Question about Toshiba TEC B-472 Thermal Label Printer
Sometimes it will stop printing about an inch from the end of a label and display paper jam always seems to be same place
    Scholar:
  • 118 Answers
turn on/off, unplug, wait a minute, plug back in, should reset.
take all paper out. check to see if any paper is jammed in the rollers
go to application folder for your computer, dbl click icon for make of printer, for settings, check to ensure everything is order. check page alignment settings too
lastly, check make of printer trouble shooting web site for more information
hope this helps, good luck.
Posted on Apr 29, 2010
X4270 paper feed jam
You may have remnants of torn paper left in the feed rollers or beyond -from a prior jam. Other causes include:
  • Overheating
  • Wrong Paper Type
  • Printing Labels
  • Cracked or Dirty Rollers
  • Use of Wrong Tray
  • Incorrect Loading of Paper
  • Paper Overload
Nov 21, 2013 | Lexmark X4270 All-in-One Multifunction...
I am getting the error code 13.05.00 on an HP laserjet CP3505n printer. The manual says that it is a front door jam. The jam is occurring every other time I try to print a document. The document is being...
13.05.00 HP CP3505N
Problem Solve. Same error. Generally either a real or phanton jam from the paper tray or manual feed tray.
SOMETIMES the manual feed would work but always one corner on the paper turned down when printed.
Remove toner cartridges and bottom paper tray
Turn printer on its back. The black plastic flap (about 9" long) that hangs down a small amount (near the white main feed roller) had one end most likely the wrong side of the small metal rollers above it.
This flap should hang about vertical. One end of it is most likely the wrong side of the small mostly metal roller above it. Each End of this flap should be about mid way between the two smaller metal rollers.
WITH CARE take a timber skewer and carefully encourage this flap back so that both ends are in the correct place
Sep 02, 2010 | HP COLOR LASERJET CP 3505 N PRINTER
We are printing round labels on a 170XiIII plus I have no blackmark so it?s very difficult to calibrate this label When the printjob starts it backfeeds but not far enough to print the complete label I?ve...
No, well not really, the printer requires a area that it is allowed to touch where there is no image being laid, for if it did so allow ink on that area it would go on to the feed rollers and prevent them from gripping you paper.and producing marks on the edges..
but I guess, one may be able.. to place or stick a fake lead edge of paper on your paper, so that your printer may be able to grip your paper,, and you can place your image, or even putting in a custom page size that is ,20 inch extra long incorrect....
although this may work, the printer may or probably will indicate or go into a jam at the end of print due to page length being detected incorrectly, so you couldn't do a run, may get print warnings, and rear exit edge wouldn't print... but it might get you one at a time....give it a go, I'm only trying to explain why we need that edge and the back feed..so we can get a grip :)..hope this helps cheers..
Nov 27, 2009 | Office Equipment & Supplies
Canon MX310 keeps not printing and message comes up paper jam sometimes nothing happens sometimes startes to take paper then stops sometimes just feeds through without printing , there seems to be no real...
Have you ever tried printing sticky labels in the thing? You have to be careful with those because sometimes a piece will come off and stick in the corner of your printer. If you don't have long surgical tweezers to pull it out, you could be looking at an expensive repair. Also check your manual. There are two places the paper can jam in. You might have checked only one. I have a different Canon model but on mine I also have to make sure the correct light is on. Is the light for feeding from the back on, or the light from feeding on the front? If you have the same light, press it again to change the place where it will feed from.
Make sure your paper isn't curled or that you're using paper that's too thick also.
Can't answer more because I don't know what program you are using to try to print.
Sep 24, 2009 | Canon PIXMA MX310 All-In-One Printer
Paper is jam on the top feeder of Dell 1110
There is a section in the user guide that shows how to remove and avoid paper jams on this unit:
Click on the user guide link .
http://www.generalmanual.com/Printers/Dell-1110-Laser-Printer.htm
Printer paper jams can be caused from:
Paper that is sticking to-gether - fan your paper from both ends and both surfaces before placing it into the printer
Paper tends to absorb moisture in high humidity - this can also cause it to stick and jam.
Always store your paper flat - many printers jam readily when supplied with bent or slightly damaged paper.
There could be a piece of paper stuck in the printer from a previous jam - especially if you have printed labels - it only takes one tiny corner of a label to cause paper jams in any printer - cheap consumer models to commercial models costing thousands of dollars.
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Apr 23, 2009 | Office Equipment & Supplies
IBM InfoPrint 1612 Repeatedly erroring - Paper Jam
Check the FUSER, I think your exit sensor is bad.
If you open the rear door, look inside where the paper starts to come out of the printer, you should see a small lever that triggers the PAPER EXIT sensor. It might be hard to see. If it is not broken, you need a new FUSER.
Mar 18, 2009 | IBM Infoprint 1612 Laser Printer
RZ 220 Risograph error code A-16-525 after paper jam indication. No jam was present.
The master is stucked on the print drum,open print drum remove master and try again.
Let me know for futher help.
Jan 26, 2009 | Riso RZ220 Duplicator
Jamming paper
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Dec 30, 2008 | HP Photosmart C6180 All-In-One InkJet...
Printer Jam - when i put a sheet of Avery labels, printer jams
When you say TOP TRAY, do you mean a paper drawer, or the BYPASS TRAY? If the labels won't feed into the bypass but bond paper does, check to see if your labels are made for inkjet printers. Go to www.avery.com and contact Avery customer support to see what product they recommend for your MFC. Labels made for plain paper printers sometimes do not work for inkjets, and vice-a-versa.
Aug 29, 2008 | Brother MFC-5840CN All-In-One InkJet...
Labels jamming
Check the entire paper processing path as it sound like either the roller gear is not engaging properly to push the paper out of the top, or the output paper path is somehow blocked, like from a label or something else stuck at the top, the roller gear is damaged, or other obstruction.
Nov 16, 2007 | Konica Minolta magicolor 2300DL Laser...
Toshiba TEC B-472 Thermal Label Printer Logo
229 people viewed this question
Top Toshiba TEC Office Equipment & Supplies Experts
pkwc
CheckitRight
CheckitRight
richie46
Are you a Toshiba TEC Office Equipment and Supply Expert? Answer questions, earn points and help others
