON•OFF key turns off, you have entered a valid code and have followed the correct
procedure for Direct Code Entry. If the illuminated ON•OFF key blinks
four times when the component key is released. This is an indication that a programming error has occurred. In that case, repeat the process from step 2. TIP: Throughout the programming of each key, be sure to keep the remote pointed at the IR sensor of the component you are currently programming the remote to control.
6. To confirm that the TV key is programmed with the correct
code for maximum functionality, test the TV. Attempt to
control a variety of the TV’s functions with the remote. If some of the features of your TV do not work, try programming the remote with a
different code in the list until you find the code that allows the remote to control the majority of your TV’s functions. Different codes can provide
different levels of functionality.
7. Remember to enter the code for future reference.
The codes for Symphonic TV are as follows:
1026, 1033, 1038, 1046, 1155, 1189
Jun 13, 2010 | RCA RCR311B Remote Control
What is the code for a symphonic tv and a rca remote. I also need insructions on how to program the remote that works with my tv. I lost the instructions
These are the steps on how to program your RCA Universal Remote Control to your Symphonic TV.
  1. Press and "HOLD" CODE SEARCH.
  2. Press and release the TV button. When the TV button flashes proceed to the next step.
  3. Enter the three digit code. In your case, the code for the Symphonic TV are 064 or 076.
  4. Release CODE SEARCH.
  5. With the TV on, press another button, for example CHANNEL UP. If the TV responds, no further programming is required. If the TV does not respond, repeat steps 1-5 using the other code number.
Jun 12, 2010 | RCA Universal Remote Control
I have a rca remote and i dont know the code for a symphonic tv in order to play my dvd/game
Start TV,and give AUTO SARCH remote !When TV close,push memory code with remote control.
May 30, 2010 | RCA RCU600M Remote Control
I have a symphonic tv i need tha code to make my all for one remote work for it i use to have it but threw it out by mistake i dont want to have to throw the remote away
To control your Symphonic TV with a One for All URC-3021, follow these steps:
1) Turn on your TV.
2) On the remote, press the TV key once.
3) Press and hold SET until the LED blinks twice, then release SET.
4) Enter the first four-digit code from the following list:
0180 or 0171
The LED will blink twice.
If it does not blink twice, go back to step 2 and try the same code again.
5) Aim the remote at the TV and press POWER.
The device should turn off.
If it does not turn off, repeat steps 2 through 5 with the next code in the list.
Hope that helps.
Nov 18, 2009 | One For All URC-3021 Remote Control
Need all codes for symphonic tv
Need the remote code number for a Symphonic TV Model # ST419B
Dec 22, 2008 | GE JASRM24912 Remote Control
Systemlink 3, code number for symphonic tv
I have a Symphonic also and I was able to program it to watch TV using the dfirections on teh inside of the battery door. Try it! I can't get VCR to work though.
Jul 01, 2008 | RCA RCU300WBL Remote Control
One For All URC-4021 Remote Control Logo
226 people viewed this question
Top One For All Televison & Video Experts
Computer Repairing
Computer Repairing
Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
